Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 10-04-2008, 11:57 PM   #1
Kaldar142
Member#: 151090
S197 boosted V8 FTW
Default which gaskets for hybrid?
Hey guys,
i'm gathering all the parts for my hybrid build and i was wondering which gaskets i need for the hybrid setup?
i want to replace everything with new gaskets so which ones do i need?
also what thickness HG do i want?
-Joe
Kaldar142 is offline   Reply With Quote
Old 10-05-2008, 12:24 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Well there are a variety of options out there. I am assuming youi are using a 2.5 block and 2 liter heads? The biggest factor is of course the thickness. The thinner, the more complications that can occur, from higher compression, to valves touching the pistons...
Personally I have been sticking with the thicker metal NA three plys and had no problems, other than a lower compression.
Old 10-05-2008, 04:36 AM   #3
Kaldar142
Member#: 151090
S197 boosted V8 FTW
yes, what about the STi oem headgasket? with 2.0l wrx heads
Old 10-05-2008, 11:15 AM   #4
rainwrx
Member#: 68955
2005 WRX Hybrid
Needs Paint
I'd recommend the oem STi head gasket. In fact, get the entire engine gasket set for an STi 2.5 engine. In addition, you'll need 2.0 valve cover gaskets and 2.0 1/2 moon gaskets (set of 4) for the 2.0 heads.
This is what I've used with my hybrid...
rainwrx is offline   Reply With Quote
Old 10-19-2008, 01:39 AM   #5
Kaldar142
Member#: 151090
S197 boosted V8 FTW
hey guys, i lost the list i made for all the pieces i needed for my hybrid build......
what gaskets do i need, what parts do i need... etc?
Old 10-19-2008, 02:28 AM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Interested in this thread as well. Lower compression or stronger head gasket. Or can you have both?
Old 10-19-2008, 06:26 AM   #7
jamal
Member#: 71875
98 2.5GT
my wheels fit
the new 2.5 n/a and turbo gaskets are identical except for thickness. Although actually there are three 2.5 turbo gaskets now. The 07 and 08 sti each have their own different ones. Stick with the 06 and earlier gaskets.
jamal is offline   Reply With Quote
Old 10-19-2008, 10:17 AM   #8
m3joe46
Member#: 139622
2006 WRB
400 WHP Wagon
anyone know which is the thickest??
m3joe46 is offline   Reply With Quote
Old 10-21-2008, 04:04 AM   #9
Kaldar142
Member#: 151090
S197 boosted V8 FTW
anyone???
Old 10-21-2008, 09:41 AM   #10
suberdave
Member#: 101865
88 GL-10 STi
the N/A 2.5l Phase 1 is 1.52mm thick C/R should be ~ 8.24:1
the N/A 2.5l Phase 2 is 0.58mm thick C/R should be ~ 8.93:1
the turbo STI 2.5l 04-06 is 0.6mm thick C/R should be ~ 8.91:1
all info taken from Matt's Compression Ratio Calculator
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 10-21-2008, 10:04 AM   #11
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Now what is the best gasket? As I read some stuff about people blowing other then sti head gaskets. I don't know about anyone else but I dont want to do this more then once.
Old 10-21-2008, 05:15 PM   #12
rainwrx
Member#: 68955
2005 WRX Hybrid
Needs Paint
It was recommended to me by several engine builders and tuners to go with the OEM STi head gaskets. Yes, your compression will be a bit higher with stock pistons, but that is not a problem and can be tuned just fine.
My hybrid with CP pistons (stock CR) and OEM STi head gaskets runs great. Right now I'm running an 18g @20psi with no problems and am now looking at a dominator 3 turbo. I anticipate no issues with that either.
Old 10-21-2008, 06:40 PM   #13
Kaldar142
Member#: 151090
S197 boosted V8 FTW
Which gasket set do i need though?
i'm asking what parts do i need to do a full hybrid swap;
oil pump
water pump
wrx overhaul gasket set
STi headgasket
thermostat
what else do i need or is that it?
Old 10-21-2008, 07:45 PM   #14
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Go here... Tristan can hook you up (thekingofparts - NOT associated with kingpin)
http://www.5-starperformance.com/ser...ock-%26/Detail
This is what you want... They have it all packaged together.
I think the only thing else you'll need are new headbolts... but that is all in the eye of the beholder.
paintbing is offline   Reply With Quote
Old 10-21-2008, 08:07 PM   #15
Kaldar142
Member#: 151090
S197 boosted V8 FTW
i was going to use ARP headstuds instead
Old 10-22-2008, 12:15 AM   #16
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Tuner told me oem if staying around 400 whp
Which gasket set for hybrid block swap? 240sxguy Built Motor Discussion 2 11-25-2009 02:52 PM
Need gaskets for hybrid. perrin247 Built Motor Discussion 11 10-18-2007 10:53 PM
Cometic Gasket for hybrid swap k_thaosta Private 'Wanted' Classifieds 8 03-28-2006 10:49 AM
head gaskets for a 2.5/2.2 hybrid?? subaru932001 Subaru Conversions 5 02-28-2006 09:36 AM
