Old 12-15-2011, 12:41 PM   #301
whozatguy
Member#: 179775
03 WRX/05 FXT
14 BRZ
I got my vf48 tuned a little while back at Cobb Tuning Plano, I love the new found power!
Car: 2003 WRX
Engine: 2.0 L
Milage: 102,XXX
Dyno: Cobb Plano's Mustang
Engine Mods:
VF48 turbo
Turbo XS TMIC
Cobb SF intake
Cobb catless tbe
Cobb bpv
Walbro 255 fuel pump
ID 750 injectors
Gimmick turbo inlet
3 port boost controller
Cobb turbo heat shield
Cobb AP tuned by Calvin at Cobb Plano peaks at 19.5 psi
Graph says vf39, but should say vf48
whozatguy is offline   Reply With Quote
Old 12-15-2011, 06:43 PM   #302
strange_magic
Member#: 259257
^ is yours the gold on blue? Would you happen to have a data log you could post or at least do to know what kind of timing on this tune?
strange_magic is offline   Reply With Quote
Old 12-15-2011, 07:05 PM   #303
whozatguy
Member#: 179775
03 WRX/05 FXT
14 BRZ
Yeah that sounds like my car, gold rpf1s. I don't have any data logs saved at the moment and to be honest, I don't know what kind of timing I'm running. If I get a chance this weekend I'll look into it. I need to replace my front O2 sensor and hunt for a little vacuum leak as well
Old 03-21-2012, 11:16 AM   #304
bigpelo
Member#: 296532
2002 WRX EJ207 swap
Car: STi 2006, 2.5L stock internals
Millage: 92xxx
Mods: VF48, 850cc side feed injectors, DW200 fuel pump, K&N typhoon intake, 3'' TBE catted, EL headers, uppipe, 3-port EBCS
Gas: 94 octane
Dyno: Maha
bigpelo is offline   Reply With Quote
Old 04-16-2012, 03:13 PM   #305
sc00ter
Member#: 117767
2015 WRX
CWP
2007 WRX / 50k miles
- VF48
- STI TMIC / Y pipe / Air Splitter
- Perrin Turbo Inlet
- Grimmspeed 3 port EBCS
- SPT Intake
- COBB 3" TBE (catted)
17.5psi - 280whp/315ft-lb TQ @5200ft above sea level
My tuner made me an additional 19psi tune which put down 308whp/327ft-lb TQ IIRC. But he only recommended running that on occasion and only when it was sub 65 degrees outside.
sc00ter is offline   Reply With Quote
Old 04-17-2012, 04:57 PM   #306
wrxstage2
Member#: 149806
06 wrx tr
Vf48
Cobb sf intake
Cobb catless dp
Cobb cat back
Forge bpv
Cobb ap
284whp/334wtq tune by efi mustang dyno 19.5 psi
wrxstage2 is offline   Reply With Quote
Old 05-02-2012, 11:55 AM   #307
SkiWrex
Member#: 142559
05 Fozz XT VF39'd
05 PSM Fozz 2.5xs
I need honest opinions......I have an 02 WRX Wagon with 108k on the odo, and I have a friend selling the VF48, injectors, TMIC and fuel pump from his 2011 STi. They had around 4k miles on them when he took them off, and he'd probably give me a killer deal if I wanted them.
Just wondering if you'd think it'd be safe, and/or worth it to throw those on the old 02 wagon.
My first WRX was an 03, and I put the VF39 on it with supporting mods, and it was a blast, but that car had 60k miles when I did that.
I want to do this but I'm a little hesitant, this car is my DD and I commute 50 miles a day, so I'm sure it would kill my gas mileage. Anyways, come at me with your opinions.
SkiWrex is offline   Reply With Quote
Old 05-05-2012, 01:22 PM   #308
chucha
Member#: 306870
2003 WRX STI 2.0
If squeeze it into snot, as wheel forces can be removed?
