Old 10-14-2008, 02:40 PM   #1
resideinva
Member#: 179641
2005 LGT Wagon 5spd
RBP
Default PLEASE HELP! stuck on oil filter
ive been trying for over an hour to get this ****ing thing off. ive used vice grips, channel lock oil filter wrenches. this ****er wont move. ive crushed the hell out of it so theres no reusing it anymore. why the **** wont this thing come off?!?!
anyone ever had this kind of problem? i change my own oil and i KNOW i didnt put the damn thing on that tight.
how can i get it off?
resideinva is offline   Reply With Quote
Old 10-14-2008, 02:51 PM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
take your oil cap off just to prevent any vaccuum, slip something grippy on your filter like a rubber glove for grip...eat your spinach!
fastnoypi is offline   Reply With Quote
Old 10-14-2008, 02:58 PM   #3
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Go find one of these... if you can't get it off with that, burn it... lol...
Large channel locks will do the same, but they need to be the large ones..
Old 10-14-2008, 03:03 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
sounds like you put it on much too tight though... Don't do that again! The rubber seal expands, so if you have it just tight enough to seal, it will tighten up soon after it has oil running through it. If you crank it down a turn or more after the seal touches, it isn't coming off again easily!
anyway, pound a long screwdriver through it and wrench it out with that.
Old 10-14-2008, 03:09 PM   #5
ptirmal
Member#: 82243
07' Acura TL-S
I bought this filter wrench off ebay, it's a claw that grips tighter as you turn it as long as there is resistance, best one I've ever used... then my friend borrowed it and lost it
ptirmal is offline   Reply With Quote
Old 10-14-2008, 03:15 PM   #6
paktinat
Member#: 155025
2004 WRX
for a messy solution:
Drive a crappy screw driver through the filter, like this:
Code:
it will give you more torque on the filter but it will make a mess.
paktinat is offline   Reply With Quote
Old 10-14-2008, 04:02 PM   #7
Feign
Member#: 68604
06 STi
That's what I have. Uses a 3/8" drive ratchet...works great on RS motors thanks to the horrid header runner placement.
Feign is offline   Reply With Quote
Old 10-14-2008, 04:27 PM   #8
resideinva
Member#: 179641
2005 LGT Wagon 5spd
RBP
lol i thought about everything! and i HAD a pair of those..but cant find them. i HAD a pair of HUGE channel locks, couldnt find them. i borrowed a pair from the maintenance man but they STILL didnt work. that son of a bitch was on there good!
Old 10-14-2008, 04:32 PM   #9
resideinva
Member#: 179641
2005 LGT Wagon 5spd
RBP
thanks guys for the input.
that was the most frustrating thing ive ever had to do on the subie so far. exhaust nuts and changing the spark plugs combined had nothing on that
i bent 2 screwdrivers trying to get that **** off. but i got
i def didnt hulk it on there this time haha
the girl upstaris from me was joking me though...
"changing oil is nothing, even i can do that!"
i wish i would have taken a picture of the filter after i finally got it off. i have to drive the screwdriver through it 4 different times!
it was tore up from the channel lock and he hammer and everything else. **** was crucial. i should have saved it as a reminder to never over tighten it again...
Old 10-14-2008, 06:02 PM   #10
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
did you lube the rubber seal this time?
crampfan is offline   Reply With Quote
Old 10-14-2008, 08:00 PM   #11
resideinva
Member#: 179641
2005 LGT Wagon 5spd
RBP
yeah i always. i never do anything any differently than i always have. so idk why it got locked on there so tight. i dont put them on there that tightly.
the ONLY thing that is different about last oil change and anyother is tht type of oil i used. i used royal purple 5W 30 last time. i dont think that would make a difference though...
Oil leak on oil filter? alenk37 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-15-2009 03:29 AM
Help! Need an oil filter! rirwater Bay Area Impreza Club Forum -- BAIC 5 02-15-2003 05:54 PM
Question on Oil Filters? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-08-2002 12:47 PM
Help! Q: about oil filter type??? RS-LOVER Service & Maintenance 9 11-09-2001 02:11 PM
('93-'01) Part number on oil filter Peaty Impreza Forum 4 06-04-2001 01:40 AM
