Old 10-08-2008, 05:26 AM   #1
Mobius118
Member#: 159098
2005 LGT Ltd 5AT OBP
2003 WRX Stg4 PSM- RIP
Default Spark plug recommendations?
My bugeye has been suffering from some misfiring for a few months, and I'm thinking that the likely cause is the spark plugs, which have yet to be changed after 74,000 miles. Most of my buddies who tune and maintain cars have recommended NGK plugs. I was looking at the Iridium IX or G-power platinum. Does anybody have anything good or bad to say about these?
Also, equally important- should I be keeping the stock heat range or going one step colder. I know that the general rule is about ~75hp for one step colder. I'm at COBB Stg.2 minus an aftermarket uppipe with plans for VF-39 and STi TMIC later on. Is this enough to go one step colder or is it unecessary?
Thanks!
Mobius118 is offline   Reply With Quote
Old 10-08-2008, 06:16 AM   #2
hotrod
Member#: 14141
2002 Impreza WRX
Have you already read the spark plug FAQ listed at the top of this forum?
http://forums.nasioc.com/forums/show...postid=5927874
Larry
hotrod is offline   Reply With Quote
Old 10-08-2008, 06:46 AM   #3
Mobius118
Member#: 159098
Yup, I did read the FAQ but I just needed a little bit of extra information to make sure I'm making a good decision. No point in giving up money towards anything if you're not sure that it's right in the first place.
Old 10-08-2008, 07:47 AM   #4
hotrod
Member#: 14141
2002 Impreza WRX
Good, there are quite a few threads where this is discussed, but bottom line is that Platinum and Irridium plugs exist to improve emissions and have essentially no effect on performance. A working plug is a working plug as far as resolving issues like a chronic miss.
Spend $1.89 each for a set of garden variety plugs, gap them to 0.029 and see if they solve the problem. If not the problem is not the plugs. If yes and you don't want to replace plugs every 20,000 miles pick up some platinum or irridium plugs and put them in there. Their only significant advantage is they have very little electrode wear and can be left in for extended change intervals.
Heat range --- the plugs tell you what heat range you need. Read the cheap plugs you put in there for how far the heat discoloration band moves down the ground electrode. If they discolor more than 1/8 inch down the ground electrode you need to go a step colder.
http://www.empirenet.com/pkelley2/sparkplugreading.html
Larry
Spark plug recommendations STL WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-09-2008 02:54 PM
Spark Plug Recommendations...? StiNV76 Newbies & FAQs 5 05-18-2007 06:37 PM
spark plug recommendation attitude Service & Maintenance 8 01-12-2005 10:23 PM
Spark Plug recommendations for running N20?? AustinSTi Normally Aspirated Powertrain 14 03-01-2003 04:54 PM
What spark plug do you recommend for 2000 RS? Longitude Service & Maintenance 4 04-23-2002 11:04 PM
