Old 10-13-2008, 10:42 PM   #1
MF-DIF
Member#: 62197
2002 WRX, GTO
SV650N, FZ-09
Default All of my brake lights are out
I noticed today that none of my brake lights work. The two tails and back windshield mount lights all do not function.
Over the weekend I did an STi trunk swap. My harness for the spoiler brake light was cut (ive done 3 trunk swaps, can't decide what I like. ). Anyways I go to splice the wires for the new spoiler like I've typically done.
Now all my normal brake lights are out and the spoiler brake light does not function either. They functioned before the swap and splice. I'm no electric expert (see spliced wires), but I'm guessing I ran out of luck and that spoiler had something to do with overloading things.
I disconnected the spoiler light wires, and check all the fuses under the hood and it's all ok. I pulled only the ones that could be pulled with the fuse puller...not the big block ones.
What's the next thing to check? I just put a 9v battery to the spoiler light wires and it lit up...so i dont think I blew the bulbs.
MF-DIF is offline   Reply With Quote
Old 10-13-2008, 11:18 PM   #2
Handsdown
Member#: 29355
the big blocks are relays, not fuses.
it could be the switch, for the pedal... but the next step is to use a multimeter and check back through the wiring. it's possible if you cut or removed wires the circuit's been broken. multimeter, start from the spoiler and tails and check every connection back.
if i had to guess i'd say it's a fuse you didn't check. the wires you removed probably are in parallel to the other brake lights, but a fuse could have easily blown.
Handsdown is offline   Reply With Quote
Old 10-13-2008, 11:41 PM   #3
MF-DIF
Member#: 62197
2002 WRX, GTO
SV650N, FZ-09
Is there another fuse box under the drivers steering column? I've noticed it in other cars...but can't find the location in this one.
Old 10-13-2008, 11:47 PM   #4
kamote
Member#: 184110
2007 impreza sti
yes there is... left below the steering column. it's like a cellphone holder or ashtray.. you have to pull it out..
kamote is offline   Reply With Quote
Old 10-14-2008, 12:09 AM   #5
MF-DIF
Member#: 62197
2002 WRX, GTO
SV650N, FZ-09
Yup it was a blown fuse in there. Subaru why you hide things I'll never know.
Old 10-14-2008, 12:24 AM   #6
Handsdown
Member#: 29355
i love that fuse block. it's so handy
All my rear brake lights are out buccilli15 Electrical & Lighting 5 03-16-2008 02:16 PM
My Brake Lights are OUT! DragoonFly Newbies & FAQs 5 10-14-2007 11:20 PM
No, my brake lights are fine. It's called a stick-shift. Sharkbait Off-Topic 65 09-23-2004 04:07 PM
"Sir your brake lights are out!" chrislehr New England Impreza Club Forum -- NESIC 31 05-23-2004 08:15 PM
my brake lights went out spiralsmurf Electrical & Lighting 4 01-29-2003 02:24 AM
