Old 10-07-2008, 10:10 AM   #1
Desi_drifter395
Member#: 154618
2007 Impreza WRX TR
Default Installing an ABS on/off switch on an 07 WRX
I've been searching EVERYWHERE for how to do this mod, and i know the basic procedure, but I cannot find the ABS fuse for the life of me... can someone please upload or send me clear pics with the fuse to pull circled? i know its probably a pain, but i would REALLY appreciate this. i have an 07 WRX (its a TR if that makes a difference...).
Oh just for reference, the site i've been using is this one (there's a link in the first post to another site that i went too as well). the pics are unclear to me, so maybe i'm being an idiot and just dont know where to look...:
http://www.clubwrx.net/forums/suspen...bs-switch.html
thanks!
Desi_drifter395 is offline   Reply With Quote
Old 10-07-2008, 10:41 AM   #2
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
check your manual...
gto7419 is offline   Reply With Quote
Old 10-07-2008, 03:24 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
The fuse panel by your left knee. There is an ABS fuse. That's it...
Old 10-07-2008, 03:30 PM   #4
Desi_drifter395
Member#: 154618
2007 Impreza WRX TR
durrr.... XD
i should have checked the manual first... but i did just now for the fuse panel behind the coin tray, and fuse 8 is a 20A fuse for the "ABS Solenoid"
is that the one i need to pull?
thanks, and sorry for being such a noob =P
Old 10-07-2008, 03:36 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Yep, that's it.
Old 10-07-2008, 03:47 PM   #6
Desi_drifter395
Member#: 154618
2007 Impreza WRX TR
okay excellent!
so now that i've found that fuse, i just use those male connectors and the in-line fuse box and the switch, and its easy as that?
Old 10-08-2008, 12:34 AM   #7
sleepyfu
Member#: 124219
2004 W(agon)RX
sounds right to me.
starts from one side of the fuse slot ->
one leg of the switch -
switch -
out to one leg of the new in-line fuse -
fuse -
out to the other leg the oem fuse slot.
the position of the switch and fuse can be swapped of course.
sleepyfu is offline   Reply With Quote
Old 10-08-2008, 10:31 AM   #8
leecea
Member#: 37359
2003 WRX
I saw some threads years ago where people were wondering what an insurance company would do if you had an accident and their inspector saw something like this installed. Just an FYI...
leecea is offline   Reply With Quote
Old 10-08-2008, 10:54 AM   #9
Desi_drifter395
Member#: 154618
2007 Impreza WRX TR
argh im having some trouble fitting the switch in, but thats my problem, i can fix it pretty easily. what is more pressing is, what exactly do i need to get that can fit in the slot where the fuse used to be, so i can run the wires out of there to the switch, fuse holder, and back?
oh leecea, thats a good point.... do you have any idea where the threads are or any key words to search for? but it seems like all you would have to do is put the fuse back in, and no one knows any better... but i'm using a covered switch for the abs, so when the cover is up, its gonna be off, and when its down its on...plus if i close the cover, the switch turns abs on too, seemed like a better idea than just a rocker switch or somethin
Old 10-08-2008, 12:21 PM   #10
shatteringstar
Member#: 149604
2006 Limited WRX
im sure im not the only one wondering this so...
whats the benefit? why would u want to do this "mod"?
i can only assume racing reasons, but i dont under the idea.
shatteringstar is offline   Reply With Quote
Old 10-08-2008, 12:46 PM   #11
ArcticWolf
Member#: 146732
2006 Impreza 2.5i
Obsidian Black Swirl
Loose surfaces, sometimes its better to lock them up.
Also racing, as you pointed out.
ArcticWolf is offline   Reply With Quote
Old 10-10-2008, 10:02 AM   #12
Desi_drifter395
Member#: 154618
2007 Impreza WRX TR
ARGH
what type of connector is supposed to fit in the slots where the fuse should go? the male connectors that they guy in the site uses DONT FIT.
HELP
ABS cut-off switch installation guide dant Brakes, Steering & Suspension 98 09-12-2009 01:47 AM
Question on rigging an Aquamist On/Off Switch scooterforever Water/Methanol Injection, Nitrous & Intercooler Cooling 4 07-05-2006 09:33 AM
Using the Dimmer as an ON/OFF switch for an LCD ?? Extraze Electrical & Lighting 2 08-09-2004 11:09 PM
ABS on/off switch? alacrity024 Brakes, Steering & Suspension 4 01-28-2004 05:34 PM
ABS on/off switch jamz New England Impreza Club Forum -- NESIC 23 01-31-2002 11:01 AM