On boost 1.5 each, can ride every day?
chucha is offline   Reply With Quote
Old 05-05-2012, 10:29 PM   #309
jaegmeister
Member#: 236092
2004 wrx full exhaus
vf48 aps big tmic nstuff
sc00ter and wrxstage2 are you guys running upgraded injectors/fuel pump?
jaegmeister is offline   Reply With Quote
Old 09-12-2012, 06:07 PM   #310
watson199
Member#: 215042
2006 wrx
2006 wrx limited
turboxs 4" downpipe
gimmick motorsports cat back
tgv delete
spt intake
walbro 255 fuel pump
3 port ebcs
vf48
sti intercooler
294hp 321tq mustang dyno at rs motors in burnsville, mn.
watson199 is offline   Reply With Quote
Old 09-12-2012, 08:10 PM   #311
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Originally Posted by watson199 View Post
2006 wrx limited
turboxs 4" downpipe
tgv delete
spt intake
3 port ebcs
vf48
sti intercooler
Respectable. And I like your choice of cars.
Dave D. is offline   Reply With Quote
Old 10-04-2012, 04:26 PM   #312
Reverend Rob Large
Member#: 301918
2003 WRX wagon
Equilibrium Tuning built hybrid
Perrin after-maf, inlet and intercooler hoses
STi TMIC
DW 650cc and Walbro 255
Hallman Pro RX MBC
STi UP
Perrin catless DP
SPT exhaust
275.6 whp and 295.8 ft-lbs @ 17.5 psi on 91 octane at EQ
Reverend Rob Large is offline   Reply With Quote
Old 10-04-2012, 04:56 PM   #313
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
2004 STi
vf48
Samco inlet
Harman Motive CAI
Grimmspeed EBCS
Grimmspeed uppipe
Maddad catted downpipe
SRS CBE
Walbro 255
Kartboy crank pulley
Cobb AP
stock TMIC and injectors
314whp 360wtq on 93 octane tuned by STI Mikey at TheShopCT
FCmaniac is offline   Reply With Quote
Old 10-07-2012, 04:39 PM   #314
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
2006 FXT-XTI full STI mechanical conversion 07 STI 6 speed/ R180
4th gear
Cobb AP v2
Stock EJ255
VF48 w/ WG welded shut, H/S PnP'd
Cobb SF intake
GMS inlet & AFTA MAF
ETS TMIC
GS EBCS
Killer B Holy Header w/ custom up pipe & Tial MVR EWG
Cobb full 3" custom catted exhaust w/ +12" resonator in mid pipe
Full 1.75" EWG exhaust
Walbro 400 E85 FP
Aeromotive FPR
Perrin Fuel rails
DW 850cc injectors
dyno. stock STI: 230 WHP
Junior tuned
Stock STI clutch let go at 440 WTQ, probably would have made more TQ and HP
2@ E85 pulls
93 pull
Old 11-17-2012, 02:20 AM   #315
paved1
Member#: 121704
07 WRX LTD
07 WRX Limited
K&N panel filter
Samco turbo inlet
Grimmspeed BCS
VF48 @ 20 PSI
STi TMIC & splitter
TGV delete
ID1000's
DW300 pump
Invidia V2 catless DP
SPT muffler section
Cobb AP
Pro Tune from Chris Black @ AMS Performance in W Chicago
(Tuner of the Alpha12 GT-R WR 1500 hp street car)
288 AWHP 324 ft-lbs on a Mustang Dyno
I will post dyno sheet, I'm trying to enhance it so that it is easier to read. If I can remember how to get it posted I will do that next.
AMS' shop is nothing shy of spectacular. I pulled in from StL and counted 7 GT-R's 2 full rally race prepped Evo's, a couple of street Evo's and a few road race Porsche 997 911's. Needless to say I felt a little under gunned pulling in with my all but stock lil' 07 WRX, but they treated me with the utmost respect and acted as if my car was just as important as the guy getting the $63,999 Alpha10 GT-R pkg. Really nice folks. My only regret is that I didn't ask for the tour, they said I could be there for the dyno session but I missed the morning train from the city to get back out to W Chicago (my bad and my bummer).
