Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-11-2008, 06:44 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Easy DIY compression test with pics!
Spent 45 min performing compression test with $25 compression tester today.
2002 WRX with 90k miles
Mods: VF34 @ 19psi protuned 282whp/272wtq
JDM STI TMIC
Maddad v2 DP & whisper catback
One step colder NGK platinum plugs
Stock intake with K&N panel filter
German castrol oil
1. Remove stock intake box, etc:
2. Remove 12mm bolt in order to remove coil pack from each cylinder:
3. Remove spark plugs using 5/8" long socket with an extension
4. Coil pack and spark plugs removed:
Old 10-11-2008, 06:44 PM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
5. Pull ignition fuse
- Fuse remover is located next to battery:
6. Connect compression tester into each cylinder:
7. Now it's time to crank the engine with wide open throttle. Crank the engine 6 times.
8. Repeat the test for each cylinder and pray numbers come out good:
Old 10-11-2008, 06:57 PM   #3
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
thanks!! will try soon
Jubert69 is offline   Reply With Quote
Old 10-11-2008, 07:02 PM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
You're welcome. Make sure to pray before performing a test!
One thing I forgot to mention is:
Make sure your car is warm when performing a test.
Old 10-11-2008, 07:41 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
you forgot a huge part.
throttle to the floor
sidewayz is offline   Reply With Quote
Old 10-11-2008, 07:43 PM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I mentioned above, ".... with wide open throttle..."
Old 10-11-2008, 07:47 PM   #7
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
why do you crank with the throttle down? What difference does it make?
Bad Noodle is offline   Reply With Quote
Old 10-11-2008, 07:52 PM   #8
jrobinson
Member#: 190786
Sedona Red
Im guessing so all the air can get in.
jrobinson is offline   Reply With Quote
Old 10-12-2008, 02:32 AM   #9
WRXDK
Member#: 187983
2005 WRX
Wouldn't you need to remove the fuel pump relay also?
WRXDK is offline   Reply With Quote
Old 10-12-2008, 02:43 AM   #10
dome24
Member#: 111845
97 RUBAsU Tall2dr
96 Neota Tacoma 4x4
2 man job, or does the gauge peak hold?
dome24 is offline   Reply With Quote
Old 10-12-2008, 03:45 AM   #11
blahhblahh
Member#: 86659
2005 WRX Sedan
WR Blue
you can, but the fuel should just evaporate after you remove the tester.
blahhblahh is offline   Reply With Quote
Old 10-12-2008, 10:18 AM   #12
stikboy9
Member#: 85019
MY02 & MY04 Turbo'd
Money Pits
I would disconnect the fuel pump relay too. Something about raw fuel washing the cylinder walls and fuel dilution in the oil just sounds like bad ju ju to me....Great write up though! Now someone needs to make one for a leakdown test! Hint hint...
stikboy9 is offline   Reply With Quote
Old 10-12-2008, 10:24 AM   #13
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
Yes, they hold peak.
Bort is offline   Reply With Quote
Old 10-12-2008, 07:57 PM   #14
03SubaruWRX
Member#: 158708
You would if you
had robot ears
Nice write up, can't wait to try it out for myself.
03SubaruWRX is offline   Reply With Quote
Old 10-12-2008, 08:12 PM   #15
csimp3
Member#: 188464
02 wrx
wrb, silver, black,primer
good write up with good pics, may have to give this one a shot this week
csimp3 is offline   Reply With Quote
Old 10-13-2008, 12:09 AM   #16
WRXislander
Member#: 50064
'02 WRX
MBP
Where'd you pick up the compression tester?
WRXislander is offline   Reply With Quote
Old 10-13-2008, 12:57 AM   #17
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I picked one up from advance auto part.
Old 10-13-2008, 12:58 AM   #18
WRXislander
Member#: 50064
'02 WRX
MBP
Thanks. I just did my plugs but I'll do this test when I replace them next year (copper plugs).
Old 10-13-2008, 06:20 AM   #19
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
The injectors need a ignition signal to fire so disconnecting the fuel pump relay is not really necessary.
GDR is offline   Reply With Quote
Old 10-13-2008, 09:45 AM   #20
Snitt
Member#: 36361
2004 WRX Cobb Stg II
WR Blue
Thank you for this write-up! I need to do one of these soon.
Snitt is offline   Reply With Quote
Old 10-13-2008, 01:38 PM   #21
sorrowfulkiller
Member#: 170439
I <3 Lamp
going wot at startup cuts fuel to the all cylinders, this is normal on al obd2 cars
sorrowfulkiller is online now   Reply With Quote
Old 10-13-2008, 02:17 PM   #22
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
So going WOT is not necessary either, correct?
Swine is offline   Reply With Quote
Old 10-13-2008, 04:11 PM   #23
smartSOFT
Member#: 168354
good write up! thank you
smartSOFT is offline   Reply With Quote
Old 10-13-2008, 05:52 PM   #24
Jus Blaze
Member#: 129428
2002 Wrx
Want to do one for me? Ill pay you = )
Jus Blaze is offline   Reply With Quote
Old 10-13-2008, 06:10 PM   #25
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
as long as you buy me lunch, sure why not?
Compression test instructions with pics. Impr3zy0u Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 123 03-27-2013 07:04 PM
new to boxers. help with compression test wildacex187 Newbies & FAQs 19 02-28-2007 12:03 AM
What is the standard compression test values on a 2.5ltr with forged pistons tino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 11-25-2005 03:16 AM
can compression test be done with accessport and antitheft mode? anthonyrb98 Engine Management & Tuning 12 09-25-2005 05:05 PM
DIY Compression Test thoughto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-31-2004 06:31 PM
