Old 10-07-2008, 10:20 PM   #1
greenemac2003
Member#: 38813
1999 RS ej20/stg2 AP
silverthorn
Default K guys done this before! Come and see my swap! Ur ideas?
Ok, guys... I've done the swap thing before and thought I would ask for your assistance and opinions for my next swap...Newbies welcome of course since I am still considered a newbie... Here's what I have so far... Got the wiring covered(no dash swap, just cut and solder) and the assembly, just need help in part selection. My budget is $6000 so help me out.
Just bought. 1999 RS WRB ($1700)
-Dis-assembled 2002 WRX engine (rod, main bearings damaged, fixed) from Conoval21 Sucker!!!
-ferrea valves
-wiseco pistons
-k1 technologies rods
-stock turbo
-91-91 legacy crossmember
-91-94 cusco legacy front swaybar
Need advice:
1-Engine management
2-Header
3-Up
4-Dp
5-Cat-back
6-Suspension
7-Rims and Tires
Ok, I'm sure I'll catch some criticism from this post, but I would like some real advise and criticism from u nasioc members. Thanks for your advise and your criticism, so have fun...
Your opinion...Need suggestions on these items (click image to see slideshow)
Here is a link to my previous 2.5 rs swap....
http://viewmorepics.myspace.com/inde...076&i=14912915
Last edited by greenemac2003; 10-08-2008 at 09:58 PM. Reason: removed combo behind header
greenemac2003 is offline   Reply With Quote
Old 10-07-2008, 10:57 PM   #2
oldhat
Member#: 113036
Originally Posted by greenemac2003 View Post
1-Engine management
2-Header combo
3-Up
4-Dp
5-Cat-back
6-Suspension
7-Rims and Tires
1. ECUTek
2. Bosal
3. Catless
4. Catless
5. Catless
6. KYB AGX + Ground Control springs or P1s
7. Whatever you like
oldhat is offline   Reply With Quote
Old 10-07-2008, 11:22 PM   #3
greenemac2003
Member#: 38813
silverthorn
Thanks Oldhat. #6 is a definite, 1. tru 5&7 up for grabs...
Old 10-08-2008, 01:00 AM   #4
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
this swap should be pretty sick keep us updated with lots of pics... how much did you snag the engine for if you don't mind me asking?
bugeye-brawler is offline   Reply With Quote
Old 10-08-2008, 01:19 AM   #5
greenemac2003
Member#: 38813
silverthorn
I bought this engine for $3200 from Conoval21 on this forum...I figured since he sh@t me on this engine 2005 I would rebuild, recycle. Thanks for the bump...
Old 10-08-2008, 01:21 AM   #6
greenemac2003
Member#: 38813
silverthorn
$3200 was including shipping from Cali...BTW...Suckssss! I'm Good Though...
Old 10-08-2008, 01:26 AM   #7
greenemac2003
Member#: 38813
silverthorn
Keep tha suggestions comin...thanks...
Old 10-08-2008, 01:41 AM   #8
silentt
Member#: 119995
2004 Outback XT
Peachy
1-Engine management - COBB AP -> Pretty much the same price as ECUTek but includes free tuning software if you want to try to self-tune or make tweaks to a map provided by your tuner.
2-Header combo - No idea
3-Up - Stock STI or GrimmSpeed
4-Dp - Maddad whisper TBE
5-Cat-back - See 4.
6-Suspension - KYB AGX (or GR2) with RCE Yellow springs
7-Rims and Tires - anything narrower than 8" wheels and 225 wide tires. 8" + 225 tires are a recipe for rubbing.
silentt is offline   Reply With Quote
Old 10-08-2008, 01:52 AM   #9
greenemac2003
Member#: 38813
silverthorn
Thanks silentt. Keepim comin...
Old 10-08-2008, 03:24 AM   #10
oldhat
Member#: 113036
I think your car's ECU should be a test mule for SubieSMART.
Stock STI headerback is the most baller you can get for the money, IMO. It would really help your WRX breathe. They sound nice, too.
Old 10-08-2008, 10:07 AM   #11
silentt
Member#: 119995
2004 Outback XT
Peachy
He's swapping... GD ECU >>>>> GC ECU.
