Old 10-04-2008, 03:06 PM   #1
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Default If Subarus came from the factory with widebands...
They would probably look something like this:
As soon as my cat back comes in, I'm going to install everything for stage 2 and flash the ecu with an open source map. Because I'm going with open source tuning, I wanted to be able to monitor my air/fuel ratio. To do this, I got an innovate lc-1. The only problem is I had no idea where to put it. I already have boost/egt/oil pressure in the clock pod, and I refuse to get an A pillar pod just because of the rice factor. After talking to a friend, I decided to put it in the ash tray. This presented some challenges, but I think I did a good job of overcoming them, and I'm very pleased with the final result.
I have more pictures and some explanation of what I did here: http://www.cgbagne.com/wrx/?p=172 . This site is self hosted. If it doesn't work, try back later. Historically, it has been very reliable, but it is only a box in my basement.
I took a bunch of pictures throughout the process, so I can make a decent write-up if the interest is great enough.
573 is offline   Reply With Quote
Old 10-04-2008, 03:10 PM   #2
puls8n91
Member#: 134696
2002 Stage 2 Bug eye
White on White
Wow, very nice install
puls8n91 is offline   Reply With Quote
Old 10-04-2008, 03:17 PM   #3
mightyRS25
Member#: 186861
03 BMW 325i
Deep Blue
Yeah man looks sick...
mightyRS25 is offline   Reply With Quote
Old 10-04-2008, 03:37 PM   #4
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Thanks for the kind words. It has a few minor flaws, but like I said, they are minor and don't bother me very much. The biggest issue is that the area under the window is sunken in a bit. I may redo that part some day, but for now, it will suffice.
Old 10-04-2008, 03:38 PM   #5
jarkid27
Member#: 124274
04 WRX Wagon
WR Blue
love it, looks really good!
but how is an a pillar pod a "rice factor" and not a clock mount?
jarkid27 is offline   Reply With Quote
Old 10-04-2008, 03:44 PM   #6
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Thanks!
It's just personal preference, I guess. The clock mount is lower, and since it is in the center of the dash, it is less visible from the outside. But you are right, even with the oem gauge pod, it isn't significantly better than an A pillar mount.
Old 10-04-2008, 06:12 PM   #7
k20utah
Member#: 170791
this is a very nice DIY.... wouldn't it be hard to see when your driving... but its not like your looking at it all the time lol.... but if it was me i would like it in front of me somewhere.
k20utah is offline   Reply With Quote
Old 10-04-2008, 06:20 PM   #8
Davenow
Member#: 23676
wow. Someone get this man a lower member number.
Old 10-04-2008, 06:41 PM   #9
EJ2point0
Member#: 103062
' YEN
EJ2point0 is offline   Reply With Quote
Old 10-04-2008, 08:21 PM   #10
MGAMAN
Member#: 24671
2010 Audi S4 PP
2006 R1 - 06/08 hybrid
Love the quality and thought behind doing it, read your blog on it, but I don't know how much I'd like to be looking down there while going fast. Quick reference looks are fine, but still a bit less usefully placed than I would personally prefer, but damned if it isn't sweet!
MGAMAN is offline   Reply With Quote
Old 10-04-2008, 08:25 PM   #11
Mechie3
Member#: 120152
I have a 2 pod A pod pillar. It might be "rice", but I can see the various color coded LED's for the wideband rather clearly in my peripheral vision.
Kudos for a job well done though!
Mechie3 is offline   Reply With Quote
Old 10-04-2008, 11:09 PM   #12
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Thanks for the comments everybody.
Though the location isn't ideal for visibility, it isn't bad either. I'll probably watch it pretty closely when I first put a new map on, but once I know it's legit, there really isn't much reason to keep looking down.
That would be awesome. I suppose I could just be an honorary <100k member.
Thanks man. I would have just gone with the Subiegal pod for the sake of simplicity and visibility if my gps weren't already in that location. Since that wasn't an option, I thought this was the next best thing.
Something that I do really like about this location is it sort of reminds me of the James Bond cars. If I close the little door thing, nobody has any way of knowing what is there. My next diy may have to involve a hidden missile system.
