Old 09-22-2010, 01:26 PM   #726
Tarkus697
Member#: 243535
2010 Impreza OBS
Steel Silver Metallic
Yeah, seriously...do the RSB. I upgraded mine a month and change ago and haven't looked back. My OBS is really a weekend driver since I take the train to work, but when I'm out and about, I love the way it feels now.
When I drove down to Cincinnati/Northern KY last week, the curvy roads were beautiful and changing lanes at high speeds felt much smoother than it did before the RSB was added.
Originally Posted by Stewart McKenzie View Post
How much shipped to 20141? I may do the RSB and forget about the WRX catback then...
Tarkus697 is offline   Reply With Quote
Old 09-24-2010, 08:00 AM   #727
Stewart McKenzie
Member#: 238873
2010 Impreza OBS
Newport Blue/Steel Silver
OK... I've been offered a 08 WRX sedan rear swaybar/bushings/endlinks for a good price.... will a sedan sway fit on a 2010 OBS? The guy said that sedan/hatch swaybars are the same, but I want to make sure with fellow OBS owners first before I buy. Also, I've read about mounting brackets.. what are they and where can I get them? Cheers!
Stewart McKenzie is offline   Reply With Quote
Old 09-24-2010, 09:56 AM   #728
Tarkus697
Member#: 243535
2010 Impreza OBS
As far as I'm aware, the swaybar is the same for the sedan and hatchback. It should fit just fine.
As for the mounting brackets, not sure. My dealer ordered them and the other necessary installation parts for me when they installed the RSB on my '10 OBS.
Old 09-24-2010, 10:03 AM   #729
Stewart McKenzie
Member#: 238873
2010 Impreza OBS
OK... I guess I'll give my dealer a call... I was hoping you installed yourself, so you can give me the lowdown on how to do it! Anyone install the RSB themselves... how easy is it?
Old 09-24-2010, 11:43 AM   #730
Eric91Z
Member#: 216858
2009 Impreza OBSlow
Steel Silver/Spark Silver
I installed mine myself and it was a piece of cake. Hardest part was trying to figure out how to tighten the end link bolts... Just backed the car up on the Rhino ramp, chocked the front wheels, loosely mounted sway bar to car using the two brackets, installed the end links, and tightened everything up. And did it all by myself. Very easy job to do!
Eric91Z is offline   Reply With Quote
Old 09-24-2010, 12:01 PM   #731
gurana
Member#: 255131
2011 Impreza OBS
OBP/Dark Gray
Originally Posted by BrownyHound View Post
Can everyone please stop obsessing over gas mileage and just enjoy their cars? We all know that Subaru's get crappy gas mileage. And i think i speak for everyone when i say that, if i was concerned with gas mileage, i wouldn't have bought a Subaru.
Incidentally, I filled up the other day, and immediately went to a touchless car wash where I just idled in there (probably should have shut it off.) Since then, I've only driven to the train station 3 miles away. After three days of that, my average is at 19.3
sent from mobile.
gurana is offline   Reply With Quote
Old 09-24-2010, 01:50 PM   #732
Baconsnake
Member#: 214880
2009 Outback Sport
Obsidian Black
I installed a Rallitek RSB a couple weeks ago, and I think it's been a decent addition. The OBS no longer leans in any corner, and it seems to track significantly straighter in regular driving. Honestly, that's the one piece that is the most noticeable for me - I'm not constantly course-correcting the car any more.
Has anyone else felt the same after installing one?
Also, screwing in one of my endlinks was a huge PITA! I had to hold the bolt with the allen fitting on the inside of the bolt, and then just get the nut with a wrench. On the first one, I could use a socket with no problem though as the bolt didn't spin.
Baconsnake is offline   Reply With Quote
Old 09-25-2010, 11:53 AM   #733
JBH2989
Member#: 249218
2013 stg1 WRX
Midnight blue
sent from mobile.
I think I am having the same problem. I've done a couple touchless car washes since I've had the car (end of May.) Each time I left the car idling rather than turning it off and ever since it feels like my gas mileage has done down noticeably.
JBH2989 is offline   Reply With Quote
Old 09-27-2010, 08:00 AM   #734
gurana
Member#: 255131
2011 Impreza OBS
OBP/Dark Gray
What size rsb? Seems like you kept the oem fsb? Sway bars are on my short list of mods, for sometime during the life of the car. Seems that most posts I've read about upgrades/installs of sway bars people tend to upgrade the front whilst getting a new rsb. I'm guessing that's because most want the larger bar in front? It seems like the easier thing to do would be to get new rsb, then later upgrade front as I can, as long as that combo doesn't have undesirable results.
I've looked at some online vids for installing, and they all suggest you should use an Allen wrench with an open ratcheting wrench. Looks like a pain though, esp if you are using a crescent wrench.
sent from mobile.
Old 09-27-2010, 09:07 AM   #735
Eric91Z
Member#: 216858
2009 Impreza OBSlow
sent from mobile.
I think most people have just added the OEM WRX RSB to go with the stock front sway bar. I believe RalliTEK is the only company currently making a larger FSB for the N/A cars. Perrin is working on it, but last time I talked with Adam it was not done yet.
I have the WRX RSB and it is definitely better than stock, but waiting for Perrin to finish their N/A FSB and going with the 25mm front and adjustable 22mm rear Perrin sway bars.