Old 10-08-2008, 11:02 AM   #12
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
how the hell did you get a 99 RS for 1700?
Old 10-08-2008, 01:42 PM   #13
greenemac2003
Member#: 38813
silverthorn
This kid sold it to me with the engine in four pieces. The #4 piston is missing a chunk and the block needs a visit to the machine shop, it's salvageable. Overall the car is in great shape. The car needs a new front bumper and it could use a visit to Dent Wizard. All that will come after I get the motor in.
Old 10-08-2008, 01:44 PM   #14
greenemac2003
Member#: 38813
silverthorn
More pics coming, thanks for the ideas...
Old 10-08-2008, 03:06 PM   #15
sense of nature
Member#: 112759
02 Srp STi...
R ur Boltz to long????
1700.00 wtf ! Jealous !
sense of nature is offline   Reply With Quote
Old 10-08-2008, 03:26 PM   #16
greenemac2003
Member#: 38813
silverthorn
Yeah! $1700
Old 10-08-2008, 04:28 PM   #17
greenemac2003
Member#: 38813
silverthorn
Wuz wondering how many of u guys swapped in the entire WRX wiring harness, opposed to cutting what u need out of the WRX harness and splicing it into the RS harness? I prefer the second method. I'm sure both methods take just as much time...
Old 10-08-2008, 04:55 PM   #18
kheff46
Member#: 66739
2002 WRX wagon
i did a V4 Sti swap GC-GC and used entire JDM STi wiring harness. it was much faster and simpler this way. but GD to GC iirc under dash plugs are different. a WRX ECU would be easy to use if you went full GD wiring though.
i would use OEM everything to start with because 1) it's legos and it'll all fit, and it gives a good baseline/reference point for tuning, mods, etc.
--keith
and im jealous of the $1700 shell as well
kheff46 is offline   Reply With Quote
Old 10-08-2008, 09:15 PM   #19
greenemac2003
Member#: 38813
silverthorn
--keith
Na man, I leave the RS harness in place, cut the WRX ecu connectors, splice them into the RS harness and plug the WRX ecu in. Of course it's a little more complicated than that, but that's what I do...
Old 10-08-2008, 10:40 PM   #20
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
i did the second method but mine was in a 93 ..
honestly with a setup that good
do option #3
take both harness out and merge
Old 10-08-2008, 10:50 PM   #21
greenemac2003
Member#: 38813
silverthorn
Got pics of my previous RS swap under the blue RS. Take a look...
Old 10-09-2008, 09:54 AM   #22
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
your golden then
but back to your original question
i see NO reason to spend the extra $500 for an ecutek/AP tune go open source
i would also skip the headers and spend the $ on a turbo/injectors instead
Old 10-09-2008, 01:18 PM   #23
greenemac2003
Member#: 38813
silverthorn
Right Jaxx...Got of track.
What do u mean about open source tuning, I was leaning toward AP as before, but thought I would try something diff. I like the idea about forgoing the headers and going for turbo and inj. So I sould look for catless oem sit header?
Old 10-09-2008, 01:29 PM   #24
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
openecu.org
romraider.com
like ecutek ... except that its a $90 cable many tuners are supporting it now
Old 10-09-2008, 01:36 PM   #25
DerrickRH
Member#: 75078
2000 Legacy GT
Black Granite Pearl
awesome build for the money
DerrickRH is offline   Reply With Quote
everyone come out and see my new band (Bjork cover band) pjhe Off-Topic 14 01-08-2008 11:16 PM
My SWAP! Come and see!!!!!!!!! greenemac2003 Subaru Conversions 96 01-22-2007 10:20 PM
has anyone done this before me? AWD>FWD Interior & Exterior Modification 27 01-03-2007 11:52 AM
Cabinet refacing. Anyone done this before? Snoopy Off-Topic 9 09-16-2006 09:42 AM
anyone had done this before? Hojai Transmission (AT/MT) & Driveline 7 08-20-2002 03:43 PM
Message Board Statistics All times are GMT -4. The time now is 02:20 AM.
