Welcome to the North American Subaru Impreza Owners Club Thursday July 24, 2014
Old 10-16-2008, 07:54 AM   #1
ict-wrx
Member#: 149565
2002 Impreza Wrx
Default HELP, loud clicking noise from front drivers side.
ok, there is a loud clicking noise coming from the front driver side at take off. i am very sure this is probably the cv halfshaft. i found the at napa for 60 something each and autozone for 114 each. is this where everyone is getting their cv joints from? what vendor? and the swap out. anyone know of any write ups on this? im sure i could finger F my way through it but sure is nice to have some predetermined direction.
i emailed Jamie from Subaru for some info already so and help would be appreciated.
thanks, Branden
ict-wrx is offline   Reply With Quote
Old 10-16-2008, 05:17 PM   #2
ThomasM
Member#: 191697
2005 WRX
WR Blue
Thumbs up
It is a very easy removal/install. Simply unbolt the strut from the hub, the hub nut from the center of the hub, and the hub from the lower control arm. be carful when removing the nut from underneath the control arm, as the cauter pin can brake easily and the threads on the bolt itself and not terribly durable. When you pull the half shaft out of the transmission, (i assume you have a 5MT) be prepared for fluid leakage, as the inner seal usually will not hold after the shaft is removed and will need to be replaced. Install new seal, then the half shaft, rebolt everything correctly, paying special attention to torque specs(especially the hub nut which i think is 136.5 lbs.) and you're good to go. shouldn't be any kind of brake-in period on a new half shaft, but check the box/included instructions to be sure. Hope this helps.
ThomasM is offline   Reply With Quote
Old 10-16-2008, 05:20 PM   #3
ThomasM
Member#: 191697
2005 WRX
WR Blue
also, unless you had visual damage to one side over the other, they usually wear at about the same rate and it is good practice to replace both at the same time, unless of course you have a visual tare on one side that caused it to sling all of it's lube out and eat itself up.
Old 10-17-2008, 07:42 AM   #4
ict-wrx
Member#: 149565
2002 Impreza Wrx
actually thats exactly what happened. when i started hearing the clicking and jacked it up and seen the tear in the boot. only the drivers side is clicking but at $50 each from a hook up at Advance Auto i think i will just do both.
i have been told the the swap out is pretty easy mostly centered around getting out a pin that holds the shafts in, oh boo hoo. thats better then some of the other situations i have been thrown into fixing or upgrading cars/sportbikes before.
Old 10-20-2008, 07:18 PM   #5
ThomasM
Member#: 191697
2005 WRX
WR Blue
Cool
Glad to help!
Old 06-18-2009, 01:18 PM   #6
ict-wrx
Member#: 149565
2002 Impreza Wrx
Default An Update??!!!??
hello, its the original poster here. i swapped out the half shafts just fine but after another 8 months went by that noise came back and worst. i have it all torn down now. the problem, it wheel bearing. oh yes, took off the wheel to investigate more and the hub is soo loose in the spindle. too much play. thinking in my head of the terrible noise it was making and all the cars weight on that loose hub being pulled front to back by the movement call ed on by the driver. what was in front of me was truly the real cause of the problem that i had sank money in other fixes for nothing, (not really, at least all the other stuff is new now).
BUT, A PROBLEM, the hub wont come out, short of going ape S on it and ripping it out then running up a tree with the hub in one hand and some bananas in the other. am i missing something here? do i just need to pry the thing out?
Old 06-19-2009, 03:25 AM   #7
cbarth3
Member#: 67249
2004 WRX
you will need something like this
http://www.mytoolstore.com/wilmar/wtech04.html
can most likely be rented from local auto store.
found this at autozone
http://www.autozone.com/autozone/ino...ersSpecialized
cbarth3 is offline   Reply With Quote
Old 06-22-2009, 12:20 AM   #8
ict-wrx
Member#: 149565
2002 Impreza Wrx
bump, nobody has replaced or pulled their hubs before on a WRX???
loud clicking noise from left head ttownriver Normally Aspirated Powertrain 4 07-10-2009 07:29 PM
Loud clicking noise from rear when turning BooniesSTIDriver General Community 34 02-21-2006 12:51 AM
clicking from front drivers side OneArmedScissor Brakes, Steering & Suspension 3 04-25-2005 11:53 PM
can you help me figure out what i just blew? very loud clicking noise from the diff sideways slut Transmission (AT/MT) & Driveline 3 09-22-2003 12:58 PM
Rubbing brakes / noise from front driver side/AC buzzing sound Foz Service & Maintenance 3 01-13-2002 12:09 AM
