Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 10-04-2008, 11:16 PM   #1
parkes
Member#: 166898
1994 T leg SS
ABM
Default Why is one sprocket solid and the other metal?
These are 1999 Subaru RS SOHC heads, Why is one cam sprocket plastic the other metal?
Also What is the Correct procedure to remove the timing belt to remove the cam sprocket? then correct torque specs?
parkes is offline   Reply With Quote
Old 10-05-2008, 12:57 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I see a couple of interesting things. I see a turbo water pump, I see a different chassis, I see wrapped headers, I see FMIC piping, I see different alternator.
I believe it was easier to cast a sproket all metal than it was inserting little medal pieces onto the carbon/graphite?? sprokects??
If I plan on reusing the timing belt, I usually rotate the motor until the SINGLE notches of the crank and cam gears are UP. I then take a paint pen and mark my timing belt with those notches. I remove the bottem passenger pulley first. Then I remove the teethed pulley next to the waterpump. The driverside cam gear MAY SPIN, you are fine if it does.
IIRC the torque on the cam gears are 36ft lbs??
FuJi K is online now   Reply With Quote
Old 10-05-2008, 01:36 PM   #3
silentt
Member#: 119995
2004 Outback XT
Peachy
What the **** are you doing?
It has an ej22t block on those heads, originally from a 99 RS. He bought that motor and is putting it in his legacy.
silentt is offline   Reply With Quote
Old 10-05-2008, 06:08 PM   #4
parkes
Member#: 166898
1994 T leg SS
ABM
A guy i met up over on legacy central came over, We looked at the engine talked it over and he phoned up his subaru Tech Guy, My best option is to Use my EJ22T Cam gear sprockets to be compatible with my Cam gear sensor, He scanned my ECU told me my codes and this is my best option right now, TO change these sprockets to my EJ22T ones, as the cam gear sprocket has different points on the back.
Old 10-07-2008, 10:43 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I tried to use EJ22 cam sprockets on my EJ25 SOHC heads, they dont work, well the driver side will, but not the pass. side. You need to use the EJ25 SOHC pass. side sprocket. I just bought both off ebay and called it good.
IIRC, the cam sprocket bolt torque is 56 ft lbs. If you search for "cam bolt specs" or "head bolt specs" the number should be in one of those two threads.
As for the block, hell I couldnt tell it was an EJ22T just by looking at the front...
~Josh~
Old 10-08-2008, 03:55 PM   #6
parkes
Member#: 166898
1994 T leg SS
ABM
~Josh~
Thanks, Yes i just swapped Drivers Side ones.
Did you do that to solve your Cam gear sensor problem? and did it?
Old 10-22-2008, 08:15 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
For future reference, if you are having trouble loosening the cam gear bolts use an old timing belt and some vice grips, wrap the belt around the pulley then around the crank and vice grip the belt together. It's a perfect "chain wrench" and if done right can even withstand an impact gun.
AT&T versus Verizon - why is one better than the other? somebody else Off-Topic 57 03-30-2010 02:51 AM
Are rod/main bearings all the same or is one brand better then the other? lotus2843 Service & Maintenance 0 01-05-2005 12:14 AM
can a relationship work if one person drinks and the other does not? phillywrx Off-Topic 28 05-06-2004 02:12 PM
prodrive or eibach, why is one linear and the other progressive? tuan phan Brakes, Steering & Suspension 38 04-16-2003 02:06 PM
Why is one PIAA XT80 brighter than the other? OBSS Interior & Exterior Modification 3 01-22-2001 10:20 PM
