#226 |
Member#: 218997
South East
Vehicle:07 WRX Mikey Tuned JE/FSR built,35r 1300c |
Just installed my VF-48 on my 07 WRX Wagon with these mods. Lager TMIC,650cc Injectors,TBE With high flow cat, Exhaust Mani PnP, Crossover pipe GS, Uppipe, 255 Fuel pump, Intake Man and TB PnP with TGVs Deteted, EBC, 8mm spacers between the TGVs and heads plus a Pro-Tune with OS Equals > 280HP and 330TQ On a Mustang Dyno with 18lbs of boost and I think 75 to 80% duty cycle.
#227 |
Member#: 153715
Vehicle:06 FXT 6spd 20g &98Outback Wagon x2 |
Nice numbers! What was your peak boost?
#228 | |
Member#: 218997
South East
#229 |
Member#: 119693
Vehicle:1995 L w/ ej205 Aspen White |
#230 |
Member#: 236092
NESIC
Vehicle:2004 wrx full exhaus vf48 aps big tmic nstuff |
Sure, but I only got a hard copy, let me ask Mike if he'll email me a jpg like the last tune. if he's too busy (which I wouldn't be surprised) to get back at me anytime within the next day or two I'll post a pic of the printout...
#231 |
Member#: 170697
NESIC
let's see some more 2.5l vf48 dyno graphs and mod lists ..please.
![]() btw...It's not installed yet, but I chose a vf48 for my 2006 wrx because the 5 speed tranny would be in serious risk if I went bigger. I'm on a low budget and given the small issues with the vf39 and vf43 I looked for a vf48 or an hta68 to replace the td04. I found a good low miles vf48 for the current going rate, right here on NASIOC from another member (thx). To my knowledge, the vf48 has no issues, other than a view folks who say it drops off at redline. I'll post some numbers in a few weeks... ![]() |
#232 |
Member#: 170697
NESIC
![]() 2006 wrx... VF48....307/341 ![]() |
#233 |
Member#: 134273
Vehicle:04 VF 48 P&P 289 WHP 275 WTQ |
^Wow
![]() ![]() Last edited by Rudywrx04; 09-04-2010 at 12:01 PM. |
#234 |
Member#: 92585
Vehicle:2005 Saab 9-2x Aero 13.6@100 EJ205 VF48 93Oct |
That's pretty typical numbers for a 2.5L with a VF48 and good supporting mods. Nice power. Seeya later 5 speed =D
#235 |
Member#: 149604
Vehicle:2006 Limited WRX OBP |
#236 |
Member#: 103399
E. Canada
Vehicle:2009 Stripped STI Dirty White |
#237 |
Member#: 92585
I've also seen on 06 WRX w/ VF48 put down 316/360, run 12.2 in 1/4, do lots of autox's, but guess what one time in third gear at 2/3 throttle and the tranny blew. It's not a matter of if its a matter of when. I completely agree that driving it well can definitely make the transmission last longer, but it won't last forever under that power, obv.
#238 | |
Member#: 170697
NESIC
jna intake gimmick inlet vf48 sti tmic invidia downpipie jna catback walbro 255 fuel pump 1 step colder ngk plugs dw 750 injectors v2 access port ![]() |
#239 |
Member#: 92585
good list. how hot does your STi TMIC get? I have an almost identical setup, cept 2.0L and the STi TMIC is just barely enough to keep her cool.
#240 | |
Member#: 170697
NESIC
btw... it's been 90 degrees plus around here in CT, my tune day included. ![]() |
#241 | |
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned |
#242 | |
Member#: 192526
Vehicle:2008 WRX FMIC/VF48 Red/Steel Grey |
Hopefully my 5spd can withstand the 20G and taking down the occasional Mustang/Camaro/Vette. Hang loose my fellow Michigander! |
#243 |
Member#: 193757
Well it's not just for the VF48. I have a complete STI converted Forester. I am not going to install a bigger turbo than the VF on the stock block, going bigger is sure route to blowing the motor. After the bullet proof motor build then that's a different story. Good luck with your 20g swap fellow Michigander!
