Old 10-14-2008, 10:08 PM   #1
MystikalDawn
Member#: 191670
Default same tire thread all around for AWD?
Hey, i have a 2007 Ram 4x4 and when i got it the dealer told me not to put the truck in 4x4 if the tire thread on the back was lower or higher then that on the tires on the front...or vise versa, so my question is this, does the same apply to these impreza's where they are AWD?, you should have the same tire thread siza all around or else damage will occur?
Thanks, Trent
MystikalDawn is offline   Reply With Quote
Old 10-14-2008, 10:10 PM   #2
maxpower45
Member#: 84445
2002 WRX Wagon
SRP
Yep, all four tires should be the same with nearly identical tread depth. Otherwise you risk damaging the differentials.
maxpower45 is offline   Reply With Quote
Old 10-14-2008, 10:14 PM   #3
wrxskier18
Member#: 88005
2002 WRX + NSX
Silver + Green
Yes, definitely have the same size tire with similar tread left. You can kill your center diff if you don't. That's one reason why rotating your tires is important. For the same reason, make sure to never have the car towed with just 2 wheels.
wrxskier18 is offline   Reply With Quote
Old 10-15-2008, 12:17 AM   #4
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
If its a part time 4wd system, its not meant to be used all the time. This means you should only use 4wd when you are on loose surfaces. You are NOT going to damage your diffs on loose surfaces if your tire tread isnt the same with a part time system...
gto7419 is offline   Reply With Quote
Old 10-15-2008, 08:34 AM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
^ He asked about the Impreza....
Old 10-15-2008, 09:48 AM   #6
gto7419
Member#: 44256
05 outback xt
He was misinformed about this truck by the dealership - I was clarifying for him..
Old 10-15-2008, 12:28 PM   #7
7th Subaru
Member#: 108245
'17 WRX Premium
ISM
We are on our 9th Subaru. All of them AWD. All tires should be of equal diameter, hence the importance of rotation.
I have had several trucks (Dodges, Chevys, Fords, Toyotas and Nissans) with part time 4wd. A 4x4 part time system, as gto7419 states, should only be engaged on 'loose' road surfaces such as snow, ice, gravel or dirt. Definitely not on dry pavement.
Trent, other than ground clearance, you will probably find the AWD Subie to be superior in most of the 'loose' that people drive in on the road (compared to a part time 4wd system like the typical pickup has).
7th Subaru is offline   Reply With Quote
The Winter Tire thread- all winter tire questions go here !!! [email protected] Tire & Wheel 6771 Yesterday 09:27 PM
WTB NJ: winter tires or all seasons for 16 inch wrx wheels snipe99 Private 'Wanted' Classifieds 1 10-29-2009 04:48 PM
WTB: Brake pads, all around for 05 STi.. ovrated Private 'Wanted' Classifieds 0 09-28-2007 03:58 AM
Wow, same 3 threads all day! DRNWAGN Forester Forum 5 10-22-2004 11:14 AM
well, its here! 275 hoosiers and 18x9 wheels all around for the M5 jmott Texas Impreza Club Forum -- TXIC 9 02-13-2003 10:55 PM
