Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 10-14-2008, 01:03 AM   #1
WoodsWagon
Member#: 180769
lots of junkers
Default Stock Sti pistons in phase 1 2.5?
My question is, can you put the stock pistons out of a sti shortblock onto the rods on a phase 1 2.5, have it fit the bores on said engine and drop the comp ratio low enough to put a turbo on.
I've got a phase 1 shortblock on a stand, then another complete phase 1 in the shed and a phase 2 out there as well. Both of those are torn down to the basic bits. Some EJ22's out there to. The phase 2 has gouges in the cyl wall from a piston breaking, the phase 1's all have degrees of pitting on cyl bores due to blown headgaskets.
The plan is to put some combonation of parts in my 86 GL-10. I've got a nice header, sundry turbo's, superchargers and intercoolers and whatnot in my other shed, and a n/a EJ22 wiring harness.
It's not my first EJ swap into the EA chassis, and if I just did a basic EJ25 N/A swap it would be easy. But the GL-10 has the turbo crossmember and it seems a shame to waste that. It moves pretty good with the 111hp turbo 1.8 in it... so even a n/a ej25 would be a big improvement.
Since I already have a mostly OK shorblock on the stand, it would be easy to swap in pistons. I'm cheap, so using stock cast-off's from someone building a sti block would be nice, if they fit.
WoodsWagon is offline   Reply With Quote
Old 10-14-2008, 01:15 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You "can" install STI pistons on the 2.5 phase 1 rods and crank. I know, cause I did it. I made 350ish whp... But the piston sits 1-2 mm below the deck. LOW compression.
But it worked!
Old 10-14-2008, 03:55 PM   #3
saab-on-the-cobb
Member#: 116330
1999 Lincoln Nav
hooker's lipstick red
Originally Posted by reddevil View Post
...LOW compression.
But it worked!
Any idea of the compression numbers?
Sounds like a good build for high-boosting turbos.
sotc
saab-on-the-cobb is offline   Reply With Quote
Old 10-14-2008, 04:00 PM   #4
paurio.tt
Member#: 169659
1997 Legacy GT
Red
I hear the best way to go about it is get a phase 2 crank from an sti or newer legy with sti rods. Then the pistons from the sti will sit properly and your NA engine will be able to hadle a lot more psi. I have not done this myself, but I have been doing a lot of searching around and found that this is the most reliable setup for turboing the phase 1 NA blocks. It's definetly worth looking into. If you would like to do some reading you should go to 2.5rs forums and search for posts by skully. He had a phase 1 block from a 97-98 rs (I think) and he was safely running more than 20psi. Best thing is, if this really does work, is that this doesn't come with the $6000 price tag
.... and sti head gaskets... and of course you need supporting mods
paurio.tt is offline   Reply With Quote
Old 10-14-2008, 05:03 PM   #5
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
But it worked!
ANd how many lbs of boost did it take to hit those #'s ?
sense of nature is offline   Reply With Quote
Old 10-14-2008, 05:27 PM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
22-24 ish...
Hey, I said it worked, not that it was the best!
Old 10-14-2008, 06:05 PM   #7
WoodsWagon
Member#: 180769
lots of junkers
I have a phase 2 crank out of the SOHC 2.5, but the thrust bearing is on the #5 main rather than the #3, and it doesn't look like they machined the crank to accept a #3 thrust...
I suppose we could chuck up the crank on the lathe and machine it to fit. The phase 2's cranks have a different throw than the phase 1's? Or is it just the rods are longer? If that was the case, could I use the phase 2 rods on the phase 1 crank?
I'm feeling a bit phased...
Old 10-15-2008, 02:09 AM   #8
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
The only differences are:
Phase I EJ25 crank: 79mm stroke, 48mm rod journals, thrust bearing located on #3 main bearing.
Phase II EJ25 crank: 79mm stroke, 52mm rod journals, thrust bearing located on #5 main bearing.
So no, you wont be able to use the Phase II rods on the Phase I crank.
IIRC, you need to have the block machined for the Phase II crank, not the crank machined for the block.
~Josh~
Old 10-15-2008, 07:22 PM   #9
WoodsWagon
Member#: 180769
lots of junkers
So the phase 2 connecting rods are longer than the phase 1's, and the pistons are shorter by the same amount? Mabe to offset the piston slap issues that the phase 1's had.
So... If i put my phase 2 SOHC pistons on my phase 1 rods, the installed height wouldn't come all the way up the bore... Which would lower my comp... But completely fubar any quench that's supposed to happen in the heads.
Hmmm.
Old 10-15-2008, 10:58 PM   #10
quikcobra
Member#: 175246
Good thread what are the years of the phases? I got a impreza rs 2.5 sohc motor i was going to use the ej20 heads and gt30r turbo, but its good to get all this info
quikcobra is offline   Reply With Quote
Old 10-15-2008, 11:14 PM   #11
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Hmmm.
NO!
The rods have different crank end journals.
Old 10-17-2008, 09:20 PM   #12
paurio.tt
Member#: 169659
1997 Legacy GT
Red
Most late 90's 2.5 DOHC engines are phase 1. I think the LGT used it from 97-99, and the RS used it 97-98(not 100% sure). I'm not sure about the forester, but I'm sure it's around those years. One thing I'm sure of is that the RS SOHC engines are stage 2.
Old 10-18-2008, 12:32 AM   #13
ballitch
Member#: 74907
98 cam'd EJ251
Hmmm.
I put Phase II pistons in my Phase I EJ25, with the stock rods. Piston is below deck about .20-.25 mm. Not really enough to screw you up too badly, but it also lets you run a thinner HG to keep your quench. I used the Thick DOHC MLS gaskets because I was dumb. Only reason I did that was because of the higher lift of my spicy delta cams I am using.
If the stock Phase II pistons in a Phase II block, are flush with the deck, and have valve reliefs. You should be able to run the thin phase II HG with no problem, which is what i'll be doing...
~Josh~
Feeler EJ22T block and phase 1 2.5 crank for 2.35 stroker 69subaru360 Engine/Power/Exhaust 8 03-24-2010 03:01 PM
phase 1, 2.5 rods wrxzzz Built Motor Discussion 4 02-06-2007 10:03 AM
raced an STI today in my cobb 2.5 vf30 wrx anthonyrb98 Off-Topic 44 03-09-2005 12:30 PM
04 JDM Sti headlight in an 04 2.5 RS? digi Interior & Exterior Modification 11 11-30-2003 05:18 AM
