Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 10-02-2008, 03:43 PM   #1
SpeedElement
Vendor Sales Rating: (61)
Member#: 18920
2004 WRX/STI
Thumbs up New Perrin Pricing... It actually went down!! Titek, Greddy, Tanabe, Apexi Exhausts
SpeedElement is your Perrin Authorized Dealer!!
Perrin's pricing changed on Oct. 1st. Most of their great parts actually went down in price!
--All Perrin Hoses come in RED or BLACK. (no more blue) Choose color when ordering!--
New Perrin Turbo KITS!
When basic bolt ons won’t do or you have simply stalled out with the performance of the factory turbo then Perrin's Rotated Turbo Systems are the place to go! With kits that range in power totals from 350 WHP to more than 600WHP we have any boost junkies needs covered.
All Kits include: stainless steel up pipe and down pipe, Tial 44 wastegate, a new complete intake system, oil and water lines,and the Turbo.
GT3071R kit $3186 shipped!
GT3076R kit $3236 Shipped!
GT3582R kit $3295 shipped!
Perrin FMIC Kit: 02-07 WRX/STI
The PERRIN Performance Front Mount Intercooler is huge. Delivering higher cooling capacity and a significant reduction in intake temperatures. Cast aluminum end tanks and a bar-and-plate design offer smooth airflow and even pressure while retaining the stock bypass valve-mounting flange. Polished: $1,305 shipped! Signature (red) or New Stealth (black): $1339 Shipped
Perrin FMIC Kit: 08+ WRX/STI
With gargantuan cores, cast endtanks, high velocity tubing and proper mounting supports, there simply isn’t a better choice for your car, period. These intercoolers will support more than 1000 HP and due to our stringent quality control process have less than 1/4 psi drop across the core at 20 psi., improving throttle response and putting the boost where it belongs in the the combustion chamber!
Signature (red) or New Stealth (black): $1337 Shipped
Perrin Blow-thru Boost Tube: 02-07 WRX/STI
PERRIN Front Mount Intercooler users can now get a more accurate charge temperature reading and run a VTA BOV with no problems! Instead of measuring the Mass Air Flow (MAF) and air temperature before the turbocharger, the PERRIN PerformanceTM Blow-Thru boost tube moves the mass airflow sensor to the boost tube before the throttle body. The placement of this does many good things like allowing your ECU to read the actual charge temp the engine sees, which eliminates any need for a Cold air intake.
MSRP:$224.99, YOUR PRICE $205 FREE SHIPPING! Polished, Signature (red) or New Stealth (black)
PERRIN Performance™ TMIC
Perrin TMIC Fits 04-08 STI. We have these for 08+ WRX too! These bar and plate cores offer more surface area per square inch than cheap tube and fin choices from our less worthy competitors and the overall size is more than 200% of the OEM unit!
MSRP:$889.99, YOUR PRICE $800 FREE SHIPPING!
**For 02+ WRX add $140 for Y-Pipe kit.**
Perrin Intakes!
PERRIN Performance™ Cold Air Intake 08+ WRX/STI
Increase horsepower and style under your hood with a PERRIN Cold air intake system. This new 08 Intake was designed from the beginning to be a cold air intake. This provides much better more consistent HP and better drivability in all conditions.
MSRP:$199.99, YOUR PRICE $179 FREE SHIPPING!
PERRIN Performance™ Big MAF
The PERRIN Performance™ Big MAF intake system is designed to prevent the Mass Air Flow output value from being pegged on heavily modified WRX engines. When using the factory MAF sensor and adding large amounts of boost the stock MAF sensor will max out and not allow additional compensation for air flow.
MSRP:$239.99, YOUR PRICE $216 FREE SHIPPING!
Perrin Short Ram Intake
Manufacturing one of the only properly positioned and sized MAF sensor adaptors for the WRX, Perrin intakes are able to achieve higher horsepower numbers then their competitors.
MSRP: $199.99, YOUR PRICE $180 FREE SHIPPING!
Perrin Cold Air Intake
One of the only properly positioned and sized MAF sensor adaptors for the WRX, Perrin intakes are able to achieve higher horsepower numbers then our competitors.
MSRP: $299.99, YOUR PRICE $270 FREE SHIPPING!
Perrin AFTA-MAF Tube
Simple to install and easy to appreciate, the AFTA-MAF™ is an eloquent compliment to every engine bay. Replaces the factory corrugated rubber hose between the inlet tube and air box.
$79 FREE SHIPPING!!!!
Perrin Turbo Inlet Hose Kit. We have them for 02+ WRX/STI AND 08+ WRX
Fits: IHI VF series turbo, FP Green, and etc..
MSRP $219.99, YOUR PRICE $198 Free Shipping!!
PERRIN Performance™ Subaru 04-06 STI Fuel Rail Kit
This kit solves all fuel distribution problems. Perrins fuel rails direct fuel to both banks of cylinders and to the fuel pressure regulator. Even fuel distribution is achieved through the PERRIN™ design guaranteed! PERRIN Performance™ fuel rails are specifically designed for the 04-06 Subaru STI side feed injectors to retain correct fuel injector alignment. THE PERRIN FUEL RAIL KIT INCLUDES: BILLET ALUMINUM RAILS FUEL PRESSURE REGULATOR MOUNT STAINLESS LINES AND FITTINGS.