Old 09-27-2010, 09:56 AM   #736
Baconsnake
Member#: 214880
2009 Outback Sport
Obsidian Black
Yeah, I left the front alone. I don't think that I would get the improvement per $ that adding the rear gives.
Old 09-27-2010, 10:38 PM   #737
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
I swapped the rear for an 09 OEM WRX bar, then I swapped to the Rallitek Front & Rear sway bars (22f/19r). The WRX rear sway was great, the Rallitek setup is better. Edit: much better!
Ogden is offline   Reply With Quote
Old 09-28-2010, 04:54 PM   #738
aweissenborn
Member#: 219181
2008 Impreza OBS
Newport blue/Steel metall
Default oil
For those who change their own oil on the 08+ obs's, which do you use and your experiences with it?
I plan to do my own oil changes from here on out and was curious what everyone's experiences have been? Thanks
aweissenborn is offline   Reply With Quote
Old 09-30-2010, 04:47 PM   #739
gurana
Member#: 255131
2011 Impreza OBS
OBP/Dark Gray
While we're on the subject: how difficult would you say installing away bars is? It looks straight forward enough. though I once snafu'd a thermostat replacement, to give you an jfea of my relative skull level.
Also, iirc, the '11 obs doesn't have a rsb. Would I just be able to install one, or would I have to get some sort of extra mounting kit and do some drilling?
sent from mobile.
Old 09-30-2010, 05:52 PM   #740
Tarkus697
Member#: 243535
2010 Impreza OBS
I had my dealer install it on my '10 OBS as I'm not mechanically inclined. But from what I've read, there shouldn't be any drilling required. Just the mounting brackets and screws and it should bolt right up.
sent from mobile.
Old 10-01-2010, 08:23 AM   #741
Eric91Z
Member#: 216858
2009 Impreza OBSlow
sent from mobile.
No drilling or anything else required. Just need the RSB, frame mounts and bushing, and end links with mounting hardware. All the holes to mount to are already there!
Old 10-02-2010, 02:14 AM   #742
RiiDePoint01
Member#: 259618
2010 Outback Sport
2tone Black
Anyone know if a 2008+ wrx/sti hood will fit on a 2008+ obs??
RiiDePoint01 is offline   Reply With Quote
Old 10-02-2010, 08:50 PM   #743
iommichild
Member#: 194990
2008 OBS
It'll fit - its been talked about before - it just doesnt serve a purpose without having an intercooler under there.
iommichild is offline   Reply With Quote
Old 10-03-2010, 03:44 PM   #744
RiiDePoint01
Member#: 259618
2010 Outback Sport
2tone Black
Ya that's true.. But it does give it a meaner look.
In what thread was it talked about?
Old 10-05-2010, 01:30 PM   #745
Tarkus697
Member#: 243535
2010 Impreza OBS
Hey, has anyone else noticed moisture in the rear taillights after getting the car washed? Seemed there was a lot of condensation in there the last time I took it to the local car wash place.
All dried nice and clear, but was just curious.
Old 10-05-2010, 03:08 PM   #746
Magic Marker
Member#: 181568
2011 3.6R Legacy LTD
I've never had an issue with condensation......
Magic Marker is offline   Reply With Quote
Old 10-05-2010, 11:58 PM   #747
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
In many, many threads. Search it. Pretty much ever since Subaru introduced turboed cars in the US, the feeling of many Subie owners is that if it's not a turbo, it shouldn't have a scoop. Really it's up to everyone to decide for themselves, but don't be surprised if you get some falk for it.
Personally, I think there are a TON of more better mods to make before I dump money on a hood. If I were looking for exterior mods, I would probably do the WRX/STI spoiler and/or bumper and side-skirts.
Old 10-06-2010, 09:49 AM   #748
Baconsnake
Member#: 214880
2009 Outback Sport
Obsidian Black
I get that when I wash my car either by hand or in the auto wash. It does dry out fine, and I only see the fog right after I do it. I have not seen it in the rain, so I think it's more about the angle of the forced water.
Old 10-06-2010, 10:30 AM   #749
Tarkus697
Member#: 243535
2010 Impreza OBS
I agree with the "meaner" look. My mom has a '99 SUS (original model before they renamed it the Outback Sedan) and it's got the hood scoop, but no turbo.
Definitely makes it stand out.
Old 10-06-2010, 02:02 PM   #750
sea-sube
Member#: 155492
2009 OBS
I agree with Ogden, you will probably hear some smack talk from WRX/STI owners especially since the hoodscoop went away awhile ago with the Hawkeye N/A's. I chose other exterior mods like the skirts, STI spoiler, and rear bumper with diffuser. I also put a wind deflector on the front end. While, it doesn't look the same as a WRX, it has its own style.
sea-sube is offline   Reply With Quote
2009 Impreza Outback Sport rear bumper step pad? 2009OutbackSport Newbies & FAQs 16 07-12-2011 08:58 AM
FS NH: 2009 Impreza Outback Sport OEM seat covers Bu11dogg2 Interior/Dressup/Audio & Security 30 07-10-2011 01:28 AM
WTB : GC8, outback sport, 2.5rs HOOD AMEEN STI NWIC Private Classifieds 8 06-25-2010 11:49 AM
New 2009 Impreza Outback Sport 2009OutbackSport Newbies & FAQs 7 08-11-2009 09:24 AM
What's a good deal on a 2009 Outback Sport zergling General Community 4 03-31-2009 01:33 AM
