Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 10-04-2008, 03:45 PM   #1
Member#: 46685
2002 WRX Sedan
Default How likely is it that this engine is toast?
Okay, I have a line on a super cheap Forester. 98 Forester S to be exact. Here's the copy of the workorder from the shop.
Towed in. Customer reports driving on the highway and started hearing a rattling noise. Then the engine died and customer was able to coast to the shoulder. The tow truck company tried to turn the engine over but a clackity clack and then a bang sounded. Smoke also came out from under hood. Showed signs of oil dripping onto the floor. Oil was changed about a week ago.
(1) Inspection found timing belt damage and not turning cam shafts.
(2) Oil level is good but coolant level is low. There is oil at front of engine.
(3) Need to verify condition of engine before determining repair.
The shop recommended
Replace timing belt and perform cylinder leak down test to verify condition of engine.
One of the techs that worked on it suggested that if I replaced the timing belt, the engine could be fine, but there's a good chance it's doomed as well. A timing belt will only set me back an afternoon and about 60 dollars, but would I be wasting my time by not finding an engine instead?
estrada42 is offline   Reply With Quote
Old 10-04-2008, 05:33 PM   #2
Member#: 149442
You have an interference engine, so chances are good a number of valves smacked into your pistons when the belt broke.
Impaled is offline   Reply With Quote
Old 10-04-2008, 11:55 PM   #3
Member#: 117996
2002 Impreza 2.5RS
Midnight Blue
If the belt is removed, it is easy to check the compression. Just make sure that the cams are both free to rotate and not depressing the valves. Then go about performing a compression test as you would normally do it. As long as the starter turns the motor over, the compression can be checked.
If in fact the valves are bent, which is most likely the case, you will have very little or no compression. If the cam wont rotate at all, then valve train damage has occurred. Removing the valve covers isnt terribly hard on our motors and could reveal some of the damage right away...
Best of luck in your troubleshooting...
pondomoto is offline   Reply With Quote
Old 10-05-2008, 12:01 AM   #4
Member#: 120029
I hate to say it but that dripping oil at the front of the engine might have been from a rod blasting its way through the block. If you decide to take a look make sure you check the block thoroughly.
8ender is offline   Reply With Quote
Old 10-05-2008, 11:02 AM   #5
Member#: 80465
2001 2.5RS
Black Diamond Pearl
um, you can't do a reliable compression test with no timing belt. the engine has to have something to compress. If the intake valves aren't opening, all you're doing is creating a vacuum inside the cylinder and then recompressing it back to ambient. yes, i realize that with ring sealing, you may get some leaking, but unless you start with the crank at BDC, screw in your compression tester, and then crank, your results will be skewed.
Estrada, have you looked at the engine? I agree that dripping oil indicates that something punched thru the block. goodbye engine.
OK... why is it that our OT is bigger than ANY other car forum I have ever been on?? eightballrj Off-Topic 60 01-22-2013 11:02 PM
How is it that OT is like this??? sjt Off-Topic 51 05-06-2011 07:54 PM
Why is it that swapping files on a home network is like rocket science? Unabomber Off-Topic 23 01-25-2009 10:43 PM
i would like to know what version sti this engine is??? compfool General Community 1 03-12-2004 03:41 AM
Question to all. What is it that you don't like about autox? Tangmere Rocky Mountains Impreza Club Forum -- RMIC 13 11-02-2001 11:00 AM