MSRP, $419.99, NOW $379 FREE SHIPPING!!!!
Perrin Crank Pulley
Weighing in at 1.2lbs, this pulley is more then 4 lbs lighter then the stock crank pulley. The Perrin pulley is not under driven and will not affect the life of your engine!
Fits: WRX, STi, Forester XT and Legacy GT
MSRP $134.99, YOUR PRICE $126 FREE SHIPPING!
Perrin Intercooler Hose Kit 02-05 WRX or 06-07 WRX
Increase airflow over stock intercooler hoses with PERRINs redesigned air passages insuring equal boost to all areas of any top mount intercooler.
MSRP $159.99, YOUR PRICE $144 FREE SHIPPING!
Perrin Radiator Hose
Made of high gloss vividly colored silicone, Perrin radiator hoses are an excellent compliment to your existing Perrin intake system or inlet hose.
Fits: WRX and STi
MSRP $139.99, YOUR PRICE $126 FREE SHIPPING!
Perrin Equal Length Header
Constructed from 321 stainless steel and 1/2 flanges the header is designed to withstand the most punishing levels of heat your engine can dish out. Fits all 2002-2007 models. (2.0 WRX models will require a STi type oilpan for clearance.)
MSRP $764.99, YOUR PRICE $689 FREE SHIPPING!
Perrin Front and Rear Section Down Pipes Available too for BOTH 02-07 WRX/STI AND 08+ WRX!
YOUR PRICE $PM For Pricing FREE SHIPPING!
---Catback and Down Pipes!! ---
--Titek Catless Down Pipe!!! 02-07 WRX/STI--
$254 shipped
--Tanabe Catless Down Pipe! 02-07 WRX/STI--
$345 shipped
--Megan Racing Catless Down Pipe! 02-07 WRX/STI --
$175 shipped
--Megan Racing Catless Down Pipe! 08+ WRX --
$220 shipped
--CATBACK SALE--
Greddy Exhausts are ALL on sale for a limited time! We can now offer you 15% off MSRP!!
EVO2
Inherent in its name, the EVO2 cat-back exhaust system is a huge step forward. In addition to the GReddy straight-through technology, offset tip design and large piping diameters of the original EVO, the EVO2 is now offered in full stainless steel providing improved looks, durability and corrosion resistance while maintaining the best qualities of the original such as fitment, sound and performance.
Fits 04+ STI and 02+ WRX!! 80mm Piping; 115mm Tip Size. Great power / nice and quiet.
List $729. Your Price = $620 Shipped!!
TI-C
GReddy Racing Ti-C Cat-back Exhausts combine the design, looks and flow of our Full Racing Titanium systems with the durability, deep sound, value and large application list of our other Stainless Steel street systems. This fusion of aggressive styling and practical construction, makes this the logical choice for both Race and Street Enthusiasts. The systems are comprised of a Titanium heat-treated tip, polished stainless steel muffler, unpolished stainless steel piping. It improves high and mid-range performance while still allowing for suitable sound levels.
List $635. Your Price = $540 Shipped!
New Greddy Comp TI-C FULL Turbo Backs Coming Soon!!!
Perrin New Stealth catbacks!!
$459!! for "sport" (evil)
Perrin Polished Sport catback - $399!!
Perrin Dual Tube (single tip) Catback - $469!!
Perrin Twin Tip - $399!!
Apexi PS Revolution Catback - $1015 Shipped
Apexi WS2 Catback - $569 Shipped
A'PEXi Ex Ti Catback - $985 Shipped
A'PEXi GTSpec Catback - $680 Shipped
Apexi N1 Catback - $540 Shipped
Tanabe Catbacks in stock! Big power without the noise! 95bd and below
Concept G Blue Full Turboback: 02-07 WRX/STI $1070 Shipped!
Medalion Touring: 02-07 WRX/STI - $715 shipped!
Medallion Concept G: 02-07 WRX/STI - $756
Visit our website for more details on all of the Catbacks we carry! http://www.speedelement.com/index.ph...0&limitstart=0
Sun Automobile!!
Hyper Ground System - Cyber Speed
Giving your car a more efficient ground will help to pull out its full performance potential! The cables used are unlike anything else available: thick-gauge, 99.99% pure copper with 1477 strands per cable, 4-layered shielding, and gold-plated terminals.
$PM for Pricing!
Hyper Force System
We have seen a 10hp gain from adding ONLY this system on our Dyno Dynamics Dyno!!
Click here for dyno the dyno chart!
$PreOrder for June!! Includes WRX harness!! PM for Price!!
Hyper Voltage System - Cyber Speed
Designed to stabilize voltage in your vehicle for maximum battery efficiency and allowing its full potential to be released.
$244 Shipped!
