Old 10-10-2008, 02:00 PM   #1
powerneedy
Member#: 161242
Default Wiring Guru's NEEDED!
Alright guys i have this 95 impreza that has a sti swap with the sti dash AND the sti wiring harness... everything has gone great except i need to know how to wire it in to the fuel pump to my 95 impreza walbro. i look at the service manuals for the car and its a mess and a headache to me. If some one could help me out that would be great
TIA
powerneedy is offline   Reply With Quote
Old 10-10-2008, 02:13 PM   #2
oldhat
Member#: 113036
Do you still have the rear harness? The 95 Impreza rear harness should basically snap into the STI front harness. Walbro wires into the rear harness no problem.
oldhat is offline   Reply With Quote
Old 10-10-2008, 02:41 PM   #3
silentt
Member#: 119995
2004 Outback XT
Peachy
Brydon has an WRX/STI swap wiring thread on here, it shows how to wire up the fuel pump controller to your NA harness. That should give you a head start on things.
silentt is offline   Reply With Quote
Old 10-10-2008, 04:59 PM   #4
powerneedy
Member#: 161242
is brydon his user name? i have tried to find somthing like this before but no luck... i will try again i guess...
also i never though of it that way i will see if it will plug in or at least repin/plug it
Old 10-12-2008, 02:46 PM   #5
suberdave
Member#: 101865
88 GL-10 STi
95 impreza dose not have a fuel pump controler, it just plugs right into the fuel pump.
they didnt get the FPC till 96.
should be a stright forward splice from the fuel pump relay to the ECU.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
All you wiring guru's merge! fx35 wiring dillema skingfreak Electrical & Lighting 15 06-27-2008 09:04 AM
Wiring Guru's.. Well, maybe not even Guru's. FederalAuditor Subaru Conversions 2 01-04-2005 05:55 PM
Cobb DIY EJ20 stroker Idea...Engine Guru's needed MomoWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-22-2004 06:41 PM
camera guru's need a macro lens for my D100 [email protected] Off-Topic 13 01-19-2004 09:34 PM
MT tranny guru's, need your comments.. kenchan Mid West Subaru Owners Club Forum -- MWSOC 4 06-06-2003 08:48 AM
