Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 10-10-2008, 03:09 PM   #1
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Default 2005 STi into 2006 WRX (pan questions)
I am going to swap a 2005 STi engine into a 2006 WRX.
Prior to that I am going to do the driveline swap (trans, rear end, brembos etc.)
When I do the engine swap it will be after I do a complete build on it and I am curios to know which oil pan I should use? The 2005 STi oil pan or the 2006 WRX pan?
I will most likely be staying with the stock 2006 headers when I install the engine so I am more concerned about oil cooler/heat exchanger clearance issues and things like that.
I know that either pan will fit the block and I know the 2006 WRX pan is a no brainer since the car is a 2006 WRX but is the 2005 STi pan going to work.clear everything?
Thanks
Team Scream is offline   Reply With Quote
Old 10-10-2008, 03:49 PM   #2
oldhat
Member#: 113036
Won't be legal in Cali if you go from 05 -> 06 chassis. Beware.
oldhat is offline   Reply With Quote
Old 10-10-2008, 06:21 PM   #3
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Im thinking it will be really hard for them to even know as long as I use the 2006 ECU and smog related items?
I will only use the long block portion of the engine in the swap.
For all intents and purposes it will still be a 2006 WRX with a 6 speed and Brembos.
Old 10-12-2008, 09:56 AM   #4
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
This will depend a lot on how much you are swapping over, the hard parts in the drive-train wont be an issue, you plan on going 5x114? the whole deal? Also depends on your goals, do u want to have 100% working DCCD? then you will need to move over the all the wiring, and the ECU, this is were in Cali it will start to get sticky *Possibly* depending on how they do the inspection your car will have the 05 ECU in it, with that cars VIN, not the best situation.
I would just swap everything in, use the WRX Ecu, then a good aftermarket DCCD controller.
Token-Negro is offline   Reply With Quote
Old 10-17-2008, 05:59 PM   #5
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Thats exactly what I am planning on doing "T-N" (love that handle by the way lol) I want to use the 05 heads however and as I understand it, there are air pump ports on the 06 heads and NOT on the 05 STi heads, so how do I handle that part of the smog crap?
So the question becomes, which oil pan to use and how do I address the differences in heads?
Thanks
Old 10-17-2008, 08:07 PM   #6
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
It will be less work to just use the 06 heads, and get the air pump block off plates, then have someone remove the codes via opensource or with a AP.
2005 6MT swapped into 2006 WRX Team Scream Subaru Conversions 4 11-15-2008 09:40 PM
2006 sti tranny into 2006 wrx renosubby Subaru Conversions 5 09-25-2007 02:32 PM
2005 sti into 2002 wrx coupe TylerC21 Subaru Conversions 1 01-20-2007 05:50 PM
2005 STi vs 2006 STI Blindsay06 Newbies & FAQs 6 09-12-2006 11:28 AM
2005 STi vs 2006 WRX exhaust, Difference? Bbasso Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 08-24-2006 12:49 PM
