Old 09-18-2010, 03:00 AM   #251
WRX_FTW
Member#: 240792
04 STi RIP, 04 FXT
Stg 3, 02 SRP WRX 37k
Originally Posted by makeawish View Post
welcome to the VF48 club
I like the guessing game...
let's see you've got:
sti uppipe (catted I think, not sure)
vf48
sti tmic
cai
550 injectors
turbo back
hks ebc
stock fuel pump
stock plugs
pro tune
I'll say 285hp / 309tq, mustang.
Good luck with tune..post the real numbers.
sti uppipes are uncatted.
anyone know of the cheapest/best investment for the most additional power on this setup?
WRX_FTW is offline   Reply With Quote
Old 09-18-2010, 03:21 AM   #252
TwistaDEEZ
Member#: 203970
02 WRB WRX JDM6spd
207+rotated 30r coming:)
some dw800cc or bigger injects, and walboro 255lph fp and tune on e85
TwistaDEEZ is offline   Reply With Quote
Old 09-18-2010, 12:19 PM   #253
makeawish
Member#: 170697
I agree with injectors and fuel pump, I went with dw 750's and the walbro255.
e85 is a committment. It's great if it's available everywhere you drive. for me it isn't.
you may also want one-step colder plugs to help prevent predetonation.
makeawish is offline   Reply With Quote
Old 09-20-2010, 03:41 PM   #254
jaegmeister
Member#: 236092
2004 wrx full exhaus
vf48 aps big tmic nstuff
Originally Posted by jaegmeister View Post
Sure, but I only got a hard copy, let me ask Mike if he'll email me a jpg like the last tune. if he's too busy (which I wouldn't be surprised) to get back at me anytime within the next day or two I'll post a pic of the printout...
as promised, a bit latem, albeit (gimmick inlet upgrade is also one of the differences between the red and black here. stock one had a leak when black dyno was graphed)
jaegmeister is offline   Reply With Quote
Old 09-20-2010, 03:43 PM   #255
jaegmeister
Member#: 236092
^it has a vf48, but the chart says vf43, not that there's much difference.
Old 09-21-2010, 02:25 PM   #256
WRX_FTW
Member#: 240792
04 STi RIP, 04 FXT
no e85 around that i know of... so that part is out.
Old 09-26-2010, 11:51 AM   #257
Member#: 205037
2009 STI OBP NitLif
365 AWHP, 382 AWTQ
there are websites that show you the nearest station for E85, if you put in your address.
Ge@rhe@d is offline   Reply With Quote
Old 01-12-2011, 08:56 PM   #258
Squillo
Member#: 193400
2016 Subaru WRX
Bluuu
im kinda stuck right now dont know if anyone can help me. this is where im at
Car:02 wrx
Tuner: Paul
Dyno: mustang
Peak Hp at rpm:316Hp @ 6500 rpm
Peak torque at rpm: 283 @ 4400
Baseline hp/tq for a stock on same dyno: 220/230 @16.5 PSI
Target Boost:18
Target AFR: 11.2
Fuel:gas 93 premium octane
Driveline Modifications: stock
Suspension Modifications: stock
Engine mods:
vf48
DW650
Walbro 255
GMS turbo inlet
GMS after maf
Short ram intake
erz catless up pipe
helix catted down pipe
JNA 3in catback
Hallman mbc
ajw/ssac fmic
NGk 1 step colder plugs
Hks ssqv bov
my clutch started slipping so now im swapping it for a act hdss and my hks bov is leaking so im going back to oem. Now im going to get a retune by sti mikey soon and i want more power but dont wana spend a lot more money. Has anyone see significant gains from a pnp on a vf turbo? im trying to decide if i should look into a fphta68 ported for around $1000 or just pnp my vf48 for $200. i know the hta68 will be more power but my vf did pretty good so will the pnp let me hit boost earlier so my power is there quicker. Im leaning torwards just pnp the vf48 because im also worried about the hta68 breaking my 02 trans. which im already past breaking point.i think im going with 20psi this time and ill probably pnp my IM and do tgv delete.
Squillo is offline   Reply With Quote
Old 01-12-2011, 11:14 PM   #259
jaegmeister
Member#: 236092
I'm not sure on the gain offered from a pnp, but your tune and power seems really strong for a 2.0. have you considered headers? I got my Perrins used for $200.
Old 01-13-2011, 12:42 AM   #260
Squillo
Member#: 193400
2016 Subaru WRX
Bluuu
Thats actually what im thinking about now, instead of spending $1000 on a turbo I can spend like 500 on a turbo pnp and some pnp'd headers or x over pipe.I'm trying to get the most power out of my current setup, but another tuner said go for the hta68. What else can I do with wat I have to make power I know going from 18 psi to 20 will increase my numbers.the only other thing I can do is get a catless dp.
Old 01-13-2011, 01:40 AM   #261
jaegmeister
Member#: 236092
What about blow thru tube? rackin my brain... cant' think of much else. Maybe a higher flow IC? Reverse intake manifold, if you're willing to do the work required for TGV deletes.
Old 01-13-2011, 02:02 AM   #262
Squillo
Member#: 193400
2016 Subaru WRX
Bluuu
Blow thru tube? Im considering tgv deletes if I can do it myself I don't think I can do a reverse IM but I didn't know it increased power. Well I dont wana spend a lot of money so it looks like I'm just going to do some basic stuff I aiming for 330whp and want to hit full boost around 3500rpms.
Old 01-13-2011, 03:08 PM   #263
jaegmeister
Member#: 236092
It would be cool if you could score a meth kit used also. Since you already run the fmic i was thinking blow thru tube. You should look into it. Im not certain of all the benefits, but it might be worth it.
