Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 10-06-2008, 10:55 PM   #1
knighter
Member#: 161913
2006 WRX TR
Steel Gray Metallic
Question I need some info on the 18x9 +35 offset rota g-forces or like rims/tire setups
im having issues with fitting these rims. i have 245/45/18's and their too tall. I rolled my fenders and i still have rubbing issues in the back when i hit bumps. Im saving to buy coilovers but im not sure which ones yet. im looking into getting 255/35/18's tires if they will clear the coilovers. I just want to know if anyone has a setup similar on there car and what they did to make it fit. what size tires they have, camber, coilovers and pics, etc. thanks for all your help. I just want make sure what i go with will work before i spend the money.
knighter is offline   Reply With Quote
Old 10-06-2008, 11:16 PM   #2
BlKsUbYkId
Member#: 92728
2013 370Z Nismo
I recently ordered mine. Im running KYB AGX's set to 4 (fullstiffness) with Tein H-Techs. If you havent already try to get your hands on some H&R camber bolts whihc allow you to change from +/-3 degrees, i believe. But I order 235/40/18 tires. If your not geting coilovers soon try pulling your fenders a bit. Good Luck
-Artie
BlKsUbYkId is offline   Reply With Quote
Old 10-07-2008, 01:06 AM   #3
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
You are having issues because your tire size is not correct. A 245/45/18 tire is extremely tall and will cause all sorts of rubbing issues, incorrect speedometer readings, slower acceleration, etc.. The recommend tire for these wheels on a relatively stock bodied WRX would be a 235/40/18 or 255/35/18.
You will have no strut clearance issues with a 255/35/18 tire, there will be plenty of room
-Dan
suby_dude is offline   Reply With Quote
Old 10-07-2008, 01:59 AM   #4
howfast?
Member#: 102027
BugI Tsx retro lamps
for sale not listed pm me
Subaru Stars
-Dan
yea lowered on that size wheel, a 45 series tire is way too tall. Max would be a 245/40 or preferrably like suby_dude said a 255/35. Super stretch would be a 225/40 but thats only for certain people and not necessarily recommended.
Besides, you have the baller wheels you need to mount the low-pro tires to set them off!
howfast? is offline   Reply With Quote
Old 10-07-2008, 04:26 PM   #5
knighter
Member#: 161913
2006 WRX TR
Steel Gray Metallic
-Dan
thats what i needed to hear i was worried about the coilover clearance. i just ordered a set of Stance GR+ Pro coilovers so im hopeing that the smaller coilovers will give me clearence to run the 255/35/18's. im looking the nexen n 3000's.
Old 10-09-2008, 08:57 PM   #6
knighter
Member#: 161913
2006 WRX TR
Steel Gray Metallic
bump for more help
Old 10-10-2008, 04:07 PM   #7
retroXvertigo
Member#: 118922
2007 Doggy Doo
Sno-cone
This is a great page to figure out wheel clearances and what not.
http://www.bigcustomwheels.com/info_specs.jsp
There are a few pages that are very much like this one.
retroXvertigo is offline   Reply With Quote
Old 10-10-2008, 05:25 PM   #8
scoobydoo33
Member#: 152860
2007 WRX Wagon
-Dan
so would a set of 18x9 g-forces fit on a stock 2007 wagon with 235/40/18
im in the same boat and would rather get the rims on now snd then the coilovers
scoobydoo33 is offline   Reply With Quote
Old 10-10-2008, 05:48 PM   #9
suby_dude
Member#: 17397
WRB, White
These wheels will not fit a stock wagon, they require some modification to the car to fit as it's a very aggressive wheel.
Here's a customers wagon with 18x9 +35 Steel Grey G-Force's and 235/40/18 tires
This wagon is very low and he has slight rubbing. His car does have coilovers and his front fenders are rolled, rears are slightly rolled. He still need to dial in some more negative camber in the rear which will fix the rubbing issue.
If you wagon is stock I would not attempt to run these wheels. They require rolled fenders and negative camber to fit, even with a smaller 235/40/18 tire.
-Dan
Old 10-10-2008, 08:14 PM   #10
knighter
Member#: 161913
2006 WRX TR
Steel Gray Metallic
thanks this will help out a great deal
FS: 18x9 +35 5x100 Rota G-Force Gunmetal ohxietviet Wheels/Tires 11 01-08-2010 01:26 PM
FS/T: 18x9 +35 5x100 Rota G-Force Gunmetal ohxietviet TXIC Private Classifieds 17 01-07-2010 02:56 PM
FS: 18x9 +35 5x100 Rota G forces in steel grey bObby SWIC Private Classifieds 5 11-06-2008 03:41 PM
I need some info on the 18x9 +35 offset rota g-forces or like rims/tire setups knighter Tire & Wheel 2 10-10-2008 01:30 AM
Utah/SLC Skiers...Need some Info on the Bar Scene REX8 Rocky Mountains Impreza Club Forum -- RMIC 14 12-15-2006 09:50 PM
