Old 10-03-2008, 12:28 AM   #1
Tea cups
Member#: 103136
Default Very cold climate - concerns?
I just moved to a new city that can have some brutally cold winters at least compared to what I'm used to. Knowing I was moving there, I was checking out the temps last winter online and it seems that the low was frequently negative double digits every night (most of the time was about -25).
Question is, is it pretty much a given that I'll need an engine block heater and a battery warmer? Or is it not absolutely necessary? Car is an 02 WRX. I usually run German Castrol 0w-30 full synthetic oil and it is always garaged.
Tea cups is offline   Reply With Quote
Old 10-03-2008, 12:51 AM   #2
arrowscooby
Member#: 176615
??? sleeper
rex
looks like a fuel leak may be coming....do a search - you'll see what i'm talking about.
arrowscooby is offline   Reply With Quote
Old 10-03-2008, 01:28 AM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
You covered the basics. Thin oil and a block heater. Be prepared for the crazy noises cars make at temps that cold. For the most part you can ignore them and try not to think about it to much. It'll probably be very hard to shift until it warms up also. Might want to think about a thin gear oil in the trans. I've had mine in like -20 weather, it's not too bad once you warm it up.
Old 10-03-2008, 01:31 AM   #4
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
How cold r u guys talking about, I live in CT, should I get a battery warmer? Last winter, sometimes my starter was sounding like it was going 10 times slower then it should
Jubert69 is offline   Reply With Quote
Old 10-03-2008, 01:42 AM   #5
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yes, a block heater is a MUST and a battery warmer/blanket is a good idea too. And yea you can ignore most of the "different" sounds that come with the cold weather.
wrxdrvr is offline   Reply With Quote
Old 10-03-2008, 02:16 AM   #6
jack klompus
Member#: 152885
2014 Malibu LTZ
where are you moving to? North Canada? Alaska? Moscow? Thats some cold weather there.
jack klompus is offline   Reply With Quote
Old 10-03-2008, 02:54 AM   #7
2xhighpsi
Member#: 158089
2004 STi RomRaided
Michigan? lol but its true
2xhighpsi is offline   Reply With Quote
Old 10-03-2008, 08:04 AM   #8
Tea cups
Member#: 103136
I guess my question is whether or not it is absolutely necessary. I can't imagine everyone in the town is running a block heater. I haven't yet seen a plug dangling from the front of any car as might be commonplace in Canada or Alaska.
Old 10-03-2008, 09:09 AM   #9
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
I usually use the block heater once the nighttime temp gets around -20C here (~ 0F). I would definitely get one - it's kinder on the motor and kinder on you (without it, temps would be barely off the low mark after 1/2hr, and the cabin air would still blow cold all the way to work).
I used to have a battery warmer but never used it - took it off and put it in my truck because the battery is weaker in that and it takes more juice to start. They *do* make a big difference, but if your battery's in good shape shouldn't be necessary imo.
Gear oil can get VERY thick at those temps too.
UkNuck is offline   Reply With Quote
Old 10-03-2008, 10:29 AM   #10
Haelan
Member#: 151045
2013 Subaru STI
CBP
I upgraded my battery last winter to an Optima Red Top. Definitely much better in terms of cold cranking amps over stock. I think if you went that route you can ditch the battery heater and just go with a block heater.
Haelan is offline   Reply With Quote
Old 10-03-2008, 11:35 AM   #11
mbaker
Member#: 188614
2004 WRB WRX wagon
VF-37 twin scroll on E85!
also leave your car in gear and dont use the e-brake. the e-brake can freeze then you are mostly f**ked. or thats what we did in MD and it doesnt get nearly as cold down there.
