Old 10-03-2008, 11:16 AM   #1
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Default Three COBB maps dynoed with AP DYNO
Posted this in the tuning section but thought some guys here may be interested. Will post up the PERRIN map when I get it.
So for those who care or have interest, went out today in my Wifes 08 STI.
Modded only with an Invidia Catted DP, wrapped and coated stock headers and an AP, 93 oct in the Texas sea level 95d temp.
Flashed each map in turn, idles for about two or three mins, couple of light pulls, then a third gear dyno on the same piece of road, 2500 rpm to 6600 rpm. (3rd gear pull), latest firmware etc etc.
Map/Roms from
COBB OTS Stage two 93 oct.
Surgeline tuning stage two 93 oct
CT stage two 93 oct
Waiting on a PERRIN map to test out also.
Anyways.
COBB - 282 WHP, 310WTQ - little soft down low but hits resonably hard but a little later in the rpm range.
Surgeline - 274 WHP, 314WTQ - very smooth across rev range - no real hit but a linear progression of power.
CT - 285 WHP, 310WTQ - Def surge down low, tapers after 5K noticibly, but a good kick.
Just my observations on my this car in those conditions, dont know how accurate it is but tried to complete pulls as identical as possible.
Any one else with similar roms post up.
Its great having the choice of three totally workable and different roms.
Cheers
Kastley85891 is offline   Reply With Quote
Old 10-03-2008, 11:22 AM   #2
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
cool.
Bad Noodle is online now   Reply With Quote
Old 10-03-2008, 11:26 AM   #3
ringe
Member#: 49998
2007 WRX CT Stg 2
I like my Clark Turner stage 1 map, I'm sure his others are strong as well. He definitely tunes for a serious surge on the bottom end, which I like.
ringe is offline   Reply With Quote
Old 10-03-2008, 11:54 AM   #4
onesixnin
Member#: 50992
09 Tribeca
Worst subaru blue
when we say surge down low, we are talking about a good spool and kick in the pants right? Not like boost spiking/falling off or compressor type of surge...?
The first one sounds great, the latter not so much.
onesixnin is offline   Reply With Quote
Old 10-03-2008, 12:43 PM   #5
CALIBAN
Member#: 188527
post some dyno graphs of before the tune and after the tune.
Its the percentage gain and power under the curve people should be looking at. Not the peak #s.
CALIBAN is offline   Reply With Quote
Old 10-03-2008, 12:50 PM   #6
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Its the spool fella, no issues.
Done on AP not laptop, no graph, just copied the numbers
Old 10-03-2008, 12:58 PM   #7
Butcherboy78
Member#: 187108
2008 Subaru STI
i also have the CT stage 1 map and i love it. complete drivability with this map. i get power as soon as i step on the gas and builds up to full power smoothly and tapers back down close to redline. im about to upgrade to stage 2 and ill let you know how that one is.
Butcherboy78 is offline   Reply With Quote
Old 10-03-2008, 06:37 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Cheers
You should log boost, timing and AFR with romraider and plot the 3 out vs each other. I doubt you have a wideband though.
But I think you'd be pretty surprised at how similar the numbers are gonna be.
The peak tq shows that they are all running equal boost and hitting peak at the same rpm. I guess one of them could be running lower boost and a lot more timing, but most tuners usually crank up the boost first.
Can you look at the maps in AP? Arent they all pretty much the same?
Old 10-03-2008, 06:46 PM   #9
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Ron
When Time permits I am going to do just that - ref logging, no WB as yet but in the mix shortly.
I was surprised on the numbers but a definite difference in feel between the three.
I think when the WB goes in I shall tweak the OTS and see how it goes from there.
I cannot open maps other then the OTS as they are locked by the respective tuner, race tuner enables me to view only the COBB or 'unlocked' roms.
Cheers
Old 10-03-2008, 08:18 PM   #10
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Do you need to log with a wideband to get tune a Clark Tuner map?
Old 10-03-2008, 08:28 PM   #11
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
No - see his post in vendor classifieds
Old 10-03-2008, 08:30 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
1) For an OTS map no...just like the OP of this thread.
2) For an internet protune with stock intake probably not
3) For an internet protune with a cold air intake, big maf, 70mm, etc and stock injectors probably not.
4) For an internet protune with 70mm + different injectors, a wideband is most likely a must.
Clark could probably put together a nice safe map for #4 but in reality he'd never know the AFR so i bet he wouldnt do it....
Old 10-03-2008, 08:39 PM   #13
juanmedina
Member#: 133146
Thanks, I am going to tune my car myself I was just wondering when a wideband was need it.
