Old 10-05-2008, 01:36 AM   #1
acidrain088
Member#: 130973
Default gd steering rack in a gc
will this work. my steering rack is going, getting a little sracy but ive got a gd from a bugeye wrx laying around. wondering if this will just bolt up into a gc impreza?
acidrain088 is offline   Reply With Quote
Old 10-05-2008, 06:52 PM   #2
kingston
Member#: 25079
1987 Subaru GL
rust blue
i've heard it does...anyone care to confirm?
kingston is offline   Reply With Quote
Old 10-05-2008, 07:15 PM   #3
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
it will bolt up.
But it will not bolt to your GC steering column. Unless you have both GD and GC steering coupler and cut and weld them back together.
I just used a GC steering column and have no problems.
circaisdashiat is offline   Reply With Quote
Old 10-05-2008, 07:17 PM   #4
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
i also have a GD dash and beam...
So im not sure if a GC steering column will bolt to the GC dash beam. I know it would not have in my MY1995. Not sure in later years.
Old 10-05-2008, 08:35 PM   #5
silentt
Member#: 119995
2004 Outback XT
Peachy
silentt is offline   Reply With Quote
Old 10-06-2008, 12:52 PM   #6
sense of nature
Member#: 112759
02 Srp STi...Yup!
R ur Boltz to long????
Originally Posted by silentt View Post
^^ did it works just fine !
sense of nature is offline   Reply With Quote
Old 10-06-2008, 01:39 PM   #7
silentt
Member#: 119995
2004 Outback XT
Peachy
As did I. Swapping a piece of the linkage >>>> welding the linkage. Easier and safer.
Old 10-06-2008, 03:10 PM   #8
rdodger
Member#: 156447
99 18g'd 2.5RS-T
Meh, the way it is designed those u-joints were never meant to be spread then recrimped, and though very unlikly they might fail when messed with. I rewelded mine because its faster and easier than prying apart two u-joints, personally I think either way is fine but welding is faster and less of a PITA. And unless you've never welded in your life theres no way that low stress area will see weld breakage.
rdodger is offline   Reply With Quote
Old 10-06-2008, 04:02 PM   #9
kamilrs
Member#: 191072
Hi, I'm looking to swap 05 USDM sti steering rack into my 99 2.5 RS. Does anyone know if that will fit?
kamilrs is offline   Reply With Quote
Old 10-06-2008, 04:04 PM   #10
silentt
Member#: 119995
2004 Outback XT
Peachy
No, your car will implode
Old 10-06-2008, 04:08 PM   #11
kamilrs
Member#: 191072
Can you please explain what do you mean by that?
Old 10-06-2008, 06:16 PM   #12
silentt
Member#: 119995
2004 Outback XT
Peachy
The STI steering rack is much beefier than the RS steering rack. When you hit bumps, that extra energy is transferred to your steering column. Due to the use of a collapsable steering column in order for Subaru to attain higher crash test ratings, the steering column will much more readily collapse with the extra energy transferred to it via the STI steering rack. Once this happens, your steering column collapses and your steering wheel falls into the engine bay. This will then destroy your crossmember (once again, extra shock load) and will cause your engine to literally drop. It is being held on by the pitch stop mount, the intake and the various bits of wiring going to the engine. Once you remove those, the engine falls to the ground.
Now, with the crossmember destroyed, the structural integrity of the chassis becomes questionable and it has a tendency to collapse inward since there is not enough support from the middle of the vehicle. Over time, the actual frame of the car behind the engine bay starts to warp and twist inside. Once the steel becomes weak enough, it falls apart, where everything collapses inward, thus completing the implosion.
Old 10-06-2008, 09:03 PM   #13
kamilrs
Member#: 191072
Thanks for explanation. That sounds pretty scarry.
Old 10-06-2008, 11:50 PM   #14
silentt
Member#: 119995
2004 Outback XT
Peachy
You're welcome.
Old 10-08-2008, 02:34 AM   #15
JDiMpreza
Member#: 18707
2002 WRX Wagon
Platinum Silver Metallic
thats mean
JDiMpreza is offline   Reply With Quote
Old 10-08-2008, 03:44 PM   #16
sense of nature
Member#: 112759
02 Srp STi...Yup!
no welding necessary
just split the joint & press em back together like in the link u could weld but not really necessary
took a ttl of 15 min to complete just regrease the joint
Old 10-08-2008, 03:50 PM   #17
sense of nature
Member#: 112759
02 Srp STi...Yup!
extremely detailed , has this happened to u ?
Old 10-08-2008, 04:26 PM   #18
silentt
Member#: 119995
2004 Outback XT
Peachy
Originally Posted by JDiMpreza View Post
thats mean
That's what I said. Other people were saying to weld it, I disagreed and said it's easier to just swap that one piece (like we both did).
Old 10-09-2008, 07:52 AM   #19
Dan Cech
Member#: 67154
1997 Legacy GT/WRX
Glad my method is working out for you! I still haven't had a chance to drive my car yet
Dan Cech is offline   Reply With Quote
Old 10-09-2008, 08:37 AM   #20
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Get the GD colum with the rack. That's what I'm doing after talking it over with my best parts and info swap source.
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 10-10-2008, 05:53 PM   #21
rdodger
Member#: 156447
99 18g'd 2.5RS-T
Haha I honestly laughed out loud, good job.
Old 10-10-2008, 08:17 PM   #22
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
is sti steering rack better? i'm thinking of getting sti donor, swap the rack, column(imobolizer ), i already have turbo x member ej20g ftl......
slava from goshen is offline   Reply With Quote
Old 10-11-2008, 08:15 AM   #23
Dan Cech
Member#: 67154
1997 Legacy GT/WRX
Yes, the STi rack has a faster ratio (15:1) than the WRX rack (16.5:1).
You won't need to swap the column if you modify your steering linkage as above.
Anyone who's swaped a wrx steering rack in their GC, I have some questions scobaru Subaru Conversions 9 04-18-2007 08:48 PM
GD seat belts in a GC? sheepdog Interior & Exterior Modification 2 04-18-2007 01:09 PM
Will this fit: 04+ STi steering rack in '00 GC? nytoy Brakes, Steering & Suspension 1 10-11-2006 11:59 PM
GD Suspention peices in a GC? Wayne_Coots Subaru Conversions 18 02-01-2005 05:49 AM
GD door Panels in a GC quietgiroth Interior & Exterior Modification 5 12-25-2003 10:29 PM
Message Board Statistics All times are GMT -4. The time now is 07:03 AM.