Old 01-14-2011, 01:56 AM   #264
Squillo
Member#: 193400
2016 Subaru WRX
Bluuu
I don't know much about blow thru tubes I just saw a pic of it but how do you run a intake with it. And I was always wondering about getting a meth kit but that's a spray so the power will only be there when I use it? I can either spend 1000 on my current set up and add a ewg pnp my headers intake manifold turbo and tgv deletes spool early and make a lil power or spend 1000 hta68 and spool early and make a lot more power.
Anyone know the highest number for a vf on 93pump gas?
Old 01-14-2011, 11:00 AM   #265
jaegmeister
Member#: 236092
Its not a spray like nitrous. Its a programmed injection using your tune that injects water/methanol (at WOT I assume) to lower intake temps, increase compression, and prevent detonation/ preignition. I believe it allows for more agressive timing. You would see 330 hp easy. correct me if im wrong.
Old 01-15-2011, 05:40 PM   #266
Squillo
Member#: 193400
2016 Subaru WRX
Bluuu
yea id like to run a meth kit but i dont really track my car and its already at 137k. im thinking of just doing some more exhaust stuff with a pnp intake and turbo and go up from 18-20 what ever i make with that i should be happy. how safe is running meth tho i know you have to use a fail safe incase you run out of meth. with all the parts i already have i dont have much room for more power unless i upgrade the turbo.
Old 01-17-2011, 11:39 PM   #267
crash#2
Member#: 112128
2002 wrx
sedona red pearl
MY CAR WAS JUST TUNED BY DOUG AT TOPSPEED! previous setup was 2.0 with pink injectors vf48 255pump sti topmount helix catted dp helix up 3port ebcs surewin catback v2. made 289whp-270wtq. now the car has a 2011 wrx shortblock, tuned by doug again. this time it put down 300whp-325wtq. im very pleased. doug always does the most fantastic work!
crash#2 is offline   Reply With Quote
Old 01-26-2011, 03:12 PM   #268
sensinitas
Member#: 131061
2006 CGM WRX Wagon
Stage 2-Protuned
I've had a brand new VF48 sitting in a box in my garage for 9 months now. In all honesty - I'm too worried about the 5mt in my 06 WRX going bye bye under the power, and I'm in NO position to replace it if it does.
Does anyone have some real world mileage numbers while running a VF48 setup?
Is 300whp the magic number?
Talk me off the ledge! LOL
sensinitas is offline   Reply With Quote
Old 01-26-2011, 03:49 PM   #269
makeawish
Member#: 170697
I hit 307 whp and 340 wtq with my vf48 and the 5 speed mt on my 2006 wrx. I've only gone about 3k since the build, but have had no slippage or any problems. I don't launch and don't 'speed slam' during shifting.
I'm not real knowledgeable but I've heard that unless your beating on it 300 is no problem for the 5 speed.
Hook it up, get tuned and post up the dyno numbers !!!
Good luck.
Old 01-27-2011, 10:46 AM   #270
shatteringstar
Member#: 149604
2006 Limited WRX
Sensinitas, just do it. u'll be fine. a vf48 is by far not an extreme to worry about ur Trans.
shatteringstar is offline   Reply With Quote
Old 01-27-2011, 12:41 PM   #271
sensinitas
Member#: 131061
2006 CGM WRX Wagon
Stage 2-Protuned
I hit 307 whp and 360 wtq with my vf48 and the 5 speed mt on my 2006 wrx. I've only gone about 3k since the build, but have had no slippage or any problems. I don't launch and don't 'speed slam' during shifting.
Good luck.
Yea I'm pretty easy on the car. It's NEVER been launched, and I learned the day I bought it you can't hard shift it.
I just keep reading that 300whp is right around the magic number for the trans. It's not a matter of "if," it's a matter of "when." And as I sit right now, I'm in no position to be replacing the tranny.
I might sell the VF48 (it only has 250 miles on it...) and use the money for some coilovers or wheels. Hmmmm....
Old 01-29-2011, 10:32 PM   #272
crazyasianwrx
Member#: 142013
2006 wrx tr
san remo
i put about 10k miles on my 06 wrx since i installed and tuned 1.5 years ago. so far no problems at all. most of those miles were pretty easy. car made 290whp/330wtq on EFI's mustang dyno.
put it on and the best advice is to drive smooth.
crazyasianwrx is offline   Reply With Quote
Old 01-29-2011, 10:35 PM   #273
jaegmeister
Member#: 236092
And always go with a stock clutch for this setup...
Old 01-30-2011, 03:07 PM   #274
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Ditto above and no power shifting. I wouldn't even power/ flat foot shift the 6 speed either. My FXT 5 speed held up well with the VF48 for a year until I blew 5th gear at 156 mph. Subaru fixed it for free. I then did the 6 speed conversion and sold my 5 speed swap.
Old 01-31-2011, 01:43 PM   #275
hammyt
Member#: 92585
2005 Saab 9-2x Aero
[email protected] EJ205 VF48 93Oct
I've had my VF48 setup for going on 1.5+ years and 15k+ miles, so far no issues at all. Knock on wood. Stock tranny & OEM clutch.
hammyt is offline   Reply With Quote
Should I swap VF39 for the VF48 on 03? guru_method Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 05-01-2016 02:20 AM
Deleting the weapon thread.. and the whining thread about me locking it is even lamer Fish Texas Impreza Club Forum -- TXIC 14 07-01-2010 12:29 PM
What is the max boost for the VF48? Tuned200 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 02-17-2009 04:59 PM
Quest for 11's in the VF48 Saabaru (How much more can I get out of my VF48?) cireturbo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 09-24-2008 01:32 AM
Why did the 'Discsussion' thread for the SOA recommendation thread get closed? left footed whooten News & Rumors 6 09-05-2006 12:47 PM
