Old 10-12-2008, 07:28 PM   #1
RobK0000
Member#: 62230
Default Almost done swap, few ?s
I have completed most of the mechanical aspects of the swap. Motor was pulled, crossmember changed and new motor installed. No problem.
Its down to the details which is confusing me, i bought my longblock with several hoses missing and certain plugs disconnected. After searching alldata, im just getting frustrated. YOu cannot find these things if you dont know what the technical name is, so it doesnt help.
Let me get a list going.
-The tube that splits from 1 to 2 pipes mounted on the intercooler
-Small hose ontop of the BOV
-each side of the motor, ontop of the heads there is a tube pointed vertically, on the 2.2 they went into the intake manifold. Do these go into the turbo inlet
-Hose coming from brake booster, use to be plugged into the intake manifold.
-on the front of the intake manifold there is suppose to be a fuel filter looking like object, it has 3 connectors with 3 hoses leading off. The two sides are 1/2" and the other is 1/8"
-Just below the previous is a sensor with 2 plugs both 1/8"
-1/2" hose directly under the previous part sticking up near the sensor.
RobK0000 is offline   Reply With Quote
Old 10-12-2008, 08:06 PM   #2
oldhat
Member#: 113036
HTH.
oldhat is offline   Reply With Quote
Old 10-12-2008, 08:15 PM   #3
RobK0000
Member#: 62230
WOW, that helps alot.
Thank you!
Old 10-12-2008, 08:58 PM   #4
oldhat
Member#: 113036
np, North Ursalia showed it to me when I had a similar problem. Just be sure to pass it on to the next guy without a vac diagram when you're done with your swap!
Old 10-16-2008, 04:34 PM   #5
RobK0000
Member#: 62230
What is the part 16102, the part that both lines off the turbo T into? I dont have it and im thinking it might be important.
Old 10-16-2008, 05:33 PM   #6
Aspen_2.5RS
Member#: 3310
16102 = boost control solenoid (and yes, it's important)
Aspen_2.5RS is offline   Reply With Quote
Old 10-16-2008, 06:04 PM   #7
RobK0000
Member#: 62230
do i need to have a stock one, or can i go with an aftermarket? if so what would you guys recommend. Whichver is cheaper
Old 10-16-2008, 06:07 PM   #8
RobK0000
Member#: 62230
also what is 22012 top center of diagram
Old 10-16-2008, 06:24 PM   #9
johnny p
Member#: 141232
02 v7sti wagon
signal green
You need a stock 1.
johnny p is offline   Reply With Quote
Old 10-17-2008, 12:53 PM   #10
oldhat
Member#: 113036
You can make your own manual boost controller for like $10 if yours is missing. Just be super careful playing around with boost control because you can blow up your motor real easy.
http://en.wikipedia.org/wiki/Boost_controller
What kind of motor, turbo and engine management do you have? what octane fuel are you using in your area?
Old 10-17-2008, 01:00 PM   #11
oldhat
Member#: 113036
Old 10-17-2008, 01:05 PM   #12
oldhat
Member#: 113036
Don't remember the name of 22012 but it's part of the MAP sensor bit IIRC.
setting up video surveillance, almost done, few q's ihavebettersound Car Audio, Video & Security 7 10-20-2006 12:55 PM
Swap almost done. tranny problem. guru's of mid-a, please help. AzNStiImpreza Mid Atlantic Impreza Club -- MAIC 1 07-18-2005 03:36 PM
Engine Swap Almost done-A pictorial blinguskahn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 05-30-2005 01:00 PM
Ver5 Swap almost done wickedscooby Subaru Conversions 12 04-13-2005 01:03 AM
1998 Outback swap! almost done! Jerry Hong Subaru Conversions 1 04-30-2003 07:09 PM