They even saved me some $ from the original estimate AFTER they found more work that had to be concluded before she was dyno worthy AND they threw in an AMS beanie on top of all that. Can't beat that with a stick.
I definitely love the new found power, I'm not beating on the car (I have never driven like that) but I want to make sure all is tight and good before I give her the full beans. There is still a little more lag than I would have thought would be there and I will be in discussion with them as to how to get rid of this as my intentions were to build around throttle response not top end or dyno numbers.
All in all AMS is an A#1 shop that I would recommend to anyone. A little on the pricey side but you know- and this is why I stayed with them after the estimate- you get what you pay for. I knew they could handle any and every little thing that might come up, which did and they did. The only used part I had was the STi TMIC and they found a tiny hole in the Y pipe that the previous owner was using to inject (prolly meth, I dunno)and welded it shut pronto, another shop probably wouldn't have even found that and just tried to tune around it. Bravo AMS, bravo. With all the in house engineering and fab work, not to mention the absolute piles of trophies including anything from the SCCA runoffs to Time Attack, I had no doubts my girl was in good hands. And this was before I read anything about Chris Black's reputation as a tuner, I just found his praise on the Injector Dynamics certified BadAss list this evening, after all was said and done. Lucky me!
All around great experience, knocking on wood that it stays that way. Like I said I don't beat on cars but I do push it frequently. I'm guessing my next money will be in Tranny work but I need Suspension and wheels and tires next, so the 5 speed has to hang on for awhile yet.
The first thing I did was the brakes, SS lines, hawk pads, quality slotted rotors (in front anyway) EBC I think, and that German Blue brake fluid. Figured a car has to be able to stop well enough first before throwing power mods at it. Now it needs to handle as well as it goes, debating coil overs VS Eibach Pro-kit (and sways) witsome quality dampers (preferably adjustable). Then wheels and tires and after all that if I'm not broke Maybe MAYBE I'll get some of the dings taken off her...
paved1 is offline   Reply With Quote
Old 11-17-2012, 02:22 AM   #316
paved1
Member#: 121704
07 WRX LTD
All that being said, I am woefully under knowledgeable about the differences in dynos and how they read. Mustang dynos read low? Thats the feeling I'm getting from reading old post after old post. I am just curious what this might read on a more accurate dyno? 300 AWHP maybe? 350 ft-lbs torque? I dunno, anyone with the knowledge please chime in, love to get a more accurate number and a real world figure. Thanks to anyone that might help with that.
Old 11-17-2012, 06:16 AM   #317
FCmaniac
Member#: 142029
2013 Forester
^^I'm assuming this tune was on 91-93 octane? Since you have 1000's, are you getting retuned on E85?
Re: your question about dynos, take it to the track to get a better idea. If you trap 108-109 as it sits on pump gas, then you have a strong VF setup. 110+ is exceptional on pump with a VF. If you were on E85, then 110-112 would be expected and you could run a high 11.
Old 11-17-2012, 09:07 AM   #318
paved1
Member#: 121704
07 WRX LTD
Yes 93 octane. I was thinking about going to e85 in the future, when I did more research because it looks like there are significant gains to be had. Been reading about the stock 5 speeds though, not liking what I'm seeing but again I don't rape the go pedal, so I'm hoping it will last awhile still. I JUST NEED MORE THROTTLE RESPONSE, like my original 05 STi. Wheres the hold up to that in my system here? I've researched the hell out of this and thought I bought all the right parts, it just still has that split second hesitation my 05 did not have. I want that instant GO back.
But all in all , I thought these were great numbers, the daily driving of it hasn't changed one bit, well. its a little louder, but with that perfect SPT boxer rumble I'm OK with that, it's not a droner like a Honda with a fartcan. (And don't get me wrong, I love Hondas, I owned a 95 Civic Si for 11 years).