Old 10-03-2008, 11:17 PM   #14
benw
Member#: 103320
1998 swapped
Forester L
Are there definitions available for the 08 STI yet? I know we can read/write with the OpenPort 2.0 cable, but didn't know if logger/editor defs were available yet.
benw is offline   Reply With Quote
Old 10-03-2008, 11:36 PM   #15
Phatron
Member#: 36033
CEO PhatBottiTuning
for juan, those were just my suspicions....not clarks words
for ben, im not sure....
Old 10-04-2008, 02:46 AM   #16
Clark Turner
Member#: 178047
02 WRX STI Spec C
Pretty cool. I have used the ap dyno feature. The trouble is that you must dyno all maps with the same starting temps, on the same road. Otherwise the power will vary. What I instruct people to do, is to load the map, Idle for 5 minutes, Drive around the block shifting at the same rpm, Then on the same point on the road, run the dyno. this way, we will have air across the ic and intake temps will be close. Any incline or decline in the road will effect the readings.
The HP tends to read pretty close on the ap dyno but the Trq always seems low compared to an actual chassis dyno. But not that far off. The map you are running is a concervative pump gas map that typicaly makes 280 to 300whp and 300 to 330ft lbs of trq so your readings are not far off. The only thing I dont understand is most of the time the Cobb map makes 260 to 275whp and 270 to 280trq. You car seems to like the cobb map.
The biggest thing you wont see with the AP dyno is the gains at RPM points. I had a customer complain that my 08 WRX map was only making 5hp and the same trq. However, When he dyno tested the maps and emailed me the graph, I saw 60ftlbs gain at 3000 to 5000 rpm!!! and about 40whp gained under 5500. The stock turbo is small and it produced about the same peak hp on both maps.
I have maps for just about any setup. I always prefer to have a WB but stage1, 2, 3 and most stock location turbos, I dont need one. On larger setups its a must unless Its a very common setup that I tune alot. I have many data logs of typical IDCs with popular injectors along with logs of Airflow so I normaly can nail it with in 1 AFR point. All maps will be on the rich side in the 10s unless I have an WB AFR log, I can read and adjust.
Clark
Clark Turner is offline   Reply With Quote
Old 10-04-2008, 11:19 AM   #17
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Clark
Clark
Thanks for chiming in,
As you know your map does rock on my STI in terms of spool and ass shunt, yes my car does like the COBB map also, along with the Surgeline unit, they are all similar power/TRQ on my vehicle with same temps,road conditions etc, although they all 'feel' so different, its great.
As soon as my WB02 is in I will start to log them all and get a bit more in to it, but its all interesting, well to me any ways
Looking over the ROM's it aint that different from my 06 so when time permits will mod the base map and see how it goes, will post any results etc, its getting cooler here now slightly so hopefully find a nice 95dC ambiant temp day!
Cheers
Old 10-06-2008, 07:28 PM   #18
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Man I should have read this thread before posting this topic:
Cobb V2 AP Dynamometer
Anyone have any input on this? I've been playing with this feature recently too...
Steve.804 is offline   Reply With Quote
Old 10-07-2008, 08:39 AM   #19
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
FWIW the cobb map is a Bailey tune as well
jmlaser is offline   Reply With Quote
Old 10-08-2008, 02:39 PM   #20
ringe
Member#: 49998
2007 WRX CT Stg 2
Right on the first one.
Old 10-11-2008, 11:17 AM   #21
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I have used the Dyno function on the AP a few times with my 08 Stage 2 sti. Everytime it has returned around 400hp and 450 tq....obviously a little off. Weight input is dead on as well.
Old 10-11-2008, 11:22 AM   #22
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I had the same thing happen to me when I went to stage 2. Stage 1 it was as expected, but stage 2 was reporting over 400 whp. I asked cobb and they had no clue.
edit: over 300 whp, like 380.
Frank A is offline   Reply With Quote
Old 10-11-2008, 01:57 PM   #23
Davenow
Member#: 23676
Looking at the numbers and your impressions, I would rather have the Surgeline map.
Old 11-20-2008, 07:18 PM   #24
Tronner
Member#: 12845
2008 BMW 335xi
Sparkling Graphite
Kastley, you should download the new Cobb map and see how it does. They have a version 1.02 that may be better.
Tronner is offline   Reply With Quote
06 wrx VF39 cobb map work with 07 VF43 Turbo? Nasty25 AccessPort 3 12-02-2009 04:53 PM
Will the vf39 Cobb Map work with the vf43? socomcaptain05 Newbies & FAQs 20 11-04-2009 02:44 PM
Pro Dyno vs. AP Dyno jrod922 General Community 7 06-21-2009 02:13 PM
06 wrx VF39 cobb map work with 07 VF43 Turbo? Nasty25 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-30-2008 06:50 AM
Unmarry 06 cobb AP with custom dyno tune HP ADDICT AccessPort 4 07-11-2008 12:28 AM
