Old 10-09-2008, 07:29 PM   #1
bouncing_soulz
Member#: 175427
2007 STi
UGM
Default Questions about upgrading to STi brakes
Ok, I looked around for a while and Ive asked questions and I have decided on doing the 04 sti Brembo Brake upgrade for the wrx.
from what I understand I need to get -
1- Brembo Front Calipers
2- Brembo Front rotors
3- Brembo Rear Calipers
4- Rear rotors that have same diamater as STI rotor but smaller brake drum for the smaller wrx ebrake
5- Brake adapter so the rear calipers will fit
ok... so my questions now are...
where do i get this special rear rotor? (rallysportdirect recomended wrxbrakes.com and they didnt carry it from what I can tell)
and, I have been told by RallySportDirect.com that the Kartboy adapter only works on the 2 pot 06-07 WRX rear calipers NOT the brembo rear calipers? Can anyone confirm this?
Also... if the above is correct, I need to get the Brembo adapter, and the Brembo adapter only. Where can I find this? I have google'd and ebay'd and I am having no luck... maybe I am just dumb, but some classic Nasioc assistance would be much appreciated!
thanks a bunch in advance!
bouncing_soulz is offline   Reply With Quote
Old 10-09-2008, 07:54 PM   #2
gr8r rex
Member#: 155652
2002 PSM WRX
www.forced4s.com
There is a lot of info in the "brembo to wrx swap info STICKY" You should check there. Kartboy does make a bracket for it and WRXbrakes does carry the rotors. WRXbrakes sells them both, contact them to get all the info on anything else you need. The fronts are a direct bolt on from a 04-07 STI as long as you get 04 sti front rotors, and the areas need the bracket and the special rotors. I also would recommend SS lines/Fluids/good pads in addition to these (if you don`t have them already)
The Rotors from WRXbrakes made by DBA: DBA 2657 Rotor
gr8r rex is offline   Reply With Quote
Old 10-09-2008, 08:45 PM   #3
bouncing_soulz
Member#: 175427
2007 STi
UGM
I have the good fluids and good pads but i suspect the ss lines would be a good upgrade since im down there.
I contacted wrxbrakes and asked them what they think.
I think I lot of places sell this rotor and bracket but they dont come out and advertise that they do. I just need to talk to more people.
When I get the info Ill post where I found them.
Old 10-09-2008, 10:47 PM   #4
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Brake supersticky -> Brembo brake FAQ
Old 10-10-2008, 09:11 AM   #5
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
we're here!
I have the rotors -
Another load of brackets is 'on the way' from Mr Deadrick
-ken
KNS Brakes is offline   Reply With Quote
Old 10-10-2008, 11:07 AM   #6
gr8r rex
Member#: 155652
2002 PSM WRX
www.forced4s.com
WRX brakes... do you have a package or can you throw together a package for front and rear rotors/pads/brackets for WRX's? Or is there such a package currently?
Old 10-10-2008, 11:19 AM   #7
bouncing_soulz
Member#: 175427
2007 STi
UGM
or even just the rotors and brackets would be nice. thats what I am looking to get.
do you have prices on the rotors?
Questions about upgrading tires, wheels and brakes shqipo Tire & Wheel 6 11-20-2007 09:49 PM
Question about the 04 STI brakes 05redwrx Brakes, Steering & Suspension 10 05-04-2007 01:45 PM
Question about upgrading to STi Intercooler WikdRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-23-2006 10:27 AM
Upgrading to STi brake system anthony c. Interior & Exterior Modification 4 01-12-2006 09:23 PM
Question about GC8-WRX front brake upgrade Krelkor Brakes, Steering & Suspension 11 06-24-2004 08:19 PM
