Old 10-04-2008, 09:25 PM   #1
csimp3
Member#: 188464
02 wrx
wrb, silver, black,primer
Default help needed! tokico blues and a super annoying clanking sound
hey, ok, heres my problem, my car came with tokico blues and h&r springs, car wasnt running good when i got it so they were never really driven on till i got it, but i have a super annoying and rather loud clunk noise everytime i hit a bump. i pulled the coilover off just now, and what im wondering is this, is there supposed to be some sort of rubber bushing on top of the shock where it mounts to the car? if so, would there not being one cause this noise? any other input on what the noise could be coming from? i didnt check to see if it was rubbing before i took it off either, but the spring doesnt appear to have any rub marks, and once the shcok was loose when i shook it and the top hit the mount, it made the same noise, anything will help, thanks
csimp3 is offline   Reply With Quote
Old 10-04-2008, 10:41 PM   #2
csimp3
Member#: 188464
02 wrx
also, it is only the rear passenger side making any noise, and when i removed it, the three bolts that hold it on, were not all even, one had almost a quarter inch more threads showing, could that have to do with it also?
Old 10-04-2008, 11:16 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
This is probably the cause. Although I wouldn't be surprised if the springs are install incorrectly on the struts. What year car do you have?
Old 10-04-2008, 11:24 PM   #4
csimp3
Member#: 188464
02 wrx
its an 02 wrx. and after some of the things the previous owner did, i wouldnt be surprised either. how do i know if they are correct?
Old 10-05-2008, 12:50 AM   #5
csimp3
Member#: 188464
02 wrx
ok, replaced the coilover, got it so all the bolts are tight and even, and its still doing it. is it possible another suspension component is bent and i just cant tell? i am very new to suspension, if you couldnt tell that already, lol
Old 10-05-2008, 12:56 AM   #6
csimp3
Member#: 188464
02 wrx
oh yeah, one more thing, sorry, just trying to give as much info as possible, once installed, the piston shaft is not centered in the middle of the spring at all, thats what leads me to believe something is possibly bent somewhere
Old 10-05-2008, 05:22 PM   #7
csimp3
Member#: 188464
02 wrx
bump, any ideas?
Old 10-05-2008, 08:58 PM   #8
Arctic Penguin
Member#: 119532
2006 WRX
fill in your profile so we know what the hell you drive
post in your local area forum for some local that may just pop by and help ya out
Arctic Penguin is offline   Reply With Quote
Little help - need 50 HP and quicker spool-up WRC-Go Factory 2.0L Turbo Powertrain 87 03-26-2005 07:46 AM
Help!! Need everyone's opinions and pics...CE28N's on STi silver ghost Member's Car Gallery 2 02-11-2005 12:14 AM
Need help...Need a garage and tools for engine install! SpamMansXe Mid Atlantic Impreza Club -- MAIC 4 07-27-2003 06:17 PM
Help, Need stock wheels and tires- Atlanta area WRX4FUN South East Region Forum 0 04-19-2003 11:43 AM
Help Needed Re: Boost and Air/Fuel Guage Installs, please! :) Fred C Factory 2.0L Turbo Powertrain 2 10-17-2001 09:35 AM
Message Board Statistics All times are GMT -4. The time now is 05:21 AM.