Old 10-05-2008, 04:55 PM   #13
tyce
Member#: 15099
2002 EJ257 WRX
Matte Grey
great looking mod! I'm tired of my LM-1 rolling around on the floor.
tyce is offline   Reply With Quote
Old 12-19-2010, 04:13 AM   #14
ReD-DaWg-OnE
Member#: 47727
2005 SAAB 9-2x Aero
Red
I hate to revive an old thread but in case anyone finds this in a search, the site bellow sells a 3.5mm cable that is made to use wall plates for custom setups, however it only mounts by going threw the hole and then it has a ring on the outside that tightens down and holds it in place. Might make it easier to hold in place.
http://datapro.net/products/dual-pan...tereo-f-f.html
ReD-DaWg-OnE is offline   Reply With Quote
Old 12-19-2010, 09:06 AM   #15
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Interesting. That would certainly make things a bit easier but one of my criteria for this thing was that everything be flush to the panel. It seems as though that product would stick out some.
If it matters to anybody, this thing its still holding up nicely. No problems to speak of aside from the roughness that you can see below the display in the original pictures. I'd like to redo it at some point to address that but its hardly a priority.
Old 12-19-2010, 12:16 PM   #16
little johnny
Member#: 267564
05/6 Impreza
silvergreyprimer
install looks OE!
props to ya
question: is there an audible peak warn?
A/F(knock) is one(if not the only) thing I would keep up high in view
little johnny is offline   Reply With Quote
Old 12-19-2010, 12:59 PM   #17
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
No, it's just a basic gauge from innovate that I hacked up. It's primarily there for tuning, so it doesn't really require constant attention. I can log with it and my tuner can see it just fine from the passenger seat, so it serves my needs just fine.
Old 12-19-2010, 03:11 PM   #18
motownmego
Member#: 267533
i like it alot, and the fact that you can close the door when you dont want to look at it
motownmego is offline   Reply With Quote
Old 12-19-2010, 06:21 PM   #19
little johnny
Member#: 267564
05/6 Impreza
silvergreyprimer
ah!
in that case cool beans!
as I mentioned, install looks OE! great job!
Old 12-19-2010, 06:29 PM   #20
kasra007
Member#: 225361
2006 wrx sti
beige
This is a bit off topic but how is adding an "A pillar pod" a rice factor? the fact your doing this many mods to a wrx "wagon" makes your car already a ricer.
kasra007 is offline   Reply With Quote
Old 12-19-2010, 06:36 PM   #21
skwirnmn
Member#: 231356
09 2.5i
black
completely opposite of rice.. he just didn't want to do the a pillar pod, who cares? this was super innovative!
skwirnmn is offline   Reply With Quote
Old 12-19-2010, 06:52 PM   #22
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
Biotches won't ever understand a Wagon... that's ok... you stick to your STi/Sedan la-la land fantasy....
Rob
TXwrxWagon is offline   Reply With Quote
Old 12-19-2010, 07:12 PM   #23
kasra007
Member#: 225361
2006 wrx sti
beige
Rob
lol what? Why don't you read my OP again.
Your bitching about A pillar pods because they are ricer yet you have a stage 2 on your wagon or in other words.. you shouldn't be calling a pillar pods ricer when you have a stage 2 wagon with a clock pod.
The wide-band mod does looks nice though
Old 12-19-2010, 07:20 PM   #24
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
i like it!
Rexxyou is offline   Reply With Quote
Old 12-19-2010, 07:27 PM   #25
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
clean!
Fat Black Pig Sac is offline   Reply With Quote
Does a WRX tranny come from the factory with Extra S in it? 09rexwagon Transmission (AT/MT) & Driveline 26 07-31-2009 04:53 PM
Why dont all cars come with SS brake lines from the factory? TJOD Brakes, Steering & Suspension 31 09-05-2008 10:32 PM
If someone came from the future to kill your child, would you let them? Strider Off-Topic 26 01-15-2008 12:43 PM
Should all Subarus come from the factory with full Group N level bushings? Back Road Runner Brakes, Steering & Suspension 19 11-13-2007 09:22 PM
help with choosing mods from the factory, when buying thewrx fufanu Member's Car Gallery 4 06-04-2001 11:04 AM
