#51 |
Member#: 96267
Vehicle:'06 20G-XT'd STI CGM & NT03+M |
GREAT writeup bro. posted a link to this on the DIY/how to section of iwsti.
And I dont mean to sound like an idiot, but 'cranking the engine' means depressing clutch and turning ignition key (like you're normally starting the car) and getting the engine to turn over 6 times, right? I was gonna order this one from harbor freight for $17 http://www.harborfreight.com/cpi/cta...emnumber=95187
#52 |
Member#: 32459
Vehicle:02 WRX VF34 Junior Tuned 301whp |
Thanks... yes you are correct. Just crank the engine just like how you normally start the car.
#53 | |
Member#: 27525
SCIC
Vehicle:03 wrx wagon yellow |
#54 | |
Member#: 59388
RMIC
Vehicle:2003 WRX - Hybrid I do my own stunts |
It doesn't mean a thing. the ONLY thing you're really measuring, are the values compared to themselves. Your gauge could read slightly different from the next persons, and the elevation and relative barometric pressure will create a different reading as well. According to FSM, as long as the cyl are all within 7% of each other, then you're fine. Great writeup though. -1 for uplugging the ignition fuse - (Plugs and coil packs alread removed =pointless to remove fuse) +1 for unplugging the fuel relay (Below glovebox just inside passenger door - Brown wire harness) |
#55 |
Member#: 63767
NWIC
Vehicle:2009 OXT 5-spd 2011 STi hatch |
98,000 miles, been running the 16G for around 50k.
Results: 1: 155 2: 155 3: 145 4: 160 Time to find some more area under the curve with PnP city ![]() |
#56 | |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
The spark plugs are removed, the coil packs are removed and the ignition fuse is removed.Cite your source. |
#57 | |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
Its standard modern EFI operation. Its called "clear flood mode" and and is an algorithm in almost 100% or modern computer controlled EFI vehicles. |
#58 | |
Member#: 47646
Vehicle:0211 RallyWagon DGM Sedan |
#59 | ||
Member#: 15543
#60 |
Member#: 191474
BAIC
Vehicle:2002 WRX Black |
Here's the numbers I got:
2002 WRX 181,000 Miles on odo Bone Stock - No mods Cylinder 1 = 153 2 = 162 3 = 150 4 = 163 I bought my compression tester from harbor freight for $7!!! |
#61 |
Member#: 200856
BAIC
Vehicle:2003 Impreza WRX aspen white |
why do you need to do it in WOT?? there's no real need for this imo
thats why you crank it 5-6 times to get the compression test. imo your fouling your spark plugs when u do this. *good chance* just my two cent great write up tho. |
#62 |
Member#: 3251
NWIC
Vehicle:2009 WRX Hatch DGM |
#63 | |
Member#: 62856
Vehicle:MBP SQC#197 Stockpiling parts... |
wow...just wow. LOL, yup, you can foul your plugs going WOT. Better put these suckers far away then.. ![]() I immediately thought of this after reading that. http://forums.nasioc.com/forums/show....php?t=1123616 |
#64 | |
Member#: 59388
RMIC
Secondly, you should still go WOT with the throttle just to get the throttle open to allow air to be less hindered going into the motor. Thirdly, you just need to disconnect the brown wiring harness below the glove box right next to the door. This contains the fuel pump power etc... unplugging this is like turning the pump off so that you don't wash your cylinders with gasoline and thin out your oil. Nuff said... This resolves any nonsense about any "clear flood mode" and "standard modern EFI operation" crap. (And it takes like 5 seconds to unplug/plug it in.) |
#65 | |
Member#: 50064
RMIC
Vehicle:'02 WRX MBP |
#66 |
Member#: 96267
bump - what happened to the pics?
#67 |
Member#: 32459
Photobucket started to put a monthly limit on bandwidth.
Photos will re-appear in March. ![]() |
#68 |
Member#: 62856
You could always open another account.
![]() Another question, everyone says to do it warm. How much time after the car is shutoff still considered warm? When I did mine it was too damn hot to be working on and we just waited for it to cool off. |
#69 |
Member#: 110994
Vehicle:2004 WRX STi something good on the way |
#70 | |
Member#: 22399
Vehicle:2002 wrx 200k mile high club |
Well I waited like an hour after my engine was warm to do a compression test. I still got the following numbers on a 160k mile motor. 1= 168 2= 175 3= 165 4= 165 |
#71 |
Member#: 200526
SWIC
here are my results from my 02 with 120k miles
1. 162 2. 165 3. 163 4. 165 will a cold compression test point out a damaged ringland? i'm getting misfires when the car is warming up, not when its at temp. any ideas? |
#72 | |
Member#: 126686
South East
Vehicle:2002 Impreza, WRX World Rally Blue |
This is how a compresson test is done...by the book...period. |
#73 |
Member#: 126686
South East
#74 |
Member#: 126686
South East
Op...is it me or did you just skip explaining how to get to the driver side coils? They are definately the harder side to deal with.
#75 |
Member#: 53558
NWIC
Vehicle:2002 WRX Wagon Silver |
Having done compression tests repeatedly, on the same vehicle (V6 Toyota Corolla) with the throttle open and closed, I can say without any doubt, put the damn throttle pedal to the floor, or you will get a low reading, no matter how many times you crank the engine.
I'd also suggest pulling the fuel pump relay or disabling the fuel pump otherwise, as has been mentioned, though getting fuel in your oil isn't a big deal as the PCV system will just suck it out next time you're cruising down the freeway. If you start the vehicle with the throttle above 80% on any modern car (ODBII), the ECU/PCM/whatever the manufacturer calls it will go into Flood clear mode. What is flood clear mode? That depends... Is the car DBW, or is it cable? -Cable: The injectors will fire at 20% for a predetermined period of time to clear the cylinders while the engine initially starts, then go into normal operation (open or closed loop) -DBW: Which ever computer controls the throttle angle will command the throttle plates to either the throttle position the drive is, via the gas pedal, or to a predetermined position. The computer will either cut the fuel off, or cut fuel to 20% for a pre-determined amount of time, then it will go into reguarl open or closed loop operation. Just to clear this up: Clear Flood is another run mode, just like Open or Closed loop. |
| Thread Tools | |
| Display Modes | |
| Compression test instructions with pics. | Impr3zy0u | Factory 2.0L Turbo Powertrain | 123 | 03-27-2013 06:04 PM |
| new to boxers. help with compression test | wildacex187 | Newbies & FAQs | 19 | 02-27-2007 11:03 PM |
| What is the standard compression test values on a 2.5ltr with forged pistons | tino | Factory 2.5L Turbo Powertrain | 15 | 11-25-2005 02:16 AM |
| can compression test be done with accessport and antitheft mode? | anthonyrb98 | Engine Management & Tuning | 12 | 09-25-2005 04:05 PM |
| DIY Compression Test | thoughto | Factory 2.0L Turbo Powertrain | 6 | 01-31-2004 05:31 PM |
