Old 10-09-2008, 04:09 PM   #1
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
Default burning smell coming from my wife's forester...
coolant and oil levels are fine...haven't checked the AT fluid yet. car idles a tad shaky, doesn't really smell until well after the engine has warmed up...to me it smells like burnt celery if that makes sense...i haven't noticed any leaks from the car although i haven't crawled all the way under yet.
any thoughts? thanks.
doubledribble is offline   Reply With Quote
Old 10-09-2008, 05:08 PM   #2
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Sounds like you have a leaking CV boot. The grease from the boot is likely leaking onto the exhaust causing the burning smell. It is probably the passenger side inner boot.
You should be able to see it if you look thru the engine bay down onto the axle. Follow the axle to where it meets the transmission. You will see a rubber boot and should see the grease on the axle.
RexyGirl is offline   Reply With Quote
Old 10-10-2008, 09:57 AM   #3
doubledribble
Member#: 42912
2003 Outback Sport
i just had the whole passenger side axle replaced last spring...i'll double check to see if it's going again...
Old 10-10-2008, 10:35 AM   #4
RexyGirl
Member#: 63616
with mods :)
You need to also take into account mileage, not just time. Some people can go 50,000 miles in a year.
You need to also check and make sure it was done correctly and a part did not fail. It's possible
Old 10-10-2008, 02:23 PM   #5
doubledribble
Member#: 42912
2003 Outback Sport
hopefully it did not fail, car has only been driven about 10k since then, service was done at the dealership. i'll check when i get home.
Old 10-10-2008, 02:50 PM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Get under there and take a look. It could be PS fluid or anything else that got loose or found it's way under there.
Old 10-10-2008, 04:42 PM   #7
dumbass
Member#: 56653
2009 Forester
It might not even be a car problem. I had a plastic bag go underneath my car, and get stuck to the exhaust. Stunk like crazy!
dumbass is offline   Reply With Quote
Weird Moaning noise coming from my front right axle area...? Flyin_Hayn Transmission (AT/MT) & Driveline 2 06-05-2010 02:50 PM
Newb Question: Smells like gas coming from my vents AceTical Newbies & FAQs 4 03-14-2006 07:38 PM
smell of gasoline coming from my subaru mkssubaruwrx Southern California Impreza Club Forum -- SCIC 7 12-26-2004 11:48 PM
Need Help, burning smell coming from my engine willguidry New England Impreza Club Forum -- NESIC 14 06-19-2002 06:21 PM
awful smell coming from my exhaust the spacecowboy Normally Aspirated Powertrain 9 02-13-2001 12:19 AM
