Old 10-29-2010, 03:40 PM   #126
maxplanck
Member#: 255498
180K miles on my stock 04 wrx. 155, 160, 155, 155.
maxplanck is offline   Reply With Quote
Old 02-24-2011, 11:33 PM   #127
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
Anyone know if cranking the engine with the floor to the ground would have the same results with cars that have a Drive by wire (DBW) throttle system?
DutchOven is offline   Reply With Quote
Old 03-11-2011, 03:39 AM   #128
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Originally Posted by dome24 View Post
IMPORTANT NOTE!!!!
If your compression tester has an extension for deep plug holes, make sure said extension is tight on the tester or remove all together or else you run the risk of the extension coming off in the head and installing the plug into the extension and causing a wicked misfire, CEL and bucking engine...
ask me how I know
Whoa!!
You didn't notice that the adapter was missing when you pulled it out?
Hopefully your motor was ok though.
I feel your pain though...I borrowed a buddies tester and i assumed the adapter was threaded on tight. After testing the first cylinder, I went to un thread it and the adapter stayed in there
*I had a buddy hold the mechanics mirror and flashlight so I could see right down the hole. Then I put some loctite red on the hose part and threaded it back into the adapter that was suck in the head, let it harden for 20 minutes and then was able to twist it out all as one unit.
z is offline   Reply With Quote
Old 03-11-2011, 03:41 AM   #129
DutchOven
Member#: 220629
yeah this is one major downside of the boxer motor. awkward placement of cylinder heads
Old 03-11-2011, 03:56 AM   #130
z
Member#: 41762
04 STi
Oh and great write up by the way, thanks.
150 x 4
(I figure these testers must vary from unit to unit—so i'm not going to get to hung up on the numbers—but I'm just happy that there wasn't one significantly lower than the others.
130k on car, 70k on this motor which was replaced under warrenty due to oiling issue.
Old 03-19-2011, 03:00 PM   #131
obsaidian scooby
Member#: 276966
2005 wrx
Obsidian Black Pearl
whats the stock compression spec?
obsaidian scooby is offline   Reply With Quote
Old 03-19-2011, 05:51 PM   #132
ogboot
Member#: 170906
psm
Ej205: 125+ psi, no more than 7 psi deviation between cylinders. Take the auto store tester numbers with a grain of salt, not known for accuracy.
ogboot is offline   Reply With Quote
Old 03-20-2011, 04:00 AM   #133
UnknownAlly
Member#: 277330
2004 WRX
awesome write up!
UnknownAlly is offline   Reply With Quote
Old 04-06-2011, 12:36 PM   #134
downtown23
Member#: 72508
05 WRX
Black Pearl
I'm going to be giving this a shot.
Got my car back with a new hybrid built motor. Went from running good to to running like **** after about 400 miles. Data logs are pretty clean so yeah, not sure what to expect.
downtown23 is offline   Reply With Quote
Old 04-06-2011, 12:56 PM   #135
SLWBUGI
Member#: 279086
02 wrx
Nice write up.
SLWBUGI is offline   Reply With Quote
Old 04-07-2011, 01:02 AM   #136
minus500
Member#: 258271
Originally Posted by stikboy9 View Post
I would disconnect the fuel pump relay too. Something about raw fuel washing the cylinder walls and fuel dilution in the oil just sounds like bad ju ju to me....Great write up though! Now someone needs to make one for a leakdown test! Hint hint...
Definitely pull the fuse or disconnect the harness. You don't want to wash the walls.
OP, good write-up.
minus500 is offline   Reply With Quote
Old 08-28-2012, 12:44 AM   #137
Frank-i-e
Member#: 316463
2005 STi
World Rally Blue
GRAVE DIGGER
Alright guys so I wan to do a compression test on my 05 and I just don't quite understand when I should do it. Cold or Warmed up. You always want to change plugs when they are cold and what not but to do the compression test everyone says to warm it up but I don't want to break a spark plug in there. I've had it happen to me on a regular 1.8T VW and I can't imagine it happening to me in a boxer engine.
Frank-i-e is offline   Reply With Quote
Old 08-28-2012, 07:13 AM   #138
emjp4
Member#: 290926
2005 WRX
Originally Posted by Frank-i-e
GRAVE DIGGER
Your question was answered on post #3. You should always do it on a warm engine for proper oil pressure.
emjp4 is offline   Reply With Quote
Old 08-28-2012, 09:55 PM   #139
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
IMPORTANT NOTE!!!!
ask me how I know
How the??
