Old 10-13-2008, 10:44 AM   #1
Bradical
Member#: 173142
2007 WRX Wagon
Brownsilverpewterwhat?
Default Trying to install LGT 1,2 in my bugeye
So,
Im installing the Legacy GT first and second, along with 04 WRX third and fourth. Keeping my 5th gear. Keeping the case too.
The problem is: When the time comes to tighten down the case, the gears are binding up. I have tried multiple combinations of gear adjustments, but cannot free them all up. The issue seems to be between 2nd and 3rd, the tolorances are not acceptable and will bind up.
Question: I know that others have done this mod on later model WRXs, but havent found anyone that has done this in an '02. Is there a modification or trick, other than the instalation of the proper parts? Is there a washer, or spacer that I need to put in there to make this all work?
Bradical is offline   Reply With Quote
Old 10-13-2008, 10:46 AM   #2
resideinva
Member#: 179641
2005 LGT Wagon 5spd
RBP
Originally Posted by Bradical View Post
So,
yes ppl have done it on a bugeye. i believe thats gear set up is the exact one siclike7 has in his
resideinva is offline   Reply With Quote
Old 10-13-2008, 11:12 AM   #3
Bradical
Member#: 173142
2007 WRX Wagon
Good to know, so I guess my real question now is: was it a straight forward install, or is there some mod/special instruction to make it all groove? Im trying to determine if I have the right parts/all the parts/faulty parts.....
Old 10-13-2008, 11:34 PM   #4
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Get some calipers and measure the old parts vs new parts and determine if the lengths are the same on the gears, shafts, or whatever else you replaced.
akira02rex is offline   Reply With Quote
Old 10-14-2008, 10:25 AM   #5
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
Can you take a picture of the input shaft, right behind forth gear (a close up) and of everything assembled in the case half? I might be able to help.
Andrew
AndrewtechAutomotive is offline   Reply With Quote
Old 10-15-2008, 11:45 PM   #6
Bradical
Member#: 173142
2007 WRX Wagon
So just to clarify.The gears bind after I tighten 5th gear housing against the input shaft retainer (pic 5 and 6 shows the retainer)to the front case halves.That is when third gear (drive)contacts 2nd gear (driven) in pic 1648.I am pointing at the gears(pic 2) that touch each other(they are not touching in the pic).If I remove the shims from the lower shaft the gears will not bind but the front diff gear set pattern is unacceptable.If there were a shim in between 2nd and 3rd drive gear it appears all would be fine(there was not a shim stock or in subi's part pics),also 2nd and 3rd felt rough as you spun 3rd on the input shaft against 2nd.I was told this was normal and lgt gears were noisy during break in.
Pic 1
Pic 2
Pic 3
Pic 4
Pic 5
Pic 5
Old 10-16-2008, 09:56 AM   #7
Member#: 99694
2002 dogbox,'11 wrx
Hard to see from the pic, but to me it looks like the thicker thrust washer is between input 4th and input thrust bearing. Can you pull the input shaft back apart to confirm?? It needs to have the thinner shim.
Andrew
Old 10-16-2008, 12:45 PM   #8
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
i had this same problem, i had to get a 04+ thrust washer for the input shaft as well as a 3/4 shift rod.
thanks again for the help andrewtech
romanlynch is offline   Reply With Quote
Old 10-16-2008, 02:29 PM   #9
Member#: 99694
2002 dogbox,'11 wrx
Your welcome.
Andrew
Old 10-16-2008, 04:13 PM   #10
Bradical
Member#: 173142
2007 WRX Wagon
I have the proper thrust washer and shift rail on the way. Thanks Andrewtech!!
Want to replace my 2.0 in my Bugeye and put in a 2.5 Legacy GT driveline... B-Kerr Subaru Conversions 6 03-14-2009 05:14 PM
How to install 07' STi Deck in my 05' STi? Misanthrope789 Car Audio, Video & Security 11 02-06-2009 11:07 AM
LGT 1,2 in my 2002 WRX Bradical Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-13-2008 09:18 AM
Why is Quick Time trying to install in my start up folder when I NASIOC??!!! speednby Off-Topic 10 08-15-2006 03:03 PM
Advice on installing a playstation 2 in my wrx. Vidiotgamer Car Audio, Video & Security 6 08-27-2004 10:50 AM
