Old 10-16-2008, 11:22 AM   #1
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
Default STI and WRX intake manifold difference?
OK. I’m sure it has being covered before, but I could not find it! So any help would be nice.
Is the STI intake manifold better or is just “cosmetics”? If it is, will a 06 + STI manifold fit/work with my 06 WRX? Any advantages?
Thanks
Ferraz is offline   Reply With Quote
Old 10-16-2008, 11:37 AM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
should fit no prob both dbw set ups
sense of nature is offline   Reply With Quote
Old 10-16-2008, 11:40 AM   #3
Badler
Member#: 133597
I believe they are the same minus the red.
Badler is offline   Reply With Quote
Old 10-16-2008, 12:53 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
It will net 0HP and 0TQ at the expensive of one pain in the ass install...doing that swap is a mother let me tell you.
Old 10-16-2008, 01:04 PM   #5
onesixnin
Member#: 50992
09 Tribeca
Worst subaru blue
when did the wrx goto the plastic manifold? 08? Cause I'm thinking there could be benefits of getting rid of it.
Plastic FTL
onesixnin is offline   Reply With Quote
Old 10-16-2008, 01:22 PM   #6
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
OK, Thanks! I think I will use the time and money in other mods.
Plastic FTL
Yes, 2008.
Old 10-16-2008, 02:08 PM   #7
06WHTWRX
Member#: 173690
2005 Ferd
F-TeenThousand
Plastic FTL
I'm 99% sure that the previous metal manifold will NOT work on an 08
06WHTWRX is offline   Reply With Quote
Old 10-16-2008, 02:23 PM   #8
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Yea, I was doin a turbo inlet and some1 told us to take off the intake manifold. Total fail.
Jubert69 is offline   Reply With Quote
Old 10-16-2008, 06:02 PM   #9
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Yea from what I read the red is just some heat resistor thing, but it doesn't really net anything at all. If you want the red take yours off and just paint it.
talvai is offline   Reply With Quote
Old 10-16-2008, 11:51 PM   #10
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
I believe there a few small little nik nak differences but nothing that causes power gains/losses. And the 08 manifolds aren't plastic (which I'm sure you know or figured, anyway). I've heard that material is actually better for retaining heat than the metal. Just what I've been told, though...
ThreeEleven is offline   Reply With Quote
Old 10-17-2008, 01:07 AM   #11
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Stick with the stock manifold. The plastic manifold is lighter and works just as well.
dexterous is online now   Reply With Quote
Old 10-17-2008, 01:09 AM   #12
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
Not plastic, but something that looks like plastic...
I heard that is not just about heat. It is easy/cheap to make a very smooth surface with "plastic".
Regards
Old 10-17-2008, 01:14 AM   #13
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
The red paint on the STI intake manifold is just that - paint. No thermal characteristics.
The 08s do have a plastic [or plastic-esque] IM. The STis don't, but the WRXs do. Benefits are decreased heat transmission [it's like a big phenolic spacer... kinda...ish], drawbacks are decreased holding pressure.
MB38 is offline   Reply With Quote
Old 04-02-2009, 01:11 AM   #14
nmasse
Member#: 183629
2015 WRX
World Rally Blue
do you know how much pressure it can handle? (the 08 plastic)
nmasse is offline   Reply With Quote
Old 04-02-2009, 06:26 AM   #15
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
when did the wrx go to the plastic manifold? 08? Cause I'm thinking there could be benefits of getting rid of it.
Plastic FTL
Yes it was in 08. No there are no benefits to changing it unless you are making some really insane power and it wont work with your set up.
Yes it will work but its a total PITA! You will need parts from the 08+ STI and an older 07- WRX as well to complete the swap. Power gained would be about 0hp on a stock or even well moded car.
This^!!!
I saw some one on another forum take one and block it off and it held 35PSI over night with no problems! FYI thats more abuse in 12 hours then a 35R would put on it in a year!
The new Composite Intake manifold has nothing wrong with it! The only real problem is the new I/C. It has composite end tanks and at higher boost levels they are known to start leaking at the joint to the core.