Nothing seemed odd when the coil pack or plug wire didn't go back on fully?
cdvma is offline   Reply With Quote
Old 09-03-2012, 09:20 PM   #140
Kdub41
Member#: 328965
Thanks for these great tips
Kdub41 is offline   Reply With Quote
Old 09-05-2012, 06:15 PM   #141
Lealand
Member#: 330846
2003 wrx
sedona red gold pearl
thanks for the great writeup! I just joined the forum and got my first subi, so thanks for all the great info!!
Lealand is offline   Reply With Quote
Old 09-05-2012, 06:22 PM   #142
emjp4
Member#: 290926
2005 WRX
Congrats on the buy! Swing by the Newbie & FAQ section and introduce yourself and your car. Also fill in your profile with your car and location.
Old 09-27-2012, 12:42 PM   #143
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Welcome to nasioc.com!
Old 03-28-2013, 01:36 PM   #144
Rymaster
Member#: 296277
2002 Impreza WRX
I did this just did this earlier today since I'm looking to modify my car farther.
As it currently sits.
2002 WRX 120k miles, 4EAT trans, 18psi on stock turbo, aftermarket downpipe/exhaust, 240whp.
Cylinders
#1-154psi
#2-153psi
#3-155psi
#4-157psi
I've personally never done spark plug work on a subi before and it wasn't all that bad. Took me probably a little over an hour total while still taking my time. Getting everything out was easy although cylinder #2, the driver side one closest to the bumper is a little rough while using the compression tester. I bought the compression tester from my local Auto Zone($30) and it only took like 15-30 seconds to screw it into the other cylinders but I fought with cylinder 2 for a good 15-20 minutes to be able to line it up (might be why its number is slightly lower being as the engine started cooling off).
It helps if you put your one arm between the engine and your battery(if it fits) to help guide the hose as you twist it with your other hand.
I did just as the OP said and only pulled fuse #11 under the dash, I looked around and didn't really see a need to pull the fuel pump connection as well(although I guess it couldn't hurt)
And an FYI, if you did like I did and just unplugged your MAF sensor from your intake instead of leaving it plugged in and unscrewing it instead, you're going to throw a check engine light code. No biggie if you got a little code reader computer to just wipe it after your done though
But if not, you might wanna leave that plugged in....
Rymaster is offline   Reply With Quote
Old 05-25-2013, 01:04 PM   #145
snowbro
Member#: 263573
2004 STi
Pearl White
131, 130, 128, 128 on my 04 STi...
snowbro is offline   Reply With Quote
Old 05-26-2013, 12:26 AM   #146
Rymaster
Member#: 296277
2002 Impreza WRX
^^ Not necessarily a bad thing. More important that the numbers are closer together with each other then it is that some be high while others fall lower. Looks good to me!
Don't forget, if your engine started cooling off you're probably going to get lower numbers and the location's elevation from sea level also plays a big part in how high/lower your numbers can be as well.
Old 05-26-2013, 12:30 AM   #147
projectQWKSLVR
Member#: 285270
03 WRX
Good point. If the engine was 50 degrees cooler than typical, those are good numbers. Especially if he's more than say 5-600ft above sea level.
projectQWKSLVR is offline   Reply With Quote
Old 05-27-2013, 02:56 AM   #148
KGwrx
Member#: 268868
This is great!
KGwrx is offline   Reply With Quote
Old 12-15-2013, 08:26 PM   #149
2012 WRX
Member#: 376227
2012 WRX Hatch
Grey
So what kind of numbers would one expect with a fully cold (40F) engine at 3500ft elevation? I ask because I had my T-belt skip a few teeth (on the passenger side intake cam) during an accident and feared a bent valve. And, with the cooling system now removed I can't run my engine more than a few seconds to get it warm for an accurate compression test. With a cold engine the passenger side head pulled 120psi on each cylinder. That seems very low but way to high to have damaged valves. My compression gauge also isn't the highest quality so that may play a factor in accuracy, the consistency was reassuring though.
2012 WRX is offline   Reply With Quote
Old 12-16-2013, 01:47 PM   #150
BenxJammin
Member#: 363500
Thanks! Great post
BenxJammin is offline   Reply With Quote
Compression test instructions with pics. Impr3zy0u Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 123 03-27-2013 06:04 PM
new to boxers. help with compression test wildacex187 Newbies & FAQs 19 02-27-2007 11:03 PM
What is the standard compression test values on a 2.5ltr with forged pistons tino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 11-25-2005 02:16 AM
can compression test be done with accessport and antitheft mode? anthonyrb98 Engine Management & Tuning 12 09-25-2005 04:05 PM
DIY Compression Test thoughto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-31-2004 05:31 PM
