Old 10-10-2008, 08:06 PM   #1
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
Default 00 emanage files
saw a thread/s a while back that had the emanage set up with jumpers and def files for certain cars.
Mostly looking for 2000 rs with td04/38mm EWG setup. Hard to get exact same files but something close to work from.
Wasn't sure if I needed to order the pressure sensor for the Emanage
Thanks
freeride is offline   Reply With Quote
Old 10-10-2008, 09:39 PM   #2
rdodger
Member#: 156447
99 18g'd 2.5RS-T
I'm running a really custom setup so I can't really send you files but yes you absolutely need the pressure sensor because you need to clamp the stock stuff at boost onset, and it quickly maxes out. Even more important for larger turbos plus far easier to tune from.
rdodger is offline   Reply With Quote
Old 10-11-2008, 11:35 AM   #3
#522
Member#: 2185
are you referring to this thread: http://forums.nasioc.com/forums/show....php?t=1575752 ?
i can send u what I am using. I got the original from master c. It has the right parameters to get the car up an running. you will need the Greddy MAP sensor to tune. I also recommend a wideband and an OBD II logger or scan tool that can monitor fuel trims in real time. I have been doing a lot of road tuning and I have learned a lot and will post some tips in the near future.
#522 is offline   Reply With Quote
Old 10-11-2008, 11:40 AM   #4
#522
Member#: 2185
Old 10-11-2008, 01:18 PM   #5
freeride
Member#: 49783
SRP/white
Wasn't the exact thread but that one does help out a lot. Thanks.
I had the Jumper one, but was looking more for engine def file like the F6A one mentioned in that thread to get it setup and running to tune from. I will take it to a shop to get tuned anyways but wanted the car to start and drive over to the shop.
:P
Just doing some wiring and then I can order the pressure sensor.
Old 10-11-2008, 03:08 PM   #6
freeride
Member#: 49783
SRP/white
if you can send me that orig base map that would be great so I can start to look it.
Heads hurting after sperating and marking out these emanage wires :P
Did you guys use this one to seperate the wires...i used this and tried to follow philsines writeup
JP1-(1-2)
JP2-(1-2)
JP3-(1-2)
JP4-(1-2)
JP5-(1-2)
JP6-(1-2)
JP7-(1-2)
JP8-(1-2)
JP9-(Open)
JP10-(Open or 2-3)
JP11-(Open)
JP12-(Open)
JP13-(Open **Do not tap this wire onto anything it will screw the factory ecu up**)
JP14-(Open **Do not tap this wire onto anything it will screw the factory ecu up**)
JP15-(1-2)
JP16-(you will not use this so what ever you want)
JP17-(you will not use this so what ever you want)
JP18-(Open)
JP19-(Open but you will probably not use this either)
JP20-(Open but you will probably not use this either)
Connector A:
Pin1 - (Ignition Input ch6 - Not used)
Pin2 - (Ignition Input ch5 - Not used)
Pin3 - (Ignition Input ch4 - Not used)
Pin4 - (Ignition Input ch2 - To ecu for cylinders 3/4)
Pin5 - (Ignition Input ch1 - To ecu for cylinders 1/2)
Pin6 - (Ignition Output ch6 - Not used)
Pin7 - (Ignition Input ch5 - Not used)
Pin8 - (Ignition Output ch4 - Not used)
Pin9 - (Ignition Output ch3 - Not used)
Pin10 - (Ignition Input ch3 - Not used)
Pin11 - (Ignition Output ch2 -To Ignitor for cylinders 3/4)
Pin12 - (Ignition Output ch1 -To Ignitor for cylinders 1/2)
Connector B:
Pin13 - (Not used)
Pin14 - (Not used)
Pin15 - (Airflow Input - To Map sensor signal)
Pin16 - (TPS - T'ed to tps signal wire)
Pin17 - (Injector Input Ch1 - To ECU for Injector 1)
Pin18 - (Injector Input Ch2 - To ECU for Injector 2)
Pin19 - (Injector Input Ch3 - To ECU for Injector 3)
Pin20 - (Injector Input Ch4 - To ECU for Injector 4)
Pin21 - (Not used)
Pin22 - (Airflow Output - To Map sensor signal wire going to the ecu)
Pin23 - (Not used)
Pin24 - (Ground - T'ed ecu Power Ground)
Pin25 - (Ignition Power - T'ed to 12volt switched power)
Pin26 - (Not used)
Pin27 - (Not used)
Pin28 - (Not used)
Pin29 - (Not used)
Pin30 - (Injector Ground - T'ed to Injector Ground)
Connector C:
Pin31 - (Analog input signal - To Atmospheric pressure sensor)
Pin32 - (Not used)
Pin33 - (Not used)
Pin34 - (Injector Output Ch1 - To Injector 1)
Pin35 - (Injector Output Ch2 - To Injector 2)
Pin36 - (Injector Output Ch3 - To Injector 3)
Pin37 - (Analog Output signal - To ECU for Atmospheric pressure sensor)
Pin38 - (Not used)
Pin39 - (Not used)
Pin40 - (VSS Ouput - To ecu for vss)
Pin41 - (VSS Input - from vss sensor)
Pin42 - (Injector Output Ch4 - To Injector 4)
Pin43 - (Not used)
Pin44 - (Not used)
Things to know when setting up EMU:
RPM signal = Ignition signal
APS uppipe NIB 100.00 plus shipping 4wheeld Engine/Power/Exhaust 0 06-04-2010 11:33 AM
WA: 00 RS heads, emanage, flywheel, clutch, Apexi project_legacy 1993 - 2001 Impreza Specific Parts 12 10-01-2008 11:06 AM
FS: 00 RS stuff, heads, block, emanage, flywheels, clutch, exhaust, springs project_legacy NWIC Private Classifieds 9 04-16-2008 04:02 PM
Emanage Ultimate Engine Definition File for 00+ RS Hitokiri Normally Aspirated with bolt-on Forced Induction Powertrain 10 03-08-2006 07:16 PM
New Topic..who's using emanage on MY01-00. Tats Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-24-2005 08:03 PM