Check out ALL of the Sun Automobile products we carry as well as more info and pix in our online store!! http://www.speedelement.com/index.ph...mart&Itemid=38
As always you can check out our website for more items as well!! We are adding NEW 08+ WRX Items daily!!
If you order by paypal: sales@speedelement.com please add 3% fees or give us a call at 510.226.8822
FREE SHIPPING only applies to lower 48 states.
*CA Residents please add local sales tax* Paypal add 3% fees
Rob
Speed Element/MPJ Performance
www.speedelement.com / www.mpjperformance.com
44875 Industrial Drive Unit B
Fremont, CA 94538
__________________
1701 Rogers Ave Ste# 10
San Jose, CA 95112
408-573-8899
Paypal:
*CA residents add 8.75% sales tax. AK, HI Shipping additional.*
SpeedElement is offline
Old 10-06-2008, 01:54 PM   #2
SpeedElement
Member#: 18920
2004 WRX/STI
Bump for Monday
__________________
San Jose, CA 95112
408-573-8899
Paypal:
Old 10-06-2008, 10:02 PM   #3
Blaze-65
Member Sales Rating: (4)
Member#: 190655
2004 Impreza WRX
I have an 04 WRX with a perrin hose going to the intake, but I'd like to purchase the hose running from the throttle body to the top mount intercooler. My car's a WRX but the top mount is off an STI and it's a little short and slipping. I think I'm getting some nasty boost leak off of it. Would the "Perrin Intercooler Hose Kit 02-05 WRX" resolve this. If so I need to know the length of the hose running from the throttle body to the intercooler, I just want to make sure it's longer then what I currently have. I want to fix this right the first time.
Also another question, since this is flowing more air, will this push me out of a class in Auto-X? So far I've been told I would run in ESP. I just don't want to keep getting into class's I can't stay competitive in. Right now I'm still getting used to the car, but I like to plan for the future.
Blaze-65 is offline
Old 10-07-2008, 01:28 AM   #4
pignoseSTI
Member Sales Rating: (13)
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
With the intercooler hose kit you'd still be in ESP. +1 for SpeedElement!
Karlton
pignoseSTI is offline
Old 10-07-2008, 06:09 PM   #5
SpeedElement
Member#: 18920
2004 WRX/STI
Blaze, what year sti tmic are you running? If it has the solid cast Y and just the red silicone elbow you'll either just need a new elbow and coupler.
Shot you a PM
__________________
San Jose, CA 95112
408-573-8899
Paypal:
Old 10-07-2008, 08:12 PM   #6
Blaze-65
Member#: 190655
2004 Impreza WRX
I do have a red elbow running to the turbo, but I don't know about the Y. I replied to your pm but i'm assuming that it runs under the intercooler since I'm missing it. I'll see if I can locate a part number on it or snap some pics tomorrow when I have some light.
Blaze-65 is offline
Old 10-09-2008, 02:58 PM   #7
SpeedElement
Member#: 18920
2004 WRX/STI
If the Y pipe looks like this the perrin hoses arent going to be much help.
PM'ed you a link to some straight couplers.
__________________
San Jose, CA 95112
408-573-8899
Paypal:
Old 10-13-2008, 06:52 PM   #8
SpeedElement
Member#: 18920
2004 WRX/STI
Monday Bumps
__________________
San Jose, CA 95112
408-573-8899
Paypal:
Old 10-17-2008, 02:52 PM   #9
SpeedElement
Member#: 18920
2004 WRX/STI
Back up for Friday
__________________
San Jose, CA 95112
408-573-8899
Paypal:
Old 10-23-2008, 01:48 PM   #10
SpeedElement
Member#: 18920
2004 WRX/STI
We have the Short Rams and the Big Maf Intakes in stock. PM for best pricing on these!
__________________
San Jose, CA 95112
408-573-8899
Paypal:
Old 10-27-2008, 03:23 PM   #11
SpeedElement
Member#: 18920
2004 WRX/STI
Bumps!
__________________
San Jose, CA 95112
408-573-8899
Paypal:
Old 10-30-2008, 02:21 PM   #12
SpeedElement
Member#: 18920
2004 WRX/STI
__________________
San Jose, CA 95112
408-573-8899
Paypal:
Closed Thread
Prices of new 6-spd STI gearbox went down unclemat Transmission (AT/MT) & Driveline 103 02-08-2008 09:21 AM
Perrin Parts! Titek Downpipes! Greddy & Borla Exhausts! Cobb AP2! Turbo Kits & More! SpeedElement Engine/Power/Exhaust 82 11-16-2007 02:23 PM
Stage2 $1395 shipped + Cobb,HKS,GReddy,Tanabe,Titek,Invida,kartboy and many more!!!!! DCH Motorsports Engine/Power/Exhaust 11 01-27-2007 05:30 PM
New Shipment!!! TurboXS*Perrin*Invidia*Cobb*Greddy*Blitz*Apexi Spun Autosports Engine/Power/Exhaust 70 01-04-2007 07:32 AM
HKS, Blitz, Apexi, Greddy, Tanabe, Invidia EAuto Engine/Power/Exhaust 0 06-08-2004 06:15 PM
