Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 10-15-2008, 01:18 AM   #1
joejoe69
Member#: 126787
Chapter/Region: HIIC
2015 WRX STI
Crystal White Pearl
Default Project EJ18T
i don't normally post alot here but just thought i'd share this project in a place of massive subie traffic. enjoy
joe
http://www.rs25.com/forums/showthread.php?t=81773
joejoe69 is offline   Reply With Quote
Old 10-15-2008, 03:04 AM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Took me an hour or so to read all that thread, very nice indeed. I sure as hell wasnt envying you when you ripped out that harness...
Got me thinking about going turbo......eventually...
~Josh~
Old 10-15-2008, 07:57 AM   #3
joejoe69
Member#: 126787
2015 WRX STI
Crystal White Pearl
thanks,
yep, it was a bit of a journey to get her running. i was so pissed during the build when things went wrong. but in the end, it was worth it after firing it up and hearing her roar.
going turbo?...go for it!!
Old 11-18-2008, 12:35 PM   #4
racerjon777
Member#: 145242
1994 Impreza L
EJ20K powered.
You and I have similar mods.
The only issues ive run across are boost creep and the stock L clutch that screams at me every time boost hits 9psi or greater. I also asked you a question in that thread, but ill post it here too.
Why didnt you do a full standalone ecu?
Also, I have a custom intake that fits a clocked td04, specifically made for the 1.8l engine, its actually pretty trick, im going to get some better pics this weekend, but i just wanted to get your thoughts on FMU and also, did you end up keeping the stock L tranny?
racerjon777 is offline   Reply With Quote
Old 11-19-2008, 02:14 AM   #5
joejoe69
Member#: 126787
2015 WRX STI
Crystal White Pearl
check rs25 for my reply.
the boost creep is probably the wastegate not letting enough gases through, that's whay i went with the tial 38mm ewg route. but i'm still creeping with the 38mm, should've went with the 44mm. i'm still on the stock L fwd tranny with a a 11lb flywheel and clutchmasters stage 3. shifting is tight, feels perfect. also fwd axles are thicker than awd axles, however i tore my outer cv boost on both sides when trying to do a burnout. left a huge mess, haha.
like i said, my wife would've killed me if she found out that a standalone costed north of $1000.
post some pics up, cant wait to see it.
3 year project ej18t '93Impreza1.8T Normally Aspirated with bolt-on Forced Induction Powertrain 26 07-22-2008 07:18 PM
ej18t project manuelmatias Subaru Conversions 5 04-09-2007 02:02 AM
Pics of my EJ18T scoobyimprza Normally Aspirated with bolt-on Forced Induction Powertrain 13 11-02-2003 12:14 AM
Pics of my EJ18T scoobyimprza Subaru Conversions 8 10-03-2003 12:16 AM
finalizing EJ18T fuel system setup scoobyimprza Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-26-2003 08:06 PM
