Old 10-06-2008, 11:03 AM   #1
jblackwell
Member#: 190324
2004 STI
World Rally Blue
Question WRX 2.0 heads on STi bottom end... Compression?
OK,
I can not find any source for a comparison between the combustion chamber volume of the 2.0 WRX head and the 2.5 STi head. The engine is assembled and the cylinder pressure is in the mid to high 170's. 173 to 178 was the spread from low to high.
Anyhow, does anyone have any idea what the compression ratio is with this combination? I'm currently contemplating tearing it apart and throwing STi heads on the motor if I'm in the mid 9's with compression.
Anyone?
jblackwell is offline   Reply With Quote
Old 10-06-2008, 11:47 AM   #2
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Originally Posted by jblackwell View Post
OK,
Anyone?
This has been covered at length in the 2.5L forums over the last 5 years.
To help out, take a look at the following:
Then read some of these threads:
http://forums.nasioc.com/forums/show...1594587&page=2
http://forums.nasioc.com/forums/show....php?t=1547876
Also, if you search for post in the 2.5L forum dealing with WRX heads and EJ257 you will find a plethora of examples.
To more directly answer your question, indeed the compression is higher. The estimate from the chart above is 8.87, but if the heads were surfaced at all, it would be higher. Also, if you used an aftermarket piston that is slightly lower in dish it would be even higher. Your should also be considerate of the difference between the WRX and STI cams.
Cheers,
Jeff Sponaugle
Surgeline Tuning
sponaugle is offline   Reply With Quote
Old 10-23-2008, 08:33 PM   #3
aaronthehic
Member#: 41577
2000 impreza rs
i ran both a 2.5 sti block with cometic 3mm gasket and a stock sti and prefer the stock sti gasket
18psi on v5 head
stock gasket ran smother and more responsive
aaronthehic is offline   Reply With Quote
STI cams in 2.0 heads on 2.0 block? OUScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-06-2010 10:05 PM
WRX 2.0 heads on STi bottom end... Compression? jblackwell Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-07-2008 11:53 AM
2.0 heads on sti block crpwrx Subaru Conversions 8 09-28-2008 07:55 PM
2.5i heads with EJ257 bottom end Boosted WRX STi Normally Aspirated with bolt-on Forced Induction Powertrain 14 09-05-2008 08:32 AM
USDM 2.0 heads on a USDM STi Block? NicktheBrit Built Motor Discussion 5 03-06-2008 04:11 PM
