Old 10-15-2008, 07:39 PM   #1
L Bo
RIP Brother
Member#: 8739
Default gorrila glue for tire plug (yea or nay)
instead of rubber cement
I bought these crappy arse plugs that came with the cement I needed. I wanted just cork plugs but they were only available in a $30 complete kit, figure to try these $2 plugs and cement instead. They leak, don't insert right (broke 4 of 10) and are shaped like a devo hat. The glue is worthless and want to try something stronger.
What if I soak that plug in gorilla glue, does GG work on rubber?
L Bo is offline   Reply With Quote
Old 10-15-2008, 07:44 PM   #2
Brad Pittiful
Member#: 34931
devo hats are called...energy domes
Brad Pittiful is offline   Reply With Quote
Old 10-15-2008, 07:50 PM   #3
Protege Menace
Member#: 41950
faq u rug
what the hell is going on here
Protege Menace is offline   Reply With Quote
Old 10-15-2008, 07:52 PM   #4
MikeCee
Member#: 136687
15 iginla, dup...
While I don't like you, I don't want you to die. So don't be a retard here.
MikeCee is offline   Reply With Quote
Old 10-15-2008, 07:52 PM   #5
-Kevlar-
Member#: 82378
-Kevlar- is offline   Reply With Quote
Old 10-15-2008, 07:52 PM   #6
Impaled
Member#: 149442
Go get plugs or patches that don't suck... Gorilla glue is mediocre at best unless used on wood.
Impaled is offline   Reply With Quote
Old 10-15-2008, 07:53 PM   #7
Protege Menace
Member#: 41950
faq u rug
anal cameltoe? : puke:
Old 10-15-2008, 07:53 PM   #8
The Motel Fella
Member#: 140147
02 '13 Sienna
I make minivans look hot
It's not a vulcanizing glue I think, so in the interest of ur safety, no
The Motel Fella is offline   Reply With Quote
Old 10-15-2008, 08:09 PM   #9
Ghosthound
Member#: 110979
2010 FJ Cruiser
1999 Miata
not to mention gorilla glue is not pliable when dry...
Ghosthound is offline   Reply With Quote
Old 10-15-2008, 08:09 PM   #10
Damn Yankee
Member#: 53066
work bum look a lot
alike, daddy.
The problem with GG is that it dries hard, and when your tire flexes it'll crack and it'll leak again.
DAMNIT Ghosthound
Damn Yankee is offline   Reply With Quote
Old 10-15-2008, 08:14 PM   #11
CF-Ninja
Member#: 143114
2007 Impreza 2.5i
CGM
GG... It dries hard
CF-Ninja is offline   Reply With Quote
Old 10-15-2008, 08:27 PM   #12
L Bo
RIP Brother
Member#: 8739
I'll just pick up some cork plugs somewhere else, that's all I need.
OT Consumer Alert: Do Not Buy This;
I can hear the air leak down to 20PSI with these worthless plugs.
Old 10-15-2008, 08:31 PM   #13
Meat Supply
Member#: 137902
---- so good
it sucks....
i like those plug types that are the sticky rubber strips. they seem to work pretty good. i ususally push them in and leave maybe 3/4 inch or so and then light the sticky mess with a lighter and let the rubber and goo get all hot. i leave the tails then just drive over them and it cramms the rest against the tire. i've done this to a couple different ones and it works pretty good. can usually get them at any gas station just about.....
Meat Supply is offline   Reply With Quote
Old 10-15-2008, 08:52 PM   #14
subyguy2sfriend
Member#: 10497
2004 WRX Wagon
+1
I've even had luck using these dry. You push them in folded over, then yank them out quickly and it doubles back over for a nice tight seal. I got mine at Harbor Freight for a few bucks.
http://www.harborfreight.com/cpi/cta...emnumber=45183
subyguy2sfriend is offline   Reply With Quote
Old 10-15-2008, 09:08 PM   #15
L Bo
RIP Brother
Member#: 8739
yeah, I know what I need thanks. The hardware store I went to only had a massive $20 kit including these.... the sticky cork plugs weren't available stand alone (outofstock). I have the tools.... just need plugs and weaseled into those lame $3 rubber plugs.
Old 10-15-2008, 09:21 PM   #16
atrodger
Member#: 144718
2002 Lexx Nitro!
1982 Suzuki GS650L
wal-mart patch/plugs tires for $10.
atrodger is offline   Reply With Quote
Old 10-15-2008, 09:23 PM   #17
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Rule 1 of motorcycle tires. Never patch. It's a $100 tire, is that worth the risk?
In a car, where you've got 4 tires and you aren't going to fall off, go right a head, in your lawn tractor, your yard kart, even your bycycle, but not a motorcycle. That's my .02.
AO
m750 is offline   Reply With Quote
Old 10-16-2008, 09:05 PM   #18
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
holy **** dude, you're seriously going to risk your life to save a hundred bucks? At the very least, pull it off and use a bike patch on the inside, with the vulcanizing glue.
CosmoTheCat is offline   Reply With Quote
Old 10-16-2008, 09:09 PM   #19
alacrity024
Review Crew
Member#: 49476
wait is this for a bicycle, motorcycle or car? i didnt' feel liiker eading.
alacrity024 is offline   Reply With Quote
Old 10-16-2008, 09:10 PM   #20
alacrity024
Review Crew
Member#: 49476
oh it's for a scooter.
**** it dude you won't get going fast enough for a blowout to do much damage.. just use testors model cement
Old 10-16-2008, 09:11 PM   #21
alacrity024
Review Crew
Member#: 49476
and finally, i've never paid more than $20 to have a tire patched professionally.. i assume it's no different for two-wheeler tires.
Old 10-16-2008, 09:13 PM   #22
L Bo
RIP Brother
Member#: 8739
It's a plug. I bought some crappy ones that didn't work. Bought some better sticky ones today. I plugged it. It's not leaking. I didn't use gorilla glue.
It's a scooter, going less then 45MPH the air would leak slowly if anything. My old tire lasted a while with a plug.
Is it that big of a deal? I could see if I were hitting 100+ MPH, but a scooter with a slow tire leak is dangerous?
Old 10-16-2008, 09:14 PM   #23
CosmoTheCat
Member#: 3409
98 My FMIC
durr. I suppose the exhaust should have been our clue.
Yeah, have fun.
Old 10-16-2008, 09:16 PM   #24
L Bo
RIP Brother
Member#: 8739
It's a pain in the arse to remove; need to take exhaust off too. I had to break the seal when I bought it with my truck and a jack lift. Hard to put back on too, just a big pain in the arse project I don't feel like doing if I didn't have too.... the local shop had a machine that couldn't work with a 12" scooter rim.
I thought the plug would be enough
Old 10-16-2008, 09:56 PM   #25
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Having gone down at 25, I'm not interested in adding 20 mph. It's your road rash.
AO
plugged flat tire poll... OK, or catastrophe waiting to happen? bigpaulo Tire & Wheel 28 05-24-2013 04:49 PM
04 WRX Interior for 02/03 Interior or WRX TR Interior cartwheels4amile SCIC Private Classifieds 5 06-04-2010 11:53 AM
Kissing after getting BJ'ed or rimmed...yea or nay? edkwon Off-Topic 55 05-19-2008 09:03 AM
('93-'01) Backing plates on rear discs- yea or nay? beachbum Impreza Forum 3 08-08-2001 02:02 AM
('93-'01) undercoat / rustproofing yea or nea? RexNoir Impreza Forum 7 05-05-2001 12:49 AM
