Old 10-07-2008, 10:39 AM   #1
Cky47
Member#: 132652
Default Theft Attempt - Broken Door Handle
So I got out to my 2002 WRX today and someone had tried to punch the lock out of my door. The door handles clips are broken and the actual lock you stick the key into is pushed about an inch inside the door.
Is there an easy fix for this? I didnt want to try pulling the rest of the trim piece off that makes up the door handle (didnt want to break another clip).
Thanks guys.
The door still works fine and the alarm must have scared them off, so i guess I was lucky.
Cky47 is offline   Reply With Quote
Old 10-07-2008, 11:17 AM   #2
SGiTDD
Member#: 191035
I will 100% replace the entire lock (where the key goes in) because if you decide to use the same lock then it might become defective in a future then you never know if it will be easier for another theif to finish breaking it.
SGiTDD is offline   Reply With Quote
Old 10-07-2008, 11:42 AM   #3
2fas4u
Member#: 90691
2005 STI / 2009 STI
glad they didnt get the car! Maybe they got hit by a bus going by at the time!?
2fas4u is offline   Reply With Quote
Old 10-07-2008, 12:29 PM   #4
bjwk89
Member#: 175615
2005 STi
Black Stg. 2
+1 on replacing the lock, if anything at all is broken that just means it will be easier to get through next time.
bjwk89 is offline   Reply With Quote
Old 10-07-2008, 12:35 PM   #5
Brown's Mazda
Member#: 186428
05 Makin' cars
pretty
If the cylinder is ok, just replace any clips or rods that may have bent behind it.
Brown's Mazda is offline   Reply With Quote
Old 10-07-2008, 12:40 PM   #6
Cky47
Member#: 132652
Well the door still locks and unlocks fine, but what I was wondering is basically is it as easy as it looks or am I going to break something. Can I just pop off the door handle from outside. Or should I take off the door panel and unfasten stuff first. I tutorial on how to get the cylinder back in place would be GREAT.
Old 10-07-2008, 12:42 PM   #7
MIKE DD
Member#: 106818
2003 Truck
Good chance it just broke on it's own, mine did. Search, you're not the only one to have this happen.
MIKE DD is offline   Reply With Quote
Old 10-07-2008, 05:38 PM   #8
greenshoes3
Member#: 164049
MBP stg2 dom tuned
mine broke on its own, and I thought the same thing that you just did. Its just a bolt that comes loose, buy a new one, take door card off, replace, and all is good again.
greenshoes3 is offline   Reply With Quote
Old 10-07-2008, 05:45 PM   #9
TyroneBiggums
Member#: 191182
MBP
Yea, take the door card off. you gotta snake your arm up the door sort of, so make sure you have the window open, and then the actually handle is only held in by two bolts. One of those bolts holds the locking cylinder in place.
TyroneBiggums is offline   Reply With Quote
Old 10-07-2008, 06:12 PM   #10
Xigent
Member#: 185701
PSM WRX
20G 2.5L
This is a known problem with WRXs, the lock falling into the door. Mine did it on it's own as well a few years ago. The trim on the door handle was loose after this happened but was easily fixed when the door was apart.
Xigent is offline   Reply With Quote
Old 10-07-2008, 06:20 PM   #11
JohnnyChimpo
Member#: 187411
If you buy one door lock cylinder you will have 2 different keys. 1 to start the car, open the trunk etc and one to open your drivers door. Subaru will have a master lock set and you will have to replace all lock cylinders on the vehicle- ignition, doors, trunk. Good luck man, I would just try and salvage the original. If it still works I would imagine it is repairable.
JohnnyChimpo is offline   Reply With Quote
Old 10-07-2008, 11:40 PM   #12
Cautionjump
Member#: 135459
Nope you buy a new cylinder, take your old cylinder down to dealership any they will key it for you.
Cautionjump is offline   Reply With Quote
2001 Legacy - Broken door handle kevinsUBARU Legacy Forum 3 04-08-2012 09:59 PM
door handle broken kswis001 Interior & Exterior Modification 3 02-18-2008 07:33 PM
WTT: WRX door handles + cash for your sti chrome door handles! D Money Interior/Dressup/Audio & Security 9 01-22-2007 03:16 PM
Broken Door Handle? joefocker20 Interior & Exterior Modification 3 03-25-2004 08:18 AM
Broken Door Handle! ImprezedRS General Forum Archive 7 01-12-2001 01:16 AM
