Old 03-20-2002, 07:50 AM   #1
makeewak
Member#: 16619
1999 Impreza 2.5rs
black pearl
Question what to do with my 2.5rs
i own a 2.5rs and im thinking about either doing an engine swap for a ej20 or turbo/supercharging my current motor. what is the best route for me to taki?
makeewak is offline   Reply With Quote
Old 03-20-2002, 10:33 AM   #2
Julian
Member#: 1182
MY00 RS
BRP
Buy a WRX.
What do you want? Outright power, low-down torque, ease of install, legallity...
How much money do you have to spend?
Julian is offline   Reply With Quote
Old 03-20-2002, 02:11 PM   #3
Darwin
Member#: 2704
2001 Impreza 2.5 RS
Blue Ridge Pearl
An EJ20 turbo swap is legal, and enough people have done it that it's well established. I guess the main factor is how much you can get an EJ20t with all the plumbing and harness for.
Darwin is offline   Reply With Quote
Old 03-20-2002, 03:28 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
A USDM EJ20T from a USDM WRX is a legal swap, provided you meet ULEV emissions when you're done (you have to meet emissions for the newer of the body/motor you install into your car). That does not clear the way for legal installations of non-USDM EJ20Ts, however.
Old 03-20-2002, 06:47 PM   #5
HondaH8er
Member#: 3097
2000 2.5RS Coupe
Silverthorn Metallic
It's actually illegal to put an engine that is older than the body into a car. So the best option would be a USDM EJ20, as it will meet emissions and is newer that your car. Unfortunately, it has less power than a J-Spec WRX motor, and the J-Spec can probably be had for less money. Turbo/supercharging is probably going to give you the best of both worlds, as long as you do it right. You'll keep the low-end power of the 2.5L, and have the top-end power of the WRX.
HondaH8er is offline   Reply With Quote
Old 03-20-2002, 07:57 PM   #6
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
If you put in an EJ20t you will miss the torque and displacement of the EJ25, I guarantee it. I recommend a turbo kit like Shiv's, coupled with his TEC II kit, and run something like 6 or 7 pounds of boost. If you want more boost than that (you'll already be running as fast, if not faster than a WRX, with the low end torque) you'd have to think about the tranny and internals, but that's my advice.
You could also stay NA and get cams.
Marc Sawaya is offline   Reply With Quote
Old 03-20-2002, 10:31 PM   #7
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
I think a super/turbo would be a better choice. It should be a bit cheaper than a 02 WRX engine swap and it'll still have the 2.5 low end.
Mike
MagicMT is offline   Reply With Quote
Old 03-21-2002, 02:41 AM   #8
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
USDM EJ20 with Tranny and rear Diff and everything inbetween IMO.
EJ25's dont like to be Turbo'ed, might find yourself spending even more to get another engine in the long run.
Old 03-21-2002, 10:24 AM   #9
Julian
Member#: 1182
MY00 RS
BRP
You CAN transplant an older engine into a newer car (at least in Cali), you just have to meet the smog requirements of the newer of the two components.
But strangely enough, the cat isn't considered part of the engine, it is part of the chassis. So, my EFI engine swap in my Datsun 510 doesn't require a cat. Funny how that works.
Old 03-21-2002, 12:10 PM   #10
wrxlvr
Member#: 10788
2002 Outback
Blackety black
Turbocharge your current engine. There still is no replacement for displacement.
wrxlvr is offline   Reply With Quote
Old 03-21-2002, 02:52 PM   #11
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Are you sure about that? I've heard numerous times the same thing that HondaH8er said- That the engine must be newer than the body of the car. It also has to be USDM, IIRC.
Mike
Old 03-22-2002, 08:00 AM   #12
JMotorsprt
Member#: 12930
2002 Nissan Spec V
My initial thought (because I have been debating saving money and buying a RS over a WRX; budgeting reasons) would be Turbo the 2.5. But I have heard a few people mention (like above) that the 2.5 does not like the Turbo. WHY? I am looking for specifics. Will I have to replace Rods and Pistons?
Thanks
Jason
JMotorsprt is offline   Reply With Quote
Old 03-22-2002, 07:31 PM   #13
HondaH8er
Member#: 3097
2000 2.5RS Coupe
You might want to double check on that, especially there in California, considering what those emission laws are like. And I believe it's a federal law, and all the states have to follow it, about the engine not being allowed to be older than the chassis. The engine only has to pass the emmisions for the year of the body, though, so dropping an LT1 into a 57 Chevy, and pulling off all the emissions stuff should be OK, since the 57 doens't even have to pass emissions. Did I say the word emissions enough yet?
Old 03-23-2002, 01:44 AM   #14
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
Go do some searches in the aftermarket induction forum for "blown engine" and stuff about turboing a 2.5... Lots of people have blown their engines running too high of PSI. The 2.5 just isnt designed as well for acompaning a turbo... (Ive heard everything from the block doesnt have as strong of piston walls, to stuff about the block not being designed well in the first place)
Old 03-23-2002, 02:21 AM   #15
bensonwrx
Member#: 6904
AWD W204, R35, V36
DWM, BO, MW
Yeah if the EJ25 is turbocharged w/too high of a boost, it's blown up Reason was what Kostamojen said, and also the cyclinder walls are too thin, as size is same as EJ20 and displacement is larger. Also, the open deck design is another reason preventing high boost setup. Tranny is another main concern, b/c the US Spec tranny just doesn't cut it for high boost turbo application. Being said all that, I am going to turbo mine soon (but at 5psi only, w/no further increase of boost).
Good luck modding!
-Benson (Another MY98 Owner)
bensonwrx is offline   Reply With Quote
Old 03-23-2002, 06:52 AM   #16
JMotorsprt
Member#: 12930
2002 Nissan Spec V
Thank you for the input. Guess I go back to the WRX vs. Spec V debate.
Thank you
Jason
Old 03-24-2002, 04:38 AM   #17
makeewak
Member#: 16619
1999 Impreza 2.5rs
black pearl
Good luck modding!
Old 03-24-2002, 04:40 AM   #18
makeewak
Member#: 16619
1999 Impreza 2.5rs
black pearl
thats funny cause although all the warning about having the engine wall to thin, im still putting a s/c in my car.
hehe,
Rod
what to do with my 2.0l..........................? Flyin_Hayn Built Motor Discussion 39 01-13-2013 04:49 PM
What to do with my 2 new 200 gig drives. Protege Menace Off-Topic 37 12-02-2006 09:01 AM
what to do with my 2.5rs engine&trans? ADE Vancouver Impreza Club Forum -- VIC 25 01-21-2005 12:28 AM
what to do with my 2 JL 12"W3DV2 ? WS6toWRX Car Audio, Video & Security 3 07-27-2003 12:51 AM
('93-'01) first thing to do for my 2.5RS Blk Devil RS Impreza Forum 18 05-12-2002 02:53 PM
Message Board Statistics All times are GMT -4. The time now is 03:00 PM.