As for the OPs question its red paint! thats it. Nothing more.
Badmunky is offline   Reply With Quote
Old 04-02-2009, 07:12 PM   #16
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
just stick with the plastic manifold. I have yet to read where one failed under pressure and like already said it saves weight and is smoother on the inside.
Steve.804 is offline   Reply With Quote
Old 09-21-2009, 09:25 AM   #17
_MFB_
Member#: 219676
09 Forester XT
Steel Silver
What about swapping the 08 wrx intake manifold with the 09 wrx?
_MFB_ is offline   Reply With Quote
Old 09-21-2009, 10:06 AM   #18
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
They are the same.
I think there was an LGT running more than 30psi on the composite IM.
09rexwagon is offline   Reply With Quote
Old 09-21-2009, 04:19 PM   #19
Astartes
Member#: 183813
2006 WRX TR OBP
WRX STi SGM
Compromise?
But for the OP if you're planning on deleting your TGVs any time soon just paint it then.
Astartes is offline   Reply With Quote
Old 09-22-2009, 07:58 PM   #20
drummerboy827
Member#: 124720
2009 WRX Hatch
Can anyone else hear a plastic whistle sound around 4k rpms on their 09 WRX? Kinda sounds like a train whistle. I just figure its the intake manifold.
drummerboy827 is offline   Reply With Quote
Old 09-22-2009, 08:08 PM   #21
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Running a STi manifold on an 06 wrx here. I had GS port it but they had no wrx cores. Only difference was the FPR vac line tap, needed a longer hose, no big deal.
Merp is offline   Reply With Quote
Old 09-22-2009, 11:20 PM   #22
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
my knuckles agree with DISSSSSSSSSSSSSSSSs
noonagon is offline   Reply With Quote
Old 09-23-2009, 12:21 AM   #23
Leggy_09
Member#: 220098
2009 Leggy GT
FWIW the LGT uses the same manifold. I bought a STi off ebay soley for the wrinkle red color and wanting WRX throttle body placement for intercooler routing.
Hill up at Agile performance told me this was actually a good mod to do, because the LGT/08+wrx manifold suffers from "alot of turbulence" in the air stream. I didnt ask any other questions about it, but he knows what he is doing enough for me to believe him. :shrug: I dont think (nor got the impression that he does) it is a life-altering, dyno-smashing modification, but is not without merit, and may be worth considering for the 08+ crowd doing TGV's anyway....its not expensive, and you are "in the neighborhood" so to speak. Just be aware whatever IC setup you were running previously, some or all of it wont work afterwords.
Leggy_09 is offline   Reply With Quote
Old 09-23-2009, 09:13 AM   #24
09rexwagon
Member#: 216135
2011 Civic SI
Hmmm, if anything the composite manifold is likely to reduce turbulent flow since it is so smooth inside relative to a cast aluminum manifold.
Old 09-23-2009, 09:34 AM   #25
Leggy_09
Member#: 220098
2009 Leggy GT
i think it has more to do with the way the throttle body was aligned/placed than the interior surface. Ive also never looked inside one of the composite manifolds. There could be parts where the molding left protruding edges at the runners or tb or wherever. The composite manifold is much cheaper to produce than the sti one is, and lets face it, subaru wasnt out looking to do the modding community favors by making the change, it was purely a cost decision. If it functioned better for less money, one has to ask the question why the STI's wasnt changed in 2008 like the wrx was. I would imagine subaru left the metallic one on the sti for a reason.
2.5I and WRX intake manifolds fateo66 Engine/Power/Exhaust 57 04-23-2010 11:31 AM
KS: STI shortblock, wrx intake manifold, coilpacks and more kcscoob Engine/Power/Exhaust 4 10-07-2009 04:48 PM
RS SOHC and WRX Intake manifold differences Odyknuck Normally Aspirated with bolt-on Forced Induction Powertrain 11 02-03-2009 05:25 AM
V8 Heads and WRX Intake Manifold ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-06-2006 04:22 PM
2004 STi and WRX ride height difference? jroberts Brakes, Steering & Suspension 2 08-29-2004 12:30 PM
