Welcome to the North American Subaru Impreza Owners Club Saturday August 30, 2014
Old 10-13-2008, 10:03 PM   #1
vin0305
Member#: 85808
2004 WRX
WR Blue
Default 2.5L/2.0L hybrid - Which flywheel/clutch do I need?
I'm in the process of having a 2.5L block from a 2005 STi build up with my 2.0L heads after throwing a rod bearing in my 2004 WRX. While the motor is out and since I'm (hopefully) going to be making some good power when I'm done, I want to change the flywheel and clutch to handle it. Question is, what do I need? Does the flywheel have to match up to the STi block, do I need to get an STi clutch to match the flywheel? How do I make this work, the 2.5 block with stock WRX tranny? I'm learning as I go along here
vin0305 is offline   Reply With Quote
Old 10-13-2008, 10:10 PM   #2
dirtyhartland
Member#: 64298
lazy and in pieces
Your clutch and flywheel depend on your transmission. Using your existing parts would be just fine.
dirtyhartland is offline   Reply With Quote
Old 10-15-2008, 10:12 PM   #3
Dtown2point5
Member#: 44702
2002 Impreza WRX
You can use the clutch you already have.
Depending on how many miles were on your clutch though, you might consider replacing the clutch disc itself.
Dtown2point5 is offline   Reply With Quote
Old 10-16-2008, 12:01 AM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Stock disc, and flywheel. But you might want to consider an upgraded pressure plate.
~Josh~
2003 WRX 2.5L/2.0L heads hybrid build w/ GT52 on dyno today Mr.Anderson Proven Power Bragging 11 05-11-2010 06:24 PM
2.5L wrx heads Hybrid swap (oil consumption issue) swift2fly Factory 2.5L Turbo Powertrain 0 10-18-2007 10:20 PM
97 "l" wagon to 2.5RS look - Which of following do I need? akm3 Subaru Conversions 17 09-05-2003 11:32 AM
Which clutch do i need, WRX or RS? edkwon Transmission (AT/MT) & Driveline 1 03-28-2003 08:48 AM
Which flywheel/clutch combo??? 6starspeed Transmission (AT/MT) & Driveline 7 11-16-2002 11:30 AM
