Welcome to the North American Subaru Impreza Owners Club Wednesday April 16, 2014
Old 10-12-2008, 11:57 PM   #1
fastlanerex
Member#: 133391
2004 boosted saleen
white
Exclamation idea for cause of low oil pressure
well after full warmup and just normal driving for a while at idle my cars oil pressure on my stri oil pressure gauge thats tapped into the gally plug reads between 5-8 psi?????? WTF is the cause of this posible reasons for this. im scared im going to spin a bearing at idle. When rpms increase so does the oil pressure but the idle pressure is scaring me a tad bit.
fastlanerex is offline   Reply With Quote
Old 10-13-2008, 07:33 AM   #2
djoye
Member#: 50072
2003 WRX
12.3@112 20psi
Did you just install this gauge or was it reading normal in the past and then now started reading low?
edit: I see where you had 15psi in the past. I'd first check the area around the sensor to make sure it's sealed good.
djoye is offline   Reply With Quote
Old 10-13-2008, 08:57 AM   #3
MasterKwan
Member#: 98961
2003 WRX
I'd get a mechanical gauge to double-check the pressure.
Old 10-13-2008, 09:37 AM   #4
rkramer
Member#: 118209
2002 WRX Sedan
I'd wonder why it changed if you had 15 psi before, but 5-8 psi at idle isn't a problem by itself. You won't spin a bearing with that oil psi at idle.
Old 10-13-2008, 12:42 PM   #5
BluScubi
Member#: 162726
2009 LGT
QSM
Definatly double check with a mechanical gauge. I had the same problem with my prosport oil press gauge. It started reading low and erratic. I checked it with a mech gauge and it was fine.
BluScubi is offline   Reply With Quote
Old 10-14-2008, 12:12 AM   #6
fastlanerex
Member#: 133391
2004 boosted saleen
white
cool guys thanks i think it reading irratic i dunno it works fine but i will keep an eye on it.
Old 10-14-2008, 12:45 AM   #7
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
i usually get 20 psi at idle and 95 psi once i get near 3k rpm
03WRX-WRB is offline   Reply With Quote
Old 10-14-2008, 02:09 AM   #8
fastlanerex
Member#: 133391
2004 boosted saleen
white
never do i hit 95 psi at cruising around 3k im between 60-70psi my gauge must be off i am guessing o well **** it ill learn to adjust so long as it doesnt hit 0 and if it does and my engine still runs ill know its probably a bad sending unit.
Old 10-14-2008, 04:12 AM   #9
hotrod
Member#: 14141
2002 Impreza WRX
e85forum.net
All you need is 10-12 psi /1000 rpm. If you are idling at 750 rpm that is a perfectly acceptable hot oil pressure.
If it is still that low at 2000 rpm then you have an issue to investigate.
Oil pressure will also vary with oil viscosity and temperture.
Larry
hotrod is offline   Reply With Quote
Old 10-14-2008, 08:52 AM   #10
Arctic Penguin
Member#: 119532
2006 WRX
what oil is being used?
Arctic Penguin is offline   Reply With Quote
Old 10-14-2008, 09:08 AM   #11
djmic
Member#: 91032
2005 impreza wrx
obsidian pearl
needs one!
djmic is offline   Reply With Quote
Old 10-15-2008, 12:30 AM   #12
fastlanerex
Member#: 133391
2004 boosted saleen
white
castrol gtx high milage 5w30. i have always used dino oil never fully synthetic.
Old 10-15-2008, 12:32 AM   #13
fastlanerex
Member#: 133391
2004 boosted saleen
white
Larry
it goes up with rpms which is a good thing, and at cruising speeds its a little below 80psi so i think im good. thanks agian for the quick responses.
drew
Old 10-15-2008, 12:44 AM   #14
The Cheat
Member#: 66044
2004 WRX/1994 Miata
my blitz gauge is reading low and is erratic as well. i've been meaning to check the sensor/gally plug for corosion since it gets ground through the sensor casing/plug.
