Old 10-14-2008, 01:14 AM   #1
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
Default How do you adjust the light on the DIY projector bugeye?
projectors are in, do you still use the stock adjuster to adjust the light?
qualityracer is offline   Reply With Quote
Old 10-14-2008, 01:17 AM   #2
jaypt802
Member#: 149730
2002 Impreza WRX
we did it on a friends car with the stock adjuster and it worked fine!!!
jaypt802 is offline   Reply With Quote
Old 10-14-2008, 02:29 AM   #3
Handsdown
Member#: 29355
uhh...
i can't use the stock adjuster on my DIY bugeye projector because i replaced the oem rear housings with ebay covered with oem fronts and made my own adjustment system.
that said, my lights kick ass and are aimed pretty well(not perfect, but safely usable and legal).
however if you mounted your projector to the stock optic reflector structure, you can adjust x(height) and y(left/right) axis with the stock adjustment screws.
if you mounted yours differently, or need to adjust z axis or are misaligned outside the physical limits of the stock adjustment, you'll need to remount or readust with a different mechanism or method.
you did not include NEARLY enough information to get a definitive answer.
Handsdown is offline   Reply With Quote
How do you post your logs on the forum? plus plus plus UTEC 9 08-27-2009 11:26 AM
Besides forums and youtub and like sites, how do you spend your time on the internet? lag Off-Topic 19 07-30-2009 08:21 PM
How do you get fog lights on with parking lights on only... Phreaker Impreza Forum 10 01-30-2008 03:03 PM
('93-'01) how do you adj. head lights on a 2.5RS? wop Impreza Forum 4 07-12-2001 02:36 PM
How do you raise boost levels on the WRX? mastervic27 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-02-2001 06:04 AM