mike
mbaker is offline   Reply With Quote
Old 10-03-2008, 01:13 PM   #12
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
09 triumph daytona 675
just know that once your warmed up and driving, with the heater blasting, you just might see power increases hahaha.... with cold air like that, i wouldnt be surprised
mannyOlicious is offline   Reply With Quote
Old 10-03-2008, 02:35 PM   #13
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
just dont be surprised if your tranny feels really gummy. perhaps look into a fuel stabilizer also, just incase theres any water in your tank and or lines..dont want that freezing and popping a fuel line
mxpunk is offline   Reply With Quote
Old 10-03-2008, 02:47 PM   #14
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yes. In my opinion it IS, necessary anytime it gets below -20*C. While the car will start even at -40*C (with a real good battery) The wear and tear while it's warming up, the extra gas it's using, combined with the battery not really taking a full charge when it's that cold and one day leaving you with a non starting car... Its worth every penny in my experience. If you garage the car then it's different, the car will start easy and the battery will take a charge better, it will warm up faster...
Old 10-03-2008, 04:35 PM   #15
rkramer
Member#: 118209
2015 WRX Limitec
(disclaimer, i've had my suby in -45F weather, got up to -30 or so as a DAYTIME high! Normally it isn't quite that cold here, but -20 to -30 is more the norm)
Anyway, if you have it in an attached garage, you can get by with neither of those. If it sits outside, a block heater is a near absolute requirement if you actually care about your engine. Battery heaters are nice, but I usually go with an onboard battery charger instead, wired into a single plugin with the block heater. The charger will warm the battery and keep it topped of when it is brutally cold.
anyway, welcome to the frigid north! On your first -20F day, here is something to try to see an example of what true cold is... Take a cup of hot water and toss it in the air.
Old 10-03-2008, 04:42 PM   #16
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Even if the car is garaged, there will still probably be instances when the car will sit at a friends or relatives house later at night or overnight, outside, exposed to the elements.
i would invest in everything possible to help the thing out.
Old 10-03-2008, 04:43 PM   #17
Ralliart4
Member#: 135927
2002 Impreza WRX RA
Hell i live in north florida and those lovely shrinking fuel lines are a BI@#$#
Ralliart4 is offline   Reply With Quote
Old 10-03-2008, 05:35 PM   #18
strohausii
Member#: 26770
'02 WRX
midnight black
Don't forget Coolant.
strohausii is offline   Reply With Quote
Old 10-03-2008, 05:45 PM   #19
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I kept my suby outside in a area with regular -20 days every winter for years and the engine still runs great. Compression is good all around. The engine now has over 220K miles.
I never had a block or battery warmer. They are not necessary.
They are really nice to have on those cold mornings though- the faster the engine is warm the faster you have heat.
speedyHAM is offline   Reply With Quote
Old 10-04-2008, 09:48 AM   #20
Tea cups
Member#: 103136
I was wondering about the coolant concentration as well. I can't really tell from Subaru's graph in the factory manual what 50/50 mix is good for. Looks like down to -30F?
Old 10-04-2008, 12:03 PM   #21
arrowscooby
Member#: 176615
??? sleeper
rex
did you even look into the dreaded fuel leak? and you're worrying about getting an engine block heater? wow.
Old 10-04-2008, 12:17 PM   #22
Tea cups
Member#: 103136
Yes, I'm well aware of the fuel leak. In fact, if you look at that thread, I posted a picture of the old fuel rail design and the new one before I installed it.
Toyota Drops Land Cruiser Citing Climate Concerns AVANTI R5 Non-Subaru News & Rumors 10 09-28-2007 07:28 PM
How bad is it to use 80w-90 in cold climates?? WRXSleeper Transmission (AT/MT) & Driveline 10 01-27-2006 01:10 PM
Very cold weather clutch issue semabe Transmission (AT/MT) & Driveline 4 03-04-2004 04:24 PM
A/C Compressor disabled in cold climates? overdose Service & Maintenance 6 01-21-2004 01:58 AM
"Cylinder #2 misfire" in very cold weather - anyone else see this problem? Patrick Olsen Normally Aspirated Powertrain 20 02-14-2002 08:31 PM
