Old 10-08-2008, 10:16 AM   #1
nismo4life
Member#: 118317
Default WRX swap into GD 2.5 TS
Just have a few questions. I've been considering doing an STi swap but I saw wrinkleboi's swap thread and theres ALOT involved, like abs module, brake lines, door harnesses, etc.
If I do a WRX swap, preferably a 06-07 does anyone know if the ABS and brake lines are the same?
Is all I have to swap out the motor/harness/trans?
Or do the hubs/axles/rear diff need to be swapped out as well as every single bit of wiring harness throughout the entire car?
nismo4life is offline   Reply With Quote
Old 10-08-2008, 11:03 AM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
you will have to swap EVERYTHING except the shell
Old 10-08-2008, 03:53 PM   #3
nismo4life
Member#: 118317
Everything needs to be swapped for a straight up WRX swap? Might as well do an STi swap then.
2.0T swap into 01 2.5 RS EJ0626 Factory 2.0L Turbo Powertrain 3 11-29-2007 05:53 PM
2.0T swap into 01 2.5 RS EJ0626 Factory 2.5L Turbo Powertrain 2 11-29-2007 12:53 PM
USDM EJ205 swap into '99 2.5 RS beaun-nus Subaru Conversions 10 12-22-2006 03:53 PM
semi newb-wrx longblock into 99 2.5 Tigris Normally Aspirated with bolt-on Forced Induction Powertrain 2 11-14-2005 10:58 PM
WRX Wagon wheel for 2.5 TS Special Delivery General Community 2 01-08-2004 05:28 AM
Message Board Statistics All times are GMT -4. The time now is 11:43 AM.
