Old 10-02-2008, 08:03 PM   #1
parkes
Member#: 166898
1994 T leg SS
ABM
Default Just pulled my codes from my swap..what to do?
This is how it went
LSSS=13
LLLS=31
Thanks to legacy777's websites for this.
Code13 cam angle sensor No signal entered from cam angle sensor, but signal (corresponding to at least two rotations of cam) entered from crank angle sensor
Code31 Throttle sensor Abnormal voltage input entered from throttle sensor Sets throttle sensor's voltage output to a fixed value
What should i do about these?
This is obviously what my problem is with why my car wont start correct?
It a stock EJ22T ECU trying to Run SOHC EJ25 Heads on Stock cam sensor.
parkes is offline   Reply With Quote
Old 10-03-2008, 12:24 AM   #2
parkes
Member#: 166898
1994 T leg SS
ABM
bump for needing help!
Old 10-03-2008, 12:22 PM   #3
parkes
Member#: 166898
1994 T leg SS
ABM
suggestions?
Bad cam gear sensor?
Wrong cam gear sensor?
Bad grounds?
Incompatible ECU?
Old 10-03-2008, 03:55 PM   #4
parkes
Member#: 166898
1994 T leg SS
ABM
anyone?
Old 10-04-2008, 12:19 AM   #5
parkes
Member#: 166898
1994 T leg SS
ABM
Nobody has any input?
just got a new 07 OBS, oh what to do, what to do... STI_Steve_555 Normally Aspirated Powertrain 19 12-04-2006 12:11 AM
'04 USDM swap. what to do about auto climate control? MrSaabaru Subaru Conversions 3 11-29-2005 07:50 AM
A/C Hose from DP install... what to do with them? Padge Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 03-17-2005 08:00 AM
Just back in Indiana for the Holidays, what to do... keirnna Mid West Subaru Owners Club Forum -- MWSOC 3 12-10-2004 09:24 AM
Wrx Brake Swap, what to do with the Rear? DDMan Brakes, Steering & Suspension 5 07-03-2003 01:02 AM