Old 12-05-2012, 07:29 PM   #319
saundc2
Member#: 237713
2002 WRX Wagon
I have an 02 wrx 2.0L and just bought a vf48. I'm trying to decide what to do for a tune. It looks like a Cobb access port runs $600 new and a Cobb Pro-tune is $400 so I'd be looking at $1000 to do it right. That seems like a lot to pay especially considering the $400 for a tune is only going to last me until I decide to mod further. My friend has a Tactrix cable that I can borrow and he knows someone he claims can tune the car for me. Does anyone here have experience with street tuning through a Tactrix and if so what words of wisdom do you have about going this route vs getting a dyno tune? I was also wondering if anyone has a similar set-up to me and wouldn't mind sending me their map so I have something to start off with. My mod's are as follows:
stock 2.0L block
vf48
05 STI TMIC with y-pipe
07 STI injectors (I believe they are 565cc, same as pinks)
SPT Intake
STI catless uppipe
3" catless TBE
Grimmspeed 3 port ECBS
Walbro 255lph FP
From reading this thread it sounds like I maybe should have gone with DW 650cc injectors. Somebody mentioned the 06 wrx injectors (560cc?) will be running at 97% IDC with this turbo. I plan on getting a wideband O2 sensor so I can monitor my AFR that way if I do toast the injectors I can shut it down before I run lean and kill the turbo. Any feedback on Tactrix cable tuning would be appreciated, and as I mentioned before if someone has a map I can base my tune off of I'd appreciate that as well
Thanks
saundc2 is offline   Reply With Quote
Old 12-05-2012, 07:30 PM   #320
saundc2
Member#: 237713
2002 WRX Wagon
Also, I plan on running on 93 octane
Old 12-06-2012, 12:25 AM   #321
manitou
Member#: 193757
2006 XTI Limited
What headers are you running? Fuel wise you have tons of headroom for a VF! You're good for a 30r with your fuel set up. Spark plugs 1 step colder?
Old 12-06-2012, 05:51 AM   #322
FCmaniac
Member#: 142029
2013 Forester
stock 2.0L block
vf48
SPT Intake
STI catless uppipe
3" catless TBE
Walbro 255lph FP
Thanks
1. There is nothing wrong with getting a road tune or tuning opensource (as opposed to using a Cobb AP). The key is finding a good tuner. I wouldn't trust some guy just because a friend knows him. I'd try to do as much research as possible to find the best tuners in your area.
2. You don't need to worry about the turbo being killed from a lean AFR. You need to worry about the motor being killed. As long as the tune is safe and within the limits of your fuel, you should be fine.
Old 12-06-2012, 09:08 AM   #323
saundc2
Member#: 237713
2002 WRX Wagon
Running stock headers and plugs right now
Old 12-06-2012, 09:12 AM   #324
saundc2
Member#: 237713
2002 WRX Wagon
1. what's the best thread to find local tuners? I tried searching "tuner" within the midwest chapter. Most of what I found was people recommending shops for a dyno tune. I live in Ann Arbor MI.
2. I was under the impression that hot exhaust temps can kill the turbo (as well as the motor)
Old 05-23-2013, 07:10 PM   #325
SubaruWrxSTR
Member#: 199039
11 Sti Closed Deck
15 wrx CVT
Any new high number e85 Sti lately?
SubaruWrxSTR is offline   Reply With Quote
Should I swap VF39 for the VF48 on 03? guru_method Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 05-01-2016 02:20 AM
Deleting the weapon thread.. and the whining thread about me locking it is even lamer Fish Texas Impreza Club Forum -- TXIC 14 07-01-2010 12:29 PM
What is the max boost for the VF48? Tuned200 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 02-17-2009 04:59 PM
Quest for 11's in the VF48 Saabaru (How much more can I get out of my VF48?) cireturbo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 09-24-2008 01:32 AM
Why did the 'Discsussion' thread for the SOA recommendation thread get closed? left footed whooten News & Rumors 6 09-05-2006 12:47 PM