#244 | |
Member#: 177399
NESIC
Vehicle:2005 Impreza WRX STi XXX Black |
If you're scared, drop in some CP forged pistons. If you're terrified, sleeve the block. ![]() |
#245 |
Member#: 193757
The block's the same, STI and XT. Cast pistons and with 80k on it. Bigger turbo NOT! Read my last post "bullet proof build" = bigger turbo, yes. Pretty much everyone that goes bigger on the stock block roaches their motor. Don't need sleeves unless you're going very big otherwise it's a waste.
#246 |
Member#: 155135
South East
Vehicle:03 115k Bugeye 285 AWHP 300 ft lbs torq. |
2003 WRX Stock EJ205
On a VF39 at 18.8 lbs, i made 277 AWHP 290 torque Via Mustang Dyno Invidia 1 piece Header with uppipeInvidia 3in V2 DP no cat Invidia N1 Exhaust w/ Resonator Injen Short Ram Intake Sti 565 Pinks Ebay FMIC Cobb 2.0 Protune by Carlos Ramini on Shell 93 pump Mishi. Rad. 07 STI Speed with sti Flywheel and Clutch NGK 1 Step Colder plugs New Dayco Sepentine belts Hallman MBC The car has not been on the Dyno Since i put the VF48 on about 20K ago. But the car has been tuned at 22.4 lbs of boost and pulls much harder to redline during WOT. need to get on a Dyno and get some results. Last edited by jerry curl; 09-21-2010 at 12:37 AM. |
#247 | |
Member#: 97785
NESIC
Vehicle:2005 WRX Stg 2 EFI Logics/CTSUBIE |
After looking at this thread, I may consider a VF48 on my 2.0 WRX for the time being...for the money, it's definitely a good upgrade. |
#248 |
Member#: 177399
NESIC
I considered a 48 for thr WRX, but after careful consideration, I'm going with a twin-scroll 30R for the '05 STI, and the WRX is getting my (totaled by Ex last year) 34K '06 LGT motor with my STI's current FP Green/Injen FMIC/850cc inj./walboro setup.
The WRX will have to be de-tuned to 300WHP at that point, to protect the 100k glass tranny while I save up for a new 6MT/DCCD Pro for it, but it'll be big fun for next winter, at any rate. So far, so good. At only $6K, the WRX left me money to play with-knock on wood, lol!! XXX |
#249 |
Member#: 240792
South East
Vehicle:04 AW STi Stage ? 04 AW FXT Stage 3 |
does anyone know what i can expect from this setup with a vf48...? i bought an 04 sti with a spun bearing and blown vf39, so im replacing both.
specs: 04 sti, brand new short block perrin crank pulley oem gaskets/arp head studs zerosports thermostat (160 F) and on 93 octane these came with the car and i dont know the brand or really anything about them: I THINK 3 inch exhaust from turbo back, im assuming a stock uppipe, and aftermarket intake with a cold air hose ran to fog light cover im pretty sure everything else is/will be stock... kinda tired right now and cant think. i will be using an hks ebc and opensource tune. i know it depends on the tuner and several other things but im just looking for a ball park figure. |
#250 | |
Member#: 170697
NESIC
welcome to the VF48 club ![]() I like the guessing game... let's see you've got: sti uppipe (catted I think, not sure) vf48 sti tmic cai 550 injectors turbo back hks ebc stock fuel pump stock plugs pro tune I'll say 285hp / 309tq, mustang. Good luck with tune..post the real numbers. ![]() |
| Thread Tools | |
| Display Modes | |
| Should I swap VF39 for the VF48 on 03? | guru_method | Factory 2.0L Turbo Powertrain | 24 | 07-31-2010 02:28 PM |
| Deleting the weapon thread.. and the whining thread about me locking it is even lamer | Fish | Texas Impreza Club Forum -- TXIC | 14 | 07-01-2010 12:29 PM |
| What is the max boost for the VF48? | Tuned200 | Factory 2.5L Turbo Powertrain | 14 | 02-17-2009 04:59 PM |
| Quest for 11's in the VF48 Saabaru (How much more can I get out of my VF48?) | cireturbo | Factory 2.5L Turbo Powertrain | 30 | 09-24-2008 01:32 AM |
| Why did the 'Discsussion' thread for the SOA recommendation thread get closed? | left footed whooten | News & Rumors | 6 | 09-05-2006 12:47 PM |
