Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 10-02-2008, 02:30 PM   #1
Innovative Tuning
Vendor Sales Rating: (43)
Member#: 67958
MY96 Time Attack
and 06 STI daily
Default GT35R Kits, Built engines and supplies, Turbos and more!
All pricing is valid until we change it or take the sale down!
Innovative Tuning Shortblocks. No core required!
Innovative Tuning Stage 2+ Shortblock:
This is a complete fully assembled shortblock built from a set of brand new OEM 703 casting 2.5L STi block halves and crank from Subaru with upgraded forged pistons, upgraded rings and pins, upgraded forged rods with ARP hardware, and coated bearings.
After evening the piston and rod weights the rotating assembly is balanced to a quarter of a gram or better at 10,000 rpm to ensure smooth operation.
CNC bore and hone are performed using Subaru specific deck plates.
All clearances are carefully checked and adjusted as necessary to extremely exacting tolerances. The new block halves are checked for true and surfaced to a finish beyond the requirements of MLS gaskets.
When it comes to building an engine we believe you either do it right or don't do it at all. We do NOT drop in stock bore pistons!
This shortblock is recommended for 600 crank HP, 8000 rpm, and 27 psi or less in a street, strip, or road race application. Rally engines are built to order and use different components.
4250+freight
Innovative Tuning Weekend Warrior Shortblock:
Those wishing for 500-700 crank hp and 25-35 psi of boost require greater resistance to deformation of the sleeves and heavier duty internals. The Weekend warrior takes the knowledge we've gleaned from track testing and puts it into practice.
In addition to the stage 2+ parts:
Ductile iron race sleeves are installed.
Severe duty forged rods and rod bolts are used.
Severe duty wrist pins are used.
We recommend an 8300 rpm rev limit if you're using the factory oiling system with an upgraded pump only (higher with dry sump) and strongly recommend talking to us about a head/cam/valvetrain package to take full advantage of this bottom end.
6950+freight
Again there is no core required for these crate engines! If you are unsure which of our engine options best meets your needs, which supporting components you require, or to inquire about freight, please feel free to contact us. We talk to every customer about their intended use of the vehicle, fuel(s) to be used, etc. etc. to custom tailor each engine. Different compression ratio pistons and clearances can be used for those with special needs. If neither package suits you, don't despair. We can just as easily put together a different setup. Contact us for details.
Innovative Tuning Cylinder Head Service
Stage 2 service shown.
Stage 1 Cylinder Head Service for WRX,LGT,FXT,STi:
This is a complete rebuild including:
pressure and leakdown testing
teardown and inspection
cleaning
intake and exhaust valve job
decking and surfacing (in case of MLS gasket usage)
and rebuilding to exacting tolerances with new valve seals.
Damaged parts are replaced as required at additional charge. Customers are contacted after testing and inspection with details on findings and an updated repair cost before proceeding if parts need replaced aside from valve seals.
749+ship
Stage 2 Cylinder Head Service for WRX,LGT,FXT,STi:
In addition to the rebuild detailed in Stage 1 the following SuperTech parts are installed:
upgraded black nitrided stainless intake and exhaust valves (stock size, .5 mm, or 1 mm oversized depending on usage)
heads are ported to accept the oversized valves if they are requested and seats are cut
dual valve springs
titanium retainers
alloy spring seats
1750+ship (shown above)
Stage 3 Cylinder Head Service for WRX,LGT,FXT,STi:
In addition to the rebuild detailed in Stage 1 and the parts listed in Stage 2, Stage 3 includes very thorough porting and upgraded camshafts. Cam options vary depending on usage and whether your heads are non AVCS or single AVCS. Flow numbers are available.
4250+ship
Other engine related components:
Kevlar Reinforced Timing Belt for WRX/STi/LGT/FXT - 119 shipped
This timing belt uses Kevlar technology for added strength/longevity and it's only slightly more expensive than an OEM belt. Frankly it's a no brainer.
CP Pistons with CP ring set - PM/Call for price!
Cometic WRX, STi or legacy turbo head gaskets - 97 shipped for the set!
Eagle Rods with ARP hardware - 335 shipped!
Carrillo Rods with WMC hardware - 925 shipped!
Carrillo Rods with Carrillo hardware - 1075 shipped!
New and improved ARP Head Studs for WRX, STi, and more - 175 Shipped!
A great addition to any engine build! Greater clamping force helps resist head lift and head gasket failures.
Supertech Valvetrain Set (compatible with Kelford, OEM, and other aftermarket cams) - 329 shipped!
