Old 02-07-2011, 11:08 AM   #276
dizmax03
Member#: 230145
2008 Forester XT
Just got tuned yesterday morning at IAG. Jorge is a great guy to talk to and definitely tuned it nicely.
2008 Forester XT 5M/T (stock)
VF48 PnP by Grimmspeed
PW TMIC
stock injectors
AP2
Stock spark plugs
drop in panel filter
Grimmspeed EBCS
Grimmspeed PnP header, xpipe, uppipe
Maddad v2 dp catted
Maddad Whisper cbe
283/322 target boost of 18psi tapers to 14-15psi
dizmax03 is offline   Reply With Quote
Old 02-07-2011, 03:51 PM   #277
Kupkake
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
Trans? Graph?
Kupkake is offline   Reply With Quote
Old 02-11-2011, 12:50 AM   #278
blk25rsti
Member#: 211942
1999 2.5RS coupe wht
01 2.5RS coupe BRP
This is not a 48 but still in the family and there have been no posts for sometime. I would just like to post for reference to anyone thinking of doing the same setup or similar and am happy to answer questions about it.
320.5whp
318 lb/ft tq
Car went 12.80@110 slipping 4th gear @ 4600ft elevation
Only complaint was the lag
Went VF39 on a stock EJ205/ block and heads. Few bolt-ons, stock 5spd and stock Subaru original clutch double
Large eBay-ish topmount
38mm v band ewg
E85 fuel
ID1000 injectors
Invidia catless DP
Gimmick catback
21.5 psi peak boost tapering to 18 by redline.
blk25rsti is offline   Reply With Quote
Old 02-11-2011, 01:44 AM   #279
blk25rsti
Member#: 211942
01 2.5RS coupe BRP
Old 02-11-2011, 02:22 AM   #280
jaegmeister
Member#: 236092
2004 wrx full exhaus
vf48 aps big tmic nstuff
Originally Posted by blk25rsti View Post
Only complaint was the lag , stock 5spd and stock Subaru original clutch double
Only complaint was basically your entire drivetrain
jaegmeister is offline   Reply With Quote
Old 02-11-2011, 02:42 AM   #281
blk25rsti
Member#: 211942
01 2.5RS coupe BRP
Yeah a stronger trans/ clutch setup as well a 2.5L shortblock would have made
It more ideal. Fairly impressed with the numbers it put down both at the track and on the dyno. No longer have the car, but it's still going
Old 02-27-2011, 03:39 PM   #282
Squillo
Member#: 193400
2016 Subaru WRX
Bluuu
PW TMIC
stock injectors
AP2
Stock spark plugs
Grimmspeed EBCS
Maddad v2 dp catted
Maddad Whisper cbe
just wanted to know when are you hitting full boost with all that pnp work its gota be pretty quick.
has anyone seen a vf48 on a 2.0 make over 330whp with 93 oct. im at 316 now with only 18lbs. so im gona turn it up to maybe 22 and get the grimmspeed x over pipe id like to get that high just to see if the vf can do it.
Squillo is offline   Reply With Quote
Old 03-19-2011, 09:16 AM   #283
xrw1
Member#: 159772
06 WRX
obp
Default stock clutch?
how many 2.5L wrx owners have their stock clutch with the VF48? (stock tranny here)
Just wondering how much boost you are running at.
Mine started to slip badly above 20psi, I read some people have have stock clutch running at higher psi. Just wondering maybe my clutch is at the end of the line, but I don't want to upgrade to ACT because of shockload to the tranny.
xrw1 is offline   Reply With Quote
Old 03-19-2011, 12:53 PM   #284
hammyt
Member#: 92585
2005 Saab 9-2x Aero
13.6@100 EJ205 VF48 93Oct
If your clutch is slipping its likely dying/dead. The PSI doesn't matter, its the amount of load you are putting on the clutch and how much friction it has left. Sounds like you need a new clutch.
I'm running a stock replacement clutch instead of the ACT for the same reasons you listed above and I am at 20 PSI with no clutch slippage on my VF48, but I also have a 2.0L so my numbers are only 275/250 to the wheels.
hammyt is offline   Reply With Quote
Old 03-19-2011, 02:01 PM   #285
CatfaceType-R
Member#: 81102
Originally Posted by Squillo View Post
im kinda stuck right now dont know if anyone can help me. this is where im at
Car:02 wrx
Tuner: Paul
Dyno: mustang
Peak Hp at rpm:316Hp @ 6500 rpm
Peak torque at rpm: 283 @ 4400
Baseline hp/tq for a stock on same dyno: 220/230 @16.5 PSI
Target Boost:18
Target AFR: 11.2
Fuel:gas 93 premium octane
Driveline Modifications: stock
Suspension Modifications: stock
Engine mods:
vf48
DW650
Walbro 255
GMS turbo inlet
GMS after maf
Short ram intake
erz catless up pipe
helix catted down pipe
JNA 3in catback
Hallman mbc
ajw/ssac fmic
NGk 1 step colder plugs
Hks ssqv bov
so this dyno reads a stock STi at 220whp...you are on a 2.0 liter correct?
something doesn't add up, unless this is a really high correction factor
if you are at 316whp on a 2.5 liter, it would almost be possible, but still not work as you are on pump gas. Idk too many issues with your post for me to answer in my pea brain
CatfaceType-R is online now   Reply With Quote
Old 03-19-2011, 03:38 PM   #286
xrw1
Member#: 159772
06 WRX
obp
yeah i think there is a larger difference when you factor in the 2.5L.
