Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 10-14-2008, 09:25 PM   #1
FDrif73r
Member#: 136389
Default 06 sti into 2000rs wireing question
Ok here is what I got. did a complete sti swap into my 2000rs including wireing harness and dash swap. The guy that I bought the 06 harness from did not include the fuel tank cord so i'm stuck with my swap.
I was thinking of just keeping my 2000rs fuel tank cord by just sodering the wires from the 06 sti on to the rs cord, but i have no clue on what wire goes were. Can anyone help. Oh and i have no experience reading a wireing diagram
FDrif73r is offline   Reply With Quote
Old 10-21-2008, 07:11 PM   #2
FDrif73r
Member#: 136389
does any one know where i can get this info from. I've tried all data and most of the Subaru technical sites with no luck.
Old 10-21-2008, 07:23 PM   #3
stoke
Member#: 164513
2001 2.5RS+EJ20+VF34
'13 WRX Special Ed
PM Brydon-- he'll be able to help.
stoke is offline   Reply With Quote
Old 10-21-2008, 07:51 PM   #4
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
06 STI fuel pump section
00 RS fuel pump section
bobjr94 is offline   Reply With Quote
Old 10-21-2008, 08:06 PM   #5
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
Look at the above diagrams. You'll need to get the controller and basically wire that into the system but double check to make sure everything is going where it needs to. You also might have to change some wiring on the fuel pump relay. I think I did with my swap.
mannac is offline   Reply With Quote
Old 10-22-2008, 11:49 AM   #6
FDrif73r
Member#: 136389
wow. that is great info to get the project going again
thanks again bobjr94
Old 10-27-2008, 12:19 AM   #7
FDrif73r
Member#: 136389
After a year of off and on work it finally paid off and my RSti finally came to life. There were times where I almost gave up but my wife geve me the moral support needed. man she souds beasty i couldn't belive it when i heard the first vroom it was like some when had taken a 100lb stone off my back. Now comes the simple process of putting it back together and the joy of completing a swap all on my own thanks to all the poeple that helpped with all the great info.
Old 10-30-2008, 03:17 AM   #8
FDrif73r
Member#: 136389
I just found out that if you disconect the air intake without disconecting your MAF connector your car will start for one or two seconds then the car will die. I was starting to get worried but as soon as i plugged it back in the car started up right away. Why is this? and is ther other tricks like these that I should know about
Old 10-30-2008, 03:37 AM   #9
civicej8
Member#: 95598
2002 wrx
nice man. let us know how you like it!!!
civicej8 is offline   Reply With Quote
Old 10-30-2008, 04:29 AM   #10
Conor
Member#: 107677
1993 MR2 - V6 swap!
1986 MR2 - 4AGE!
Wow! That's a complicated fuel pump system! o_O I'm just used to +B and Ground ...
Conor is offline   Reply With Quote
Old 10-30-2008, 06:41 AM   #11
JMack
Member#: 183773
1997 Legacy GT Wagon
Red
I believe this happens b/c the MAF is a blow thru sensor, and with the Intake plumbing disconnected, the vacuum that is normally subjected to the MAF causing positive airflow thru it, is lost. This causes the ECU to read that there is NO incoming air, and it cuts the fuel flow off to keep from a 100% Rich condition occuring.
I'm not sure though, just an idea.
JMack is offline   Reply With Quote
Old 10-30-2008, 09:01 PM   #12
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
sounds about right if the maf is out of the path of the intake, it is reading from the maf but the readings dont make sense so it panics. basically the same as if you just unplug the MAF, then there is no signal so it goes to limp mode and doesnt let you rev above 4000 or 4500 and car runs like crap overall
elislider is offline   Reply With Quote
Old 10-31-2008, 03:58 AM   #13
FDrif73r
Member#: 136389
very good info. i'm just putting everything back together. she should be out and about in a couple of weeks or so will keep you posted
STI radiator fan wiring question rayc Subaru Conversions 8 05-23-2010 09:38 PM
05 vs 06 STI ECM and wiring s3t Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 01-25-2008 04:27 PM
V7/8 into WRX wiring question?? 2000wrx Subaru Conversions 2 08-06-2005 12:46 PM
04-05 STi Cruise Control Wiring Question STiMULi Interior & Exterior Modification 0 07-27-2005 11:19 PM
Swap into 2000RS, Couple Questions. boofer Subaru Conversions 10 07-26-2005 05:18 PM
