Old 10-12-2008, 02:06 PM   #1
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Default 02 wrx manifold onto 06 STI block...how?
I'm dropping in a 06sti longblock into my 02 wrx. And have decided to use my 02 wrx manifold. This is my DD and just don't have the time available right now to due the full harness. I'm going to have the manifold, tgv's and tb done by Grimmspeed. I have to use the tgv's and injectors for the 02? Basically I need a how to on the swap. Whats kept whats not. Fuel lines and all that.
breathinez is offline   Reply With Quote
Old 10-12-2008, 02:30 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
suberdave is offline   Reply With Quote
Old 11-23-2008, 11:33 AM   #3
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
The maniflod I got back from Grimmspeed doesn't have a pvc valve on the underside screwed in. It only has a freeze plug. Is this something not necassary in my conversion.
Old 11-24-2008, 07:59 PM   #4
charliew
Member#: 125304
You can use a in-line pcv if you don't have the stock one anymore. All you need is a 1/2 vaccum port on the intake. I would run the old pcv lines to a closed catch can and then go through a in-line pcv on the manifold, Then run the heads breather back to the before the turbo intake but use about 3 feet of hose so it's not so close to the turbo when it's really sucking. The pass. side head breather is really close to the turbo intake and it will try to suck the oil vapor out of the head into the turbo under boost.
charliew is offline   Reply With Quote
Old 11-28-2008, 12:10 AM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
ditch the pcv all together^ and get a o/a separator.
scby rex is offline   Reply With Quote
02 wrx heads on v4 sti block? supernick77 Pre-2002 Factory Turbo Powertrain 0 05-09-2009 06:46 PM
02 WRX W/ 2.5L STi BLOCK 300 WHP!! 300 WTQ!! PASSED SMOG!! PRICED TO SELL $16,995!! Wrocket Private Vehicle 'For Sale' Classifieds 29 03-27-2007 12:29 PM
02 WRX W/ 2.5L STi BLOCK!! 300 WHP!! 300 WTQ!! PASSED SMOG!! PRICED TO SELL $16995 Wrocket SCIC Private Classifieds 33 03-27-2007 12:29 PM
02 WRX with a 06 STi trunk JiDM_WeRX Member's Car Gallery 10 09-20-2005 11:11 AM