I read stickies saying that stock tranny should be stock clutch. I think for the sake of not killing my tranny too fast the options are fairly limited. A 6sp is starting to look very expensive now
Old 03-19-2011, 11:05 PM   #287
jaegmeister
Member#: 236092
stock sti's, at least in the 04-07 MY range, make 200 whp on my tuner's mustang dyno. I'm making 280 whp at 17.5 psi with the vf48, full exhaust with ELH, big APS topmount, etc.
Old 03-30-2011, 10:19 PM   #288
GRUMPY514
Member#: 112285
2014 BMW 535i
Alpine White
How many of you guys are running meth on stock VF48s? Just picked up a 2011 and pondering this idea.
I'm going to be getting my car protuned sometime in the near future and am thinking about doing meth injection on it, the car would have the following
Full 3" catless TBE with straight pipes
Short ram intake
Cobb Acessport
NGK Plugs
Pretty much just your basic Stage 2 protune, I'm a little concerned about maxing out the injectors/turbo with running meth though? I would also be using the stock TMIC for this, anyone running a setup similar that could comment?
I know that meth would keep the IDCs down but enough to run it fairly safely? The reason I ask about using meth now is LATER LATER down the line this car will have a gt35 running meth.
Here is the car 80 miles on the odometer so far.
DOM III 07' in the back (My old one)
GRUMPY514 is offline   Reply With Quote
Old 03-31-2011, 11:53 AM   #289
Kupkake
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
If you plan to get meth later on, and your budget can fit it now, then get it now
Old 03-31-2011, 08:25 PM   #290
GRUMPY514
Member#: 112285
2014 BMW 535i
Alpine White
But is it or is it not smart to get it with a stock TMIC?
It's meth injection or a EWG setup.... I know meth will net me more gains. Perhaps both? Since either one will require a tune for sure.
Old 04-10-2011, 02:04 PM   #291
dizmax03
Member#: 230145
2008 Forester XT
In search of more power from my vf48. just picked up a set of modded 860cc injectors. gonna pick up an upgraded IWG from a buddy of mine. need to invest in a turbo inlet. invest in an intake .. probably cobb sf intake. install intake spacers and the a retune. anyone have any idea what i can potentially push the turbo to safely?
Old 04-10-2011, 03:18 PM   #292
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
I have a stock EJ255 and I am running DW 850's, TIH, hi flow filter in stock box and all pnp'd intake man., tgv deletes, pnp'd VF48 and GS pnp'd stock exhaust. It handles 22psi with a 4-5 deg. temp differential most days. It spools very quickly!
Old 04-10-2011, 05:20 PM   #293
dizmax03
Member#: 230145
2008 Forester XT
i dont have pnp intake manifold or tgv deletes.. prob will not do those.. did you do an upgrade on the iwg? what kinda numbers are you putting down?
Old 04-10-2011, 10:56 PM   #294
manitou
Member#: 193757
2006 XTI Limited
I swapped the tgv deletes and did the PnP stuff more for future mods but it doesn't hurt the vf48. Numbers are just that, my car was tuned on a heart breaker mustang 260/310, who knows what it would be on another dyno. This motor destroyed 5th gear of the FXT 5mt on top end pulls, so it makes good power and torque. I Also swapped in the full 07' 6 speed driveline. I would definitely do the GrimmSpeed pnp'd stocker exhaust.
Old 04-10-2011, 11:46 PM   #295
manitou
Member#: 193757
2006 XTI Limited
Grimmspeed pnp'd my vf48 so the did a bit of work on the IWG porting. I get some WG flutter around 20+ psi, but it doesn't hurt the power and holds boost it just sounds funny.
Old 05-23-2011, 10:45 PM   #296
PUMP XXVIII
Member#: 210872
'06 PPG EWG VF48WRX
Steel Grey
i really dont feel like looking through all 10+ pages of this thread so with that being said,
i am wondering if anyone has ran the vf48 on E85 on their 2.5l just curious as to see some numbers because i am thinking about keeping this turbo for now instead of going bigger
PUMP XXVIII is offline   Reply With Quote
Old 05-24-2011, 12:04 AM   #297
manitou
Member#: 193757
2006 XTI Limited
This is close enough, Forester XTi 07sti swap VF39 11.8@113 popping off TMIC 7.61@92 1/8th!!!!!!!!!!!!!!!! http://forums.nasioc.com/forums/show....php?t=2082058
Old 05-24-2011, 02:02 PM   #298
PUMP XXVIII
Member#: 210872
'06 PPG EWG VF48WRX
Steel Grey
ah thank you sir
Old 05-25-2011, 10:39 AM   #299
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Synolimit on his 09 with E85 hit something like +350whp.
scramjett is offline   Reply With Quote
Old 05-26-2011, 11:00 PM   #300
PUMP XXVIII
Member#: 210872
'06 PPG EWG VF48WRX
Steel Grey
does he have a thread on here or any dyno sheets or anything?
Should I swap VF39 for the VF48 on 03? guru_method Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 07-31-2010 03:28 PM
Deleting the weapon thread.. and the whining thread about me locking it is even lamer Fish Texas Impreza Club Forum -- TXIC 14 07-01-2010 01:29 PM
What is the max boost for the VF48? Tuned200 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 02-17-2009 05:59 PM
Quest for 11's in the VF48 Saabaru (How much more can I get out of my VF48?) cireturbo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 09-24-2008 02:32 AM
Why did the 'Discsussion' thread for the SOA recommendation thread get closed? left footed whooten News & Rumors 6 09-05-2006 01:47 PM