Includes: Dual Springs, Titanium Retainers, and Alloy Spring Seats!
Supertech Valves also available!
Brian Crower, Kelford, and Cosworth Cams. Call for specs, availability, and pricing!
Ultimate Racing GT35R Turbo Kit
This is a complete 650 hp capable turbo kit for the WRX/STi from Ultimate Racing. It includes:
Garrett dual ball bearing GT35R turbocharger
Tial 44mm Wastegate
Ultimate Racing Uppipe with T3 turbo inlet and tial 44 wastegate inlet (vband)
Ultimate Racing 3" Downpipe
Ultimate Racing Wastgate dump tube for Tial 44 (vband outlet)
Ultimate Racing Cold Air Intake (4 inch at turbo inlet)
Turbo Lines and fittings
3250 SHIPPED!
This kit bolts onto stock and stock fitting exhaust manifolds and cat backs. All piping is full stainless steel unlike older kits. It also fits many intercooler setups both top mount and front mount, such as the Perrin FMIC shown above. Some require retrofit kits (sold separately). Ultimate Racing has produced a kit for the APS front mount, and another for the TurboXS/XSPower/SSAutochrome/Ebay front mount. Contact us for details.
Tuning, fuel system, intercooler and other upgrades such as a clutch are required to properly utilize any turbo kit designed to make this much power. Please contact us for details so we can help you put together a complete package.
Who is this kit right for? Someone looking to make over 400 whp (Dynojet numbers) on pump gas and considerably more on pump/meth or race gas. Built engine not required for lower boost tunes on this kit! Full boost is typically achieved just after 4000 rpm on a stock US STi engine at which point you better be aware of what's going on around you because things start happening quickly. This kit is not targeted at the autox/rallyx crowd, but it performs beautifully on a road course, on the street, and at the strip.
Ultimate Racing GT30R dual ball bearing and t3t04 E & S non ball bearing kits are also available!
T3T04E Kit - 2500 shipped!
T3T04S Kit - 2600 shipped!
GT30R Kit - 3150 shipped!
For those looking for a more conservative setup we offer the full line of Forced Performance bolt on turbos!
Blouch Subaru bolt on Evo 3 16g Turbos - 875 shipped!!!
If you're looking to upgrade your turbo without taking a big hit in spoolup this is your turbo!
Blouch Dominator 3.0R Turbos - 1675 shipped!
All other Blouch turbos are also available with 2-3 day build times!
And last but not least...Innovative Tuning Radiator Shrouds for 02-05 Impreza!
Add one to your $100+ order for just 40 dollars!!!
If you don't see what you're looking for here, PM/E-mail/Call us and we'll hook board members up even if your items aren't on sale!!!
NY state residents add 8.75% sales tax as usual. Shipped pricing applies to ground shipments within the lower 48 states.
There are two easy ways to order:
A) Call us at 716-873-7360
B) Paypal us at [email protected]
Mike McGinnis
Innovative Tuning
Voice/Fax: (716) 873-7360
[email protected]
http://www.InnovativeTuning.com
__________________
Mike McGinnis
Innovative Tuning
(716) 873-7360
Innovative Tuning is offline   Reply With Quote
Old 10-02-2008, 02:37 PM   #2
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Engines are built to order and custom tailored to each customer's needs.
Ultimate Racing GT35R kits etc. are IN STOCK and ready to ship as usual!
-Mike
__________________
Mike McGinnis
Innovative Tuning
(716) 873-7360
Old 10-20-2008, 09:33 PM   #3
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
So much for the economy being in trouble...you guys are making this October a record breaker for us. Thanks for all the orders!
__________________
Mike McGinnis
Innovative Tuning
(716) 873-7360
*No longer for sale!* 1999 2.5RS w/ low miles! Built Engine & custom turbo! ZeroDrift Private Vehicle 'For Sale' Classifieds 61 08-02-2010 06:27 AM
FS:(NY) Custom Built Innovative 67 Trim Turbo and 50 Trim.. WHP!!! iwanasubi Engine/Power/Exhaust 12 07-25-2008 09:23 AM
FS: NY GT35R Kit, Perrin EL Headers, Invidia Uppipe, Some more... 9vapors Tri-State Area Private Classifieds 23 08-20-2007 01:49 PM
blitz intake and stock turbo and intercooler onyxhunter Private 'For Sale' Classifieds 3 05-12-2005 12:48 AM
p and p turbo and boost dlowman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 08-18-2004 05:42 PM
