Old 10-03-2008, 05:42 PM   #1
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
Default Pilot bearing gone bad?
How do I know if a pilot bearing has gone bad?
What noises would it make and when would it make them?
I know what noises the car is making, but I don't want to lead the witnesses
See Post #4.
DiscoGsus is offline   Reply With Quote
Old 10-06-2008, 01:20 PM   #2
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
With the clutch out, the pilot will make NO noise. A binding pilot bearing will act like the clutch doesnt release all the way, and/or produce noise when the clutch is pressed.
Does this help????
Andrew
AndrewtechAutomotive is offline   Reply With Quote
Old 10-06-2008, 03:04 PM   #3
SOHCEJ25
Member#: 135013
'17 WRX Hatch ; )
I have seen some really bad Pilot bearing and not have any noises or symptoms .....
Shawn
GerBrock.net
My Site
SOHCEJ25 is offline   Reply With Quote
Old 10-06-2008, 03:54 PM   #4
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
I thought the throw-out bearing made noise when the clutch is pressed? And the Pilot when it wasn't.... hmm.
I have a noise that goes away as soon as you press the clutch pedal. Not even press it all the way in and disengage the tranny, just depress it like 1/2" and as soon as the "free play" in the system is taken up the sound disappears.
The noises is sort of engine speed related. And it is an annoying squeaking sound. (Sounds like a squeaky belt.)
Old 10-07-2008, 07:12 AM   #5
Woodward
Member#: 102424
2003 Tundra
GrEy
EXACTLY what I have right now.
I bought a new TO bearing from Subaru that's being installed right now, so we'll see if that works.
Pretty crazy, but you described the exact problem I'm having. It sounded like a squeaky belt, but when I barely press on the clutch, it goes away completely.
Woodward is offline   Reply With Quote
Old 10-07-2008, 09:40 AM   #6
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
Please let me know if that fixes it!
Andrew, does that sound like a Throw out bearing?
Old 10-08-2008, 02:04 AM   #7
Woodward
Member#: 102424
2003 Tundra
GrEy
I'm getting my tranny worked on right now, so I HOPE it's the TO bearing bc I don't want to have to take it all apart again for the little pilot bearing :/
This is what happened to me though... I blew 3rd gear so while it was down I thought I'd upgrade the clutch to an Exedy Stg 1. I also replaced the stock TO bearing with the one that came in the package w/ the clutch. I think that's when it started to sound weird. I always thought it was a belt till I had my window down at an intersection and pressed the clutch a lil.
If I don't reply back on here about the replaced TO bearing in a week or so, then just PM me.
Old 10-10-2008, 03:27 PM   #8
redrexmeister
Member#: 111692
04 wrx wagon
was it TO bearing?
redrexmeister is offline   Reply With Quote
Old 10-13-2008, 07:03 AM   #9
Woodward
Member#: 102424
2003 Tundra
GrEy
STILL waiting for my car to be fixed. It's been one month now.....
Old 10-15-2008, 08:24 PM   #10
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
I just finished replacing the clutch disc, pressure plate, TO bearing, and pilot bearing in my '02 WRX.
It was making a noise whenever the clutch was beginning to engage or disengage (pedal about 1/2 way up/down). I assumed it was the TO (aka 'release') bearing but it turned out to be the pilot bearing.
The strange thing is that it never made noise when the clutch was fully engaged or fully disengaged, only in between.
BTW -- I broke a bearing puller trying to remove it and finally had to remove the flywheel and tap it out. If I had it to do again I would just remove the flywheel at the first sign that it was going to be stubborn.
sajohnson is offline   Reply With Quote
Old 10-23-2008, 01:23 PM   #11
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
This thread has/had a similar problem, and contains useful things on posts 12 and 24. (As well as a general helping hint on post 34.)
http://forums.nasioc.com/forums/show....php?t=1553251
When/If it gets warm or a I find a garage, I will try to lube my shift fork and check the slave cylinder condition as well.
Old 10-23-2008, 03:05 PM   #12
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
What TurboL says about the pilot bearing in #34 is correct, however it didn't squeal when the clutch pedal was depressed (even though you'd think it would).
In fact, it _never_ made noise when the clutch was fully engaged or disengaged -- only when it was slipping -- in the process of engaging or disengaging.
The only theory I can think of is that when the clutch is fully engaged or disengaged there is no (or very little) lateral force applied to the input shaft, but when the clutch is engaging the shaft has torque applied to it causing it to shift position (as much as the transaxle input bearing will allow).
Just a guess.
Old 10-27-2008, 03:32 AM   #13
Woodward
Member#: 102424
2003 Tundra
GrEy
My noise was fixed. Just bought a TO bearing from Subaru and had a shop replace it while my tranny was being worked on. The sound Disco and I described is completely gone in my car now.
I must have gotten a bad bearing from Exedy or maybe it was damage when we installed it the first time... not sure.
Old 10-27-2008, 03:56 AM   #14
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
Congrats!
Old 10-27-2008, 09:55 AM   #15
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
My clutch is an Exedy as well....
Can you ask if they lubed your shift fork as well?
Old 10-29-2008, 05:46 AM   #16
Woodward
Member#: 102424
2003 Tundra
GrEy
I did myself before when I replaced my clutch with my Subaru mech. and the noise started. But I think we have different clutch setups so I'm not sure what u mean.
Old 01-08-2009, 04:25 PM   #17
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
So, it was the throw-out bearing.
And it cost WAY to much to fix because you have to pull the transmission.... but I have another new exedy.
Wheel Bearing Gone Bad SubieWubieWu Service & Maintenance 11 10-16-2009 06:19 PM
Bad Clutch, or Pilot Bearing??? Hardline Transmission (AT/MT) & Driveline 5 07-17-2009 02:07 AM
WTB: Flywheel Pilot bearing or Flywheel w/ pilot bearing snowcrzy SCIC Private Classifieds 0 02-21-2007 02:01 PM
Wheel bearing gone bad Mr.Sparkle New England Impreza Club Forum -- NESIC 7 08-11-2006 11:43 AM
Noise! throwout bearing? pilot bearing? Wellhung Transmission (AT/MT) & Driveline 16 11-03-2002 01:42 AM
