Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 09-06-2009, 03:00 PM   #301
yosuplee
Member#: 202806
2009 subaru OBS
black
Originally Posted by Magic Marker View Post
Be sure to take before and after pics.
will do... dont hold your breath though... ground shipping from OR to DC takes a while, then got to install them myself.....
yo
yosuplee is offline   Reply With Quote
Old 09-06-2009, 10:33 PM   #302
d. gage
Member#: 201150
are you going to be using the stock shocks/struts??
d. gage is offline   Reply With Quote
Old 09-06-2009, 10:49 PM   #303
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Hey folks, I need some help. If someone gets a chance, could you go and measure the length and height of the Outback Sport badge on the back of your car?
Unfortunately, my OBS was hit in a parking lot a week, guy was drinking coffee and driving on the wrong side of the road, clipped the front from the side and took the bumper, grill, fogs, etc right of the front of the car. Anyway, as it's at the bodyshop, hopefully getting paint on Tuesday, I can't take the measurements myself.
Thanks!
Ogden is offline   Reply With Quote
Old 09-07-2009, 10:33 AM   #304
yosuplee
Member#: 202806
2009 subaru OBS
black
yeah. although i hear about people blowing there struts primarily with STI pinks; according to HnR and the peeps at perrin, the HnR spring were made for the stock shock/struts (granted its all hearsay to me).
specs on springs - 1.4in drop at front, 1.3in drop at rear via website, and
"They are roughly 5% softer than stock at ride height to improve freeway ride quality, and then max out at 45% stiffer than stock at full compression. So they work really well!" from adam at perrin.
yo
Old 09-07-2009, 04:44 PM   #305
d. gage
Member#: 201150
Yo, I also heard about people blowing struts on pinks. I saw on tireracks site they sell HnR and they Strongly recommend aftermarket struts/shocks. I had a few cars with just springs and they were fine and the drop was much more dramatic. I'm looking forward to hearing how you like them and to seeing some installed pics. Thanks
Old 09-08-2009, 02:55 PM   #306
Baconsnake
Member#: 214880
2009 Outback Sport
Obsidian Black
Thanks!
Did you measure it already? I can get to it when I get home tonight if you still need it.
Baconsnake is offline   Reply With Quote
Old 09-08-2009, 03:43 PM   #307
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
I didn't, it would be great if you could. I'm of the mind for a bit of a de-badge - re-badge once I get the car back (hopefully Thursday), and if I can get those measurements I can get started earlier. Thanks, much appreciated!
Old 09-08-2009, 09:21 PM   #308
Baconsnake
Member#: 214880
2009 Outback Sport
Obsidian Black
Okay, please note that I have the rear bumper step, so my dimensions from the bottom are including that....
Let's use this image as a base (thanks cars101.com, sorry the image is hot).
From the bumper guard to the bottom of the P in Sport, 1 1/4"
From the bumper guard to the bottom of the O in Outback, 3 3/8"
From the door line on the right to the top of the k in Outback, 1 7/8" (Stay parallel to the top of the Outback)
From the door line on the right to the bottom of the k in Outback, 1 3/8" (Stay parallel to the bottom of the Outback)
Hope that helps!
Old 09-09-2009, 09:26 AM   #309
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Thanks! I think I can figure out what I need from that. I was looking more for the length of the word "Outback" and the height of the badge from the bottom of the "P" in sport to the top of the "Outback" lettering, but I think this will give me enough of an idea to run with.
Much appreciated!
Old 09-09-2009, 09:47 AM   #310
Eric91Z
Member#: 216858
2009 Impreza OBSlow
Steel Silver/Spark Silver
Three words: Rear Sway Bar
Do it as your first mod, you will not be sorry.
After that, I would go with a short shift kit if you have a 5-speed.
Well, finally ordered a sway bar. Just went with the WRX bar, end links, bushings, etc. Figured mine as well keep as many factory parts on there - not that it really makes it better or not. But any rear sway bar has got to be better than nothing.
So, anyone know for sure how big the stock '09 WRX rear sway bar is? I thought I read one place that it was 16mm and another that it was 20mm. 20mm sounds a little big for a stock rear bar, but what do I know...
Eric91Z is offline   Reply With Quote
Old 09-09-2009, 11:31 AM   #311
Baconsnake
Member#: 214880
2009 Outback Sport
Obsidian Black
I can do more later, let me know if you need it.
Old 09-09-2009, 01:37 PM   #312
Magic Marker
Member#: 181568
2011 3.6R Legacy LTD
Steel Silver Metallic
Let me know how it works out since I'm planning to do exactly the same thing. Pretty much just using all stock parts.