The Cheat is offline   Reply With Quote
Old 10-15-2008, 02:13 AM   #15
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
hmm ive got a similar issue. my oil pressure gauge reads less tyhan 20 at idle usually around 10 psi. the warning light comes on (the aftermarket gauge light not the cluster dummy light)
when driving the gauge sits around 120 psi. the factory oil light is functioning properly but never comes on. do you think something is wrong with the gauge>?
Loomin is offline   Reply With Quote
Old 10-15-2008, 02:24 AM   #16
Arctic Penguin
Member#: 119532
2006 WRX
and how many miles on it since it was changed?
Old 10-15-2008, 09:40 PM   #17
Steve Nastoff
Member#: 52052
03 Subaru WRX
Midnight Black Pearl
My Autometer guage, tee'd with the factory sensor (idiot light) under the alternator reads 35 lbs. at idle and 80 lbs. + at 3,000 rpms when fully up to operating temps while running
Redline 10-30 oil.
Steve Nastoff is offline   Reply With Quote
Old 10-20-2008, 10:38 PM   #18
fatalbertswrx
Member#: 42029
2002 Subaru
seriously i dont know the specs on the ej20 but anything below 20-25psi at idle
is def. not good.
using castrol, if you pulled the oil pressure sensor and installed an manual gauge on a hot start and didnt get at least 20psi, i would pull the oil pan and look at a clogged pick-up tube or "strainer" as old timers like to call em.
castrol sux IMO.
fatalbertswrx is offline   Reply With Quote
Old 10-20-2008, 10:52 PM   #19
rentforsale
Member#: 139391
BugI wrx
Its Blue !
I've heard of more than a few Electric oil pressure senders mounted in the galley plug underneath the intercooler going bad from the heat down there . Happened to me actually .
rentforsale is offline   Reply With Quote
Old 10-20-2008, 11:15 PM   #20
jason.g
Member#: 88467
2005 WRX
All black everything.
Same here.
OP- try swapping out your sending unit w/ a new one and double-check the gauge w/ a mechanical one.
jason.g is offline   Reply With Quote
Old 10-21-2008, 12:17 AM   #21
Arctic Penguin
Member#: 119532
2006 WRX
these engines seem to shear oil very quickly and using the wrong oil(way too much of that here due to lack of logical thought process and wives tales) seems to lead to a LOT of spun bearings and I think that this low oil pressure at idle is one of the big indicators of the wrong oil being used past the point where it has sheared beyond providing proper lubrication
but ive never even thought about this issue and have nothing to add because it just wont matter anyway
Old 10-21-2008, 12:23 AM   #22
TX_Travis
Member#: 111648
04 wrx
are you saying non synthetic 5w30 is the wrong oil?
TX_Travis is offline   Reply With Quote
Old 10-21-2008, 01:03 AM   #23
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Sound like a motor ready to let go soon. I recently had low pressure of 17.4psi with bad weight of oil. I switch to valvoline max life. Now at 26psi oil pressure. Read my thread. Then consider another oil as your motor is worn. Change your oil quick. Normal pressure is 20 to 30 psi.
Old 10-21-2008, 08:58 AM   #24
rkramer
Member#: 118209
2002 WRX Sedan
is def. not good.
The spec is 8 psi or greater at 800 rpm, so no, below 20-25 psi is certainly not the limit. PSI has alot to do with oil viscosity, a heavier oil is simply going to resist flowing more. Also, increased psi doesn't mean the oil is actually doing a better job, it just means less of it is actually reaching the bearings. (the oil pump is static displacement, higher psi means lower flow) Engines generally can idle at a VERY low psi without issues.
Old 10-21-2008, 09:56 AM   #25
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I don't fully agree with that but ok
Drop in oil pressure / low oil pressure magicstop Newbies & FAQs 1 06-08-2009 02:23 AM
Looking for cause of oil consumption (forged pistons) 300blueballs Factory 2.5L Turbo Powertrain 22 02-15-2006 10:50 PM
All possible causes for low oil pressure... Javier Factory 2.5L Turbo Powertrain 50 01-24-2006 10:49 AM
Oil Coolers cause low oil pressure upon startup? kaos200 Factory 2.0L Turbo Powertrain 2 07-21-2004 02:22 AM
Low Oil Pressure MisterX Factory 2.0L Turbo Powertrain 29 12-06-2002 11:18 AM
