#201 |
Member#: 4419
Vehicle:2002 S2K - 2003 FXS i don't have a wrx |
read all posts/first question
what search engines to you use to find all these answers on the internet? mark
#202 |
Member#: 13772
RMIC
Vehicle:93 legacy wagon |
In relation to a thread a couple days ago, or maybe last week about the human hearding instinct...
Why are most people so stupid that they can't overcome that instinct? For example, when leaving a movie theater. There are 2 doors in which to exit, yet almost everytime people will wait in a single file line to exit through only one door in which everyone else is leaving? And on another one no human stupidity - why is that whenever an elevator door opens (the person waiting for the elevator always assumes they are the only person who could possibly be wanting to use that elevator) they always instantly try to enter the elevator? Not thinking that before they enter, some people may need/want to get off the elevator before that person can get on the elevator? |
#203 | |
Member#: 7719
Vehicle:You are my new best friend, can I come over? |
#204 | |
Member#: 7719
#205 | |
Member#: 7719
Answer to the first: People are lemmings. Answer to the second: People are rude and selfish Most people follow others because it is the simplest thing to do. They don't have to think or make their own decisions. Some of it also is because people don't like to "break out" and be considered a rogue or independent, to take a risk means the possibility of being wrong (like if they try to go through the other door marked Exit only to find it bolted and locked). On the second, most people that stand in an elevator stand off to one side and therefore aren't seen when the doors start to open and the reaction is for the person coming on to start walking in. However, people should be courteous and apologize and let the person(s) off the elevator first. |
#206 | |
Member#: 4419
mark |
#207 |
Member#: 13967
SCIC
Vehicle:I I can fit in with the "Cool" OT crowd! |
You mean disestablishmentarianism????
I know that withought searching... some people DO know a few pieces of useless trivia... ![]() |
#208 | |
I like to beat on n00bs
Moderator Member#: 10648
NESIC
Vehicle:2005 Civic Bling Black & salt/pollen |
Glass is clear for the same reason water is clear. It can't absorb visible light. The light passes through it and is on its merry way. It also refracts light the same way glass does, only to a different degree. The speed of light decreases as it passes through certain objects. That is what causes diffraction. Fun fact about glass: its not a "liquid" like most people try to tell you. they only want to sound smart and get with your girlfriend. Its an "amorphous solid." that's a solid with no crystalline structure. watch your girlfriend if "that guy" reads this thread. -IggDawg |
#209 | |
NESIC
![]() -IggDawg |
#210 |
What's the MINIMUM about of helium that's required to lift 250 lbs off the ground?
--kC |
#211 | |
Member#: 7719
#212 |
Member#: 6654
Vehicle:2006 Odyssey 2006 Prius |
Find the difference in density of helium & air at sea-level and some temerature. Then you should be able to calculate the volume of helium needed to lift x amount of weight.
PV = nRT D = n/V D = P/RT Dry Air - R = 278 25% helium/75% air - R = 760 P = 101325 Pa at sea level T = 22C = 295.15 K D(air) = 1.235 Kg/m^3 D(He/air) = 0.452 Kg/m^3 Difference = 0.783 Kg/m^3 250 lbs = 113.64 Kg Volume of Helium/Air mixture = 113.64 / 0.783 = 1451 m^3 Obviously, a larger % helium gas would have a higher R value which would lower the volume needed. Temperature and pressure will also effect this number. |
#213 |
Member#: 20684
Why is poo brown?
#214 |
Pooptastic
Why is it that as soon as I have a beer, my contacts start to dry out... a LOT! I mean, if I drink a lot of beer, I can understand dehydration. But even after one beer, as soon as I get up to walk around, the wind from walking just dries out my eyes (and contact lenses) almost immediately. It sucks.
#215 | |
Member#: 7719
#216 |
Member#: 17430
Vehicle:2002 WRX Sedona Red Pearl |
How about an answer to Dr Goosey's "Eyebrow" question?
#217 |
Member#: 6780
South East
Vehicle:1993 Nissan |
What does sempai mean? It's a romanji for a japanese word...I've been trying to figure out what it means.
#218 | |
Member#: 7719
Seriously, I think your eyes naturally dehydrate quicker than what you consider dehydration. Your body probably just starts to work on things quicker. Dr. Igg? |
#219 | |
Member#: 7719
kohai is the opposite of it and means something like lesser/lower it's like a senior in high school is the sempai of a sophomore. |
#220 | |
Member#: 6780
South East
#221 |
NESIC
JGard - Alchohol dehydrates every part of you. That's what a hangover is after all. dehydration. Most of the parts of your body get water directly. Your eyes are only hydrated when you blink. There are no blood vessels in your cornea (unless you have been wearing contacts for several years. Yourblood vessels begin to encroach into your cornea). That part of your body depends on you blinking to be washed over with water. If your whole body isn't getting the normal amount of water, including the underside of your eyelids, then its difficult for your eyes to stay hydrated. Every time you blink when you're drinking your eyes are getting less water than they're used to. On top of that, there are probably people smoking around too, and the smoke is compounding the effect.
-IggDawg |
#222 | |
Member#: 15947
Vehicle:91 RX-7 Brave Blue |
#223 | |
NESIC
-IggDawg |
#224 |
Member#: 15947
how do razzles turn from a candy into a gum?
#225 |
Member#: 20684
I am still waiting on an answer to my question.