Magic Marker is offline   Reply With Quote
Old 09-09-2009, 01:43 PM   #313
Eric91Z
Member#: 216858
2009 Impreza OBSlow
Will do!
Old 09-09-2009, 01:53 PM   #314
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
If you can, that would be great. But if you don't get to it, no problem. I should have my car back tomorrow (fingers crossed) so I can do it then.
Old 09-09-2009, 01:58 PM   #315
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
I think that the 09 OEM WRX rear sway is 18mm. If I can get my hands on some calipers, I'll crawl underneath my car this weekend and check. I believe the 08 OEM rear sway is 15 or 16mm.
In other sway bar news, I emailed Rallitek and confirmed that they have, in fact, changed the design of the front sways that they have listed for the 08+ NA Imprezas, and they will now fit both the sedan and the hatch. These are the 22F/19R (or maybe 18R?) set. I have a follow-up question in to see if their track set (25F/22R) will also fit the NA Imprezas. I'll let you know when I hear anything. Even if the bigger bars won't fit, 22F/19R is a HUGE impovement over stock.
Old 09-09-2009, 08:31 PM   #316
d. gage
Member#: 201150
Awesome news. I haven't seen the underside of my 2.5 yet but i was wondering how hard of a job the front sway is going to be. please keep us posted ogden.
Old 09-11-2009, 09:49 AM   #317
yosuplee
Member#: 202806
2009 subaru OBS
black
after more research with people blowning there stock struts with aftermarket springs- its gotten me paranoid regarding blowning mine too... either way, i plan to install my HnR springs, but just look into aftermarket struts too (as a contingency).
anyone with personal experience regarding any of this? for the 08-09 impreza OBS?
yo
Old 09-11-2009, 11:01 AM   #318
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Lots of folks (08-09 2.5i and 08 WRX owners) seem to upgrade to the '09 WRX struts. That would be my eventual plan once I get around to upgrading the stock struts.
It's hard for me to pitch brand new struts without getting at least a few tens of thousands of miles out of them. After 20-30K, I'll get around to it.
Old 09-11-2009, 12:27 PM   #319
yosuplee
Member#: 202806
2009 subaru OBS
black
interesting... can i ask why?
if i do get the 09wrx struts, to they change the height of the car too?
thanks in advance.
yo
Old 09-11-2009, 12:28 PM   #320
yosuplee
Member#: 202806
2009 subaru OBS
black
interesting! what makes the 09wrx struts so much better?
and does it change the ride height?
yo
Old 09-11-2009, 05:48 PM   #321
Wagonguy98
Member#: 183763
2009 WRX
SSM
yo
The 09 wrx struts are valved much better(better dampening). I don't believe the ride height will be changed at all.
Wagonguy98 is offline   Reply With Quote
Old 09-11-2009, 06:36 PM   #322
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
This.
Old 09-12-2009, 02:45 AM   #323
cranker87
Member#: 216363
2008 OBS
Newport Blue
Since some want more pictures, here is my 08. I've had it for almost a year and still love it. It definitely helped me get through the Wisconsin winter. I am still considering getting the sport grille. I kind of feel like the sport grille makes the car look more generic. I like the light interior because, yes, I have dogs that shed and it is harder to see against the light brown. I took the rails off after snapping these pics.
cranker87 is offline   Reply With Quote
Old 09-12-2009, 08:28 AM   #324
Magic Marker
Member#: 181568
Looks good Cranker. I was wondering what the hood deflector looked like on the car. I don't see too many NPB OBS's running around. As for the sport grill, I was thinking about it too, but I figured it would let in too much debris in the the engine. The stock grill waffle at least deflects any road debris.
Old 09-12-2009, 04:30 PM   #325
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
The sport grill mesh is tighter than the stack waffle, I think, unless there is something behind the waffle on the stock grill that I haven't seen. I've had the sport grill on mine since day one and the only thing that's made it through my grill was a Ford Focus. That was not a fun morning. Luckily, only superficial cosmetic (i.e. non-structural) damage.
2009 Impreza Outback Sport rear bumper step pad? 2009OutbackSport Newbies & FAQs 16 07-12-2011 08:58 AM
FS NH: 2009 Impreza Outback Sport OEM seat covers Bu11dogg2 Interior/Dressup/Audio & Security 30 07-10-2011 01:28 AM
WTB : GC8, outback sport, 2.5rs HOOD AMEEN STI NWIC Private Classifieds 8 06-25-2010 11:49 AM
New 2009 Impreza Outback Sport 2009OutbackSport Newbies & FAQs 7 08-11-2009 09:24 AM
What's a good deal on a 2009 Outback Sport zergling General Community 4 03-31-2009 01:33 AM
